75bus4/me Samba Member
Joined: November 10, 2011 Posts: 363 Location: Arizona
Posted: Sat Feb 25, 2012 4:58 pm Post subject: **Update-FIXED**Just died? then started after 20 |
3 month old Electric fuel pump on a single Weber .1975 bay.
When teaching my son stick shift the bus died and would not re-start. The bus turned over tried to stay running but no go. I checked the filter and it is new a clean I checked the pump and very hot. We waited about 20 min and it stared and we drove home with no problem.
Any ideas on what it could have been?
Thanks Gerry _________________ 1975 Bay Window {Big Red}
jeffsbugs Samba Member
Joined: May 02, 2011 Posts: 294 Location: Nanaimo, British Columbia, Canada
Posted: Sat Feb 25, 2012 5:16 pm Post subject: |
Fuel starvation or pump is starting to go.
What type of pump? A pic would help.
Jeff _________________ '73 Westfalia, rebuilt 1700, dual OG solex - 3500 miles and counting
'62 Baja |
Posted: Sun Feb 26, 2012 5:31 pm Post subject: |
It's a carter. electric and only 3 months old. I re bolted it tighter could it have been a loose ground?
Gerry _________________ 1975 Bay Window {Big Red} |
Posted: Sun Feb 26, 2012 9:15 pm Post subject: |
Drove it today no problems..
Would like to know what it could be kind of wierd. _________________ 1975 Bay Window {Big Red} |
Posted: Mon Feb 27, 2012 8:08 pm Post subject: |
any ideas???
Thanks _________________ 1975 Bay Window {Big Red} |
Posted: Mon Feb 27, 2012 10:14 pm Post subject: |
| More information about your installation would get you more responses, particularly pictures of your pump as installed. |
Posted: Tue Feb 28, 2012 8:28 am Post subject: |
| Wildthings wrote: | | More information about your installation would get you more responses, particularly pictures of your pump as installed. |
Ok Thanks
Will try to get some pics soon. after my work week
Posted: Sat Mar 03, 2012 1:34 pm Post subject: |
Running and starting fine now. but unsure of what it could of been?
Thanks
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 412 Location: United Kingdom
Posted: Sat Mar 03, 2012 3:19 pm Post subject: |
Last time it did it to me, as in bus died for no apparent reason, then having to go through the usual roadside fault finding procedure was in October 2011. It was the condensor on the distributor, which after about 20 minutes decided on its own that it was OK again. I have replaced it with a Beru condensor, but it was another nail in the coffin for conventional ignition for me, I'm going to swap over to electronic ignition sometime this year. Your loose ground theory sounds very plausible.
No harm in checking and giving a service to all your ignition connections and wires, your distributor cap, rotor arm, points, plugs, condensor, coil etc. _________________ 1976 Microbus L (1800cc Type 4)
Previously...
1972 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 Camper (Danbury) |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 1536 Location: Kaneohe
Posted: Sat Mar 03, 2012 3:40 pm Post subject: |
| chimneyfish wrote: | | ... It was the condensor on the distributor, which after about 20 minutes decided on its own that it was OK again. ... I'm going to swap over to electronic ignition sometime this year. ... |
Your problem might have been a bad connection rather than a bad condenser. Condensers do not heal themselves within or after twenty minutes. If you do switch to electronic, carry points and condenser in your spare parts.
Aloha
tp |
Posted: Sat Mar 03, 2012 4:13 pm Post subject: |
Thanks Tom. In that 20 minutes I had pushed on every connection going, but at least I feel better with a Beru than the non-descript replacement condensor I was running. As you rightly say, even if electronic, carry spare points and condensor, and a static timing light. (sorry, don't want to hijack thread) but does anyone know of there is any fact in the rumours that if you have Pertronix ignition fitted, that if you leave your key in the ignition with the ignition on but engine off, that the Pertronix unit will burn out and fail after a minute or two? Or is that just a myth? I read it somewhere on here, which gives me some trepidation to the electronic system. _________________ 1976 Microbus L (1800cc Type 4)
Previously...
Posted: Sat Mar 03, 2012 5:04 pm Post subject: |
| chimneyfish wrote: | | ... but does anyone know of there is any fact in the rumours that if you have Pertronix ignition fitted, that if you leave your key in the ignition with the ignition on but engine off, that the Pertronix unit will burn out and fail after a minute or two? Or is that just a myth? I read it somewhere on here, which gives me some trepidation to the electronic system. |
I've also read that many times. It can also happen with points and condenser ignition if the points are ... My solution is two distributors. One is on the engine and the other one has new points and condenser and has been tested on the engine. I have a punch mark on the engine case to swap in a distributor without a timing light. Possibly there is a bit of difference in the distributors that requires a timing light, but the punch mark can get me going again on a cold dark road. I recently went to Aeromech for my 300,000 mile maintenance check and his timing was a bit different from my punch mark and there was some improvement in engine performance from the timing I had set.
