johnanddes Resident Chip Chucker
Joined: October 17, 2004 Posts: 605 Location: Orcutt CA
Posted: Sun Jun 10, 2007 6:58 pm Post subject: 3-point seat belts in a 64 bug |
Okay all,
I am trying to install 3 point non-retractable seat belts into my 1964 vw beetle. My question is this, where is the hole located for the shoulder strap? Is it on the B-pillar, or is it level with the top of the seat? Any ideas?!?!?  _________________ John
64 Stock Beetle
Chuckin' chips at a store on the Central Coast near you! |
dlxcoupe Samba Member
Posted: Sun Jun 10, 2007 7:14 pm Post subject: |
Here is a 64.. this help?
chauk Samba Member
Posted: Mon Jun 11, 2007 8:59 am Post subject: How 'bout retractable? |
If I can jump in -
I want to install RETRACTABLE belts. Where is the hole for those?
Up on the pillar? I don't see a higher hole in the above pic.
HELP? |
Posted: Mon Jun 11, 2007 9:48 am Post subject: |
What you see is what you get on the 64.. Do not know about other years..
No higher seatbelt holes than the ones pictured.. I guess you could cut and weld in your own - - |
glutamodo  The Android
Joined: July 13, 2004 Posts: 17986 Location: Douglas, WY
Posted: Mon Jun 11, 2007 11:13 am Post subject: |
Another pic:
clarkbre Samba Member
Joined: June 20, 2004 Posts: 1107 Location: Everett, WA
Posted: Mon Jun 11, 2007 11:37 am Post subject: |
| Another thing to remember is that in 1964 the over the shoulder seatbelts weren't standard equipment...seatbelts probably weren't standard equipment. There may not be a hole for the higher up shoulder harnesses until about 1968 or 69 when they had to be standard. I know my '69 had over the shoulder harnesses that bolted in right above the pop-out hinge but I haven't checked to see if my '65 has the holes or not. I kind of doubt it does. |
79SuperVert  Samba Member
Joined: May 31, 2002 Posts: 8252 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Mon Jun 11, 2007 11:56 am Post subject: |
Not that I've installed a retractable one myself, but I did install the non-retractable three point type on my 65 vert, and my 62 has the upper mount point on the "B" pillar as well for a shoulder belt.
It seems to me the retractor mechanism for a retractable three-point ought to attach at the bottom of the "B" pillar, with a loop for the shoulder belt at the higher "B" attachment point. It won't feel quite as comfortable as a modern three-point belt because the shoulder belt will be going straight back over your shoulder instead of up the way they do now. But that's what the upper "B" attachment point was for. |
chauk Samba Member
Posted: Fri Jul 20, 2007 8:43 am Post subject: Seat Belts 64 |
| Thanks! That helps! |
67type15 Samba Member
Joined: March 07, 2006 Posts: 15 Location: Kitchener, ON
Posted: Tue Mar 13, 2012 8:23 pm Post subject: 3-point Seatbelts in Beetle convertible. |
| I was wondering if anyone had any ideas about how to install 3-point seatbelts (shoulder belt) into the rear seating of a Beetle convertible? Anyone ever attempt this? |
McGuirk Samba Member
Posted: Wed Mar 14, 2012 10:57 am Post subject: |
Three point mounting for the back & front on my 64.
I think they moved the attachment point hole up higher for the 1965 model. There's a picture in the 1965 owner's manual with it up higher on the pillar. I used to have a 65 -- I didn't have 3 point belts in that car but I remember the plug was higher. |
2tone64 Samba Member
Posted: Thu Mar 15, 2012 11:36 am Post subject: |
I know in my 64 with the 3 point belts, they don't stay on my shoulders for crap... The only way they stay on is if I super-tighten them, then I feel like I am strapped in a ride at Disneyland.
Most of the time its just a lap-belt with an extra part across my midsection. _________________ 64 Sunroof Bug, 68 Bug, 73 Super 'Vert, 01 Dodge 1500, 00 Subaru Outback, 46 Dodge 1-Ton, 68 Plymouth Roadrunner |
willimammoth Samba Member
Joined: July 08, 2010 Posts: 54 Location: Meridian, Idaho
Posted: Tue Mar 27, 2012 4:53 pm Post subject: |
If I may.
This is the backseat of my '63. I have the three point belts from Wolfsburg West and the instructions say to attach the lap belt mount to the body-to-chasis bolt (to the left of the un-attached seatbelt you see sitting there.)
The bolt that is there is too short to reach when the belt and washer on on there, and the indented space around the bolt is to small to really fit the metal piece in it.
My question is... Can I attach the lap belt mount to the backseat backrest bolt? Is it strong enough to hold? _________________ .,/[__]\,.
('o\.!./o')
..U----U..
Ruby Red '63 bug
Do your part and check the stolen section regularly. Keep an eye out for listings in your area. |
pdivizzle0112 Samba Member
Joined: July 13, 2011 Posts: 256 Location: Toluca Lake
panicman Samba Member
Joined: December 18, 2011 Posts: 454 Location: Oregon
Posted: Wed Jul 04, 2012 10:55 am Post subject: |
Not trying to resurrect this thread, but I would not use the backrest bolt to attach a seat belt. Way too small, and it is not structural. It would just rip out. I would trim the jute back and get a longer bolt at any hardware store. That big chassis bolt may offer actual protection, the small backrest bolt will not. _________________ Present:
1960 Type 1 project underway
Past:
1966 Type 1
1966 Type 1
1965 Type 1 |
