Air Simple Samba Member
Posted: Mon Feb 27, 2012 11:56 am Post subject: 14" Porsche Fuchs on a 62 beetle? |
| Has any one run the 14"x5.5" Fuchs on a beetle. I have a 62 beetle and came across a deal on these wheels with tires. Im interested but I have two concerns. I eventually want disc brakes in Front- Will they fit? and I wonder how much 14" front wheels will effect my speedometer speed. I like the flat look of the 14" fuchs. I forgot ro mention I have a 2" narrowed beam. |
babysnakes Samba Member
Joined: August 19, 2008 Posts: 3774 Location: West Boca Raton, Fla.
Posted: Mon Feb 27, 2012 1:13 pm Post subject: |
Most disc setups won't allow 14" wheels. I'm bummed because I have a set also. The speedo issue can be fixed with taller tires. _________________ '69 SC under resto
'72 deluxe daily
'78 Westy motor transplant in progress
'71 super vert
1st bus, '67 Westy in '83. Thank you '74 Pontiac Ventura.
Luftwagens
420GOAT wrote:
..dont ever ever ever ever EVER, compare any bus forum to a bug forum... |
Bruce Samba Member
Posted: Tue Feb 28, 2012 1:49 am Post subject: |
| babysnakes wrote: | | Most disc setups won't allow 14" wheels. ... |
Ummm, all 911s, all 912s, and all 914s had disc brakes, and they're what the 14" Fuchs were designed for.
Go ahead and buy the wheels. They'll fit your K&L Beetle with discs, even if you put dropped spindles on. _________________
| Glenn wrote: | | ..... and like them better than Bosch. |
Posted: Tue Feb 28, 2012 10:16 am Post subject: |
| Bruce wrote: | | babysnakes wrote: | | Most disc setups won't allow 14" wheels. ... |
Go ahead and buy the wheels. They'll fit your K&L Beetle with discs, even if you put dropped spindles on. |
My bad, I'm a Bus guy and most kits are 944.I've been told by vendors I need 15"wheels. I stand corrected. _________________ '69 SC under resto
'72 deluxe daily
'71 super vert
Luftwagens
MURZI Samba Member
Joined: August 25, 2005 Posts: 3690 Location: Madisonville, La
Bruce Samba Member
Posted: Wed Feb 29, 2012 2:15 am Post subject: |
| babysnakes wrote: | | Bruce wrote: | | babysnakes wrote: | | Most disc setups won't allow 14" wheels. ... |
My bad, I'm a Bus guy and most kits are 944.I've been told by vendors I need 15"wheels. I stand corrected. |
Oh, and they fit stock VW Bus discs too! _________________
Posted: Sat Mar 03, 2012 11:09 am Post subject: Thanks |
| All good info. Like some one said 911E, 914-6, and 912E all had disc brakes and those wheels fit on them. I kind of like the lower center of gravity, and I can correct the Speedo with tire size. |
