Semper_Dad Samba Member
Joined: May 14, 2005 Posts: 2627 Location: HELL Paso, TX
Posted: Sun Feb 26, 2012 2:19 pm Post subject: Electrical Repairs |
OK, so I'm finally at the point where I need to permanently fix some of the band-aid electrical repairs on my car. Mostly broken or loose F style slip-on crimped connectors.
Today was the last straw. I jumped into my car to cruise downtown in order to have a leisurely breakfast. Started right up and then died with in seconds. Attempted to restart but just wouldn't go. Took a look in the engine compartment only to see the some smoke coming off the coil to Cutoff valve to choke wire. Yanked the connection loose from the coil. + Coil wire from ignition was OK but the jumper wire was crispy. Need to replace it ASAP. I'm guessing the choke wire had come loose and grounded itself.
So,...my question is... Who uses what brand and style crimper to reproduce OEM style connections? Where is the best source for connectors. The local auto part place here seem to only carry the cheap tools and connectors (aluminum?)
German Supply seams to have the correct tool and connectors.
http://www.germansupply.com/home/customer/product.php?productid=17094&cat=278&page=2
Anyplace else? _________________ 74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 99 181s in the world |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 619 Location: louisville Ky
Posted: Sun Feb 26, 2012 3:36 pm Post subject: |
| McMaster-Carr has the connectors. I bought my tool from Mac Tools. |
Posted: Sun Feb 26, 2012 4:35 pm Post subject: |
| Ron Domeck wrote: |
Any idea what part or model number. _________________ 74 VW Thing - Walküre
citroen Samba Member
Joined: February 28, 2010 Posts: 833 Location: louisville ky
Posted: Sun Feb 26, 2012 4:39 pm Post subject: |
also i covered my connections with shrink wrap so if they fell off it has a better chance of not shorting out
the right crimper for a good connection i bought mine at home depot in the electrical section made by thomas and betts
Posted: Sun Feb 26, 2012 4:47 pm Post subject: |
| citroen wrote: |
| also i covered my connections with shrink wrap so if they fell off it has a better chance of not shorting out |
Good idea. The shrink looks like it would provide some stain relief as well. _________________ 74 VW Thing - Walküre
Al Capulco Samba Member
Posted: Sun Feb 26, 2012 10:34 pm Post subject: |
| I would buy the connectors from german supply, they have already done all the work for you. The cost may be a little more per connector but they are the right ones. As far as a crimper, I like my AMP #47044. It will only crimp 18-16 but it has the ability to hold the connector in place and crimp both crimps at the same time. I bought several crimpers before the AMP and they didn't work very well. The F type connector is a great connector but very hard to crimp properly without the right tool. You can sometimes fine the AMP crimper used on Ebay for less than $30. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2012 Location: . . . in denial.
Posted: Mon Feb 27, 2012 12:04 pm Post subject: |
I have discussed this issue with some buddies who work in aerospace. They recommend ratcheting crimpers, because they make a consistent crimp every time that is not dependent on the user's grip strength.
They also recommend using the same brand of crimper and terminals. That way you know the crimper is properly matched to the terminals.
As for the notion of heat-shrink tubing providing strain relief (with all due respect to Semper Dad) I think that if you are depending on heat shrink for strain relief, your connection is going to have other problems. |
Posted: Mon Feb 27, 2012 12:42 pm Post subject: |
| Captain Spalding wrote: |
Agree on the ratcheting style crimpers. As far as the shrink tubing for strain relief I was referring the moderate lateral movement that eventually causes fatigue in the conductor. I'm not planning to swing like Tarzan from my coil wire. One of the nice things about the double barrel connector is that it really secures the wire by it's cover. However, if improperly crimped, the cover can be damaged. A piece of shrink can work as a brace of sorts. Purely a secondary benefit to it's providing insulation to the connector itself. _________________ 74 VW Thing - Walküre
mondshine Samba Member
Joined: October 27, 2006 Posts: 1006 Location: World's Motor Capital