Aloha
tp |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 1391 Location: viroqua wi.
Posted: Sat Mar 03, 2012 5:09 pm Post subject: |
| Tom Powell wrote: | | chimneyfish wrote: | | ... but does anyone know of there is any fact in the rumours that if you have Pertronix ignition fitted, that if you leave your key in the ignition with the ignition on but engine off, that the Pertronix unit will burn out and fail after a minute or two? Or is that just a myth? I read it somewhere on here, which gives me some trepidation to the electronic system. |
Aloha
tp | Get a second clamp, time your spare, take it off clamp and all. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5360 Location: Edmonds, WA.
Posted: Sat Mar 03, 2012 11:43 pm Post subject: |
was the intake manifold cold to the touch? that single carb can ice up the manifold very easily....try driving for like 10 mins from cold and see if the manifold gets cooler to the touch...if it iced up, it would keep the fuel from being a mist, and make it into drops, with will flood the engine basically, and after about 20 mins, it would warm up enough to start.
maybe?
busdaddy? _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2044 Location: Acton, Ontario, Canada
Posted: Sun Mar 04, 2012 5:51 am Post subject: |
| Stuartzickefoose wrote: | was the intake manifold cold to the touch? that single carb can ice up the manifold very easily....try driving for like 10 mins from cold and see if the manifold gets cooler to the touch...if it iced up, it would keep the fuel from being a mist, and make it into drops, with will flood the engine basically, and after about 20 mins, it would warm up enough to start.
maybe?
busdaddy? |
Yep could have been carb ice if the temp and dew points were close. Also I had a coil years ago that would heat up and fail so I would have to let it cool down to work again. Anything past 20 mins of running it would fail. _________________ Brett
"I do not see things as black and white, but everything as very colourful!"
'75 Kombi/Westy (2.0L CV, H-Lifters, '75-'79FI mix, XR700, 003 Auto) project.
03 Jetta TDI, 04 Honda civic, 71 super beetle
Licensed pilot (single engine land VFR)
Rust In Peace: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
Posted: Sun Mar 04, 2012 9:45 am Post subject: |
| 1975 Kombi wrote: | | Stuartzickefoose wrote: | was the intake manifold cold to the touch? that single carb can ice up the manifold very easily....try driving for like 10 mins from cold and see if the manifold gets cooler to the touch...if it iced up, it would keep the fuel from being a mist, and make it into drops, with will flood the engine basically, and after about 20 mins, it would warm up enough to start.
maybe?
busdaddy? |
Yep could have been carb ice if the temp and dew points were close. Also I had a coil years ago that would heat up and fail so I would have to let it cool down to work again. Anything past 20 mins of running it would fail. |
Great suggestions but in my case it was one of the warmest days I have driven around 82 degrees and I was in a parking lot teaching my son stick shift. The other thing is driving in the parking lot I was getting very little air flow only traveling around 5 mph. For us here in Arizona it was a winter day.  _________________ 1975 Bay Window {Big Red} |
Tcash  Samba Member
Joined: July 20, 2011 Posts: 539 Location: San Jose California
Posted: Sun Mar 04, 2012 11:09 am Post subject: cranks won't start |
Hi, if your pump was hot connections are good. You need to determine if it is a fuel or ignition problem. Then go from there. Good Luck
Cranks Won't Start |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23841 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Sun Mar 04, 2012 12:08 pm Post subject: |
^X2^
There's lots of things that can fail when warm like coils, points, condensers, rotors, wires and plugs in the ignition system and pumps and float levels in the carb. Don't rule out tight valves or bad compression either and there's always the possibility of something floating around in the fuel tank intermittantly blocking the outlet, or a bad ignition switch.
There, does that narrow it down enough?  _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Posted: Sun Mar 04, 2012 1:53 pm Post subject: |
| 75bus4/me wrote: | | 1975 Kombi wrote: | | Stuartzickefoose wrote: | was the intake manifold cold to the touch? that single carb can ice up the manifold very easily....try driving for like 10 mins from cold and see if the manifold gets cooler to the touch...if it iced up, it would keep the fuel from being a mist, and make it into drops, with will flood the engine basically, and after about 20 mins, it would warm up enough to start.
maybe?
busdaddy? |
Great suggestions but in my case it was one of the warmest days I have driven around 82 degrees and I was in a parking lot teaching my son stick shift. The other thing is driving in the parking lot I was getting very little air flow only traveling around 5 mph. For us here in Arizona it was a winter day.  |
It can ice up easy on hotter days too, i watched my intake on a bug ice up in 70 degree weather once...just idling, i watched the frost form....first time i ever had heard about a cold issue.
brings new meaning to the term "cold air intake"  _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Posted: Sun Mar 04, 2012 1:59 pm Post subject: |
Carb ice depends on the temp and dew point numbers. If the numbers are close then the drop in temp going through the venturi will create ice on the walls of the carb and choke it off. The symptoms ahead of time is a gradual loss in the pedal response and then the engines dies.
