Pre heater tubes on classic vw beetle intake off of carb
mattlutz
mattlutz is offline
PostPosted: Tue Feb 28, 2012 12:23 pm    Post subject: Pre heater tubes on classic vw beetle intake off of carb Reply with quote
can the pre heater tubes be cut off and welded shut on the 1600 motors that come off the long flange from the carb on a dual port and goes to the exhaust then without negatively affecting the motor.?
anthracitedub
anthracitedub is offline
PostPosted: Tue Feb 28, 2012 12:39 pm    Post subject: Reply with quote
You should do a search on preheat tubes and read up on this topic... I think you'll find that keeping them will be beneficial.
Nevada Notch
Nevada Notch is offline
PostPosted: Tue Feb 28, 2012 1:47 pm    Post subject: Reply with quote
This section of the intake manifold serves 2 functions.
1.) It channels hot air through the bottom of the center section of the intake runner and it keeps the intake from icing over in the cold weather. When the runner ices over it will cause acceleration stumbling when transitioning from idle. The accelerator pump does not atomize fuel, it squirts it like a squirt gun. These droplets of fuel do not atomize until they hit the bottom of the hot intake runner.
2.) It also serves as a support for the center section of the intake runner. If you were to cut these off, you will have to brace the center section of the manifold due to the pull of the throttle cable.
1966 Euro
1600DP
Dual 34mm ICT's
99% Resto-Custom Daily Driver
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Feb 28, 2012 5:15 pm    Post subject: Reply with quote
Are you running an aftermarket muffler/header that lacks the proper connections for the heat riser?
61SNRF
61SNRF is offline
PostPosted: Tue Feb 28, 2012 6:14 pm    Post subject: Reply with quote
Do you mean this pipe (lower red arrow)?...
Photo from the Gallery thanks to shakers73
-Bruce
An ounce of prevention is worth a pound of cure.
mattlutz
mattlutz is offline
PostPosted: Tue Feb 28, 2012 6:20 pm    Post subject: Reply with quote
no its the one that comes from the intake tubes off carb but goes to exhaust the small dia tube on left and right..the one in your pic behind the aluminum heater hose
mattlutz
mattlutz is offline
PostPosted: Tue Feb 28, 2012 6:22 pm    Post subject: Pre heater tubes on classic vw beetle intake off of carb Reply with quote
not where the red arrows are ..the small dia tubes that bolt on to the exhaust it comes off of the larger tubes from the intake of the carb on left and right side..
mattlutz
mattlutz is offline
PostPosted: Tue Feb 28, 2012 6:24 pm    Post subject: Pre heater tubes on classic vw beetle intake off of carb Reply with quote
in your pic its the silver rusted pipe to the left of the distributor
61SNRF
61SNRF is offline
PostPosted: Tue Feb 28, 2012 6:43 pm    Post subject: Reply with quote
In that case Nevada Notch has answered your question as well as I or most can, and all the other comments relevant to pre-heat tube apply as well.
-Bruce
zzhayward
zzhayward is offline
PostPosted: Tue Feb 28, 2012 11:30 pm    Post subject: Reply with quote
In warm climes ( HI, SoCA, Mex) you can get away without carb heat. Cold morning or non warm climes you must have. Something about entropy and change of state from liquid to gas ((see physics of a refrigerator)) Ditto on the carb support need
KTPhil is offline
PostPosted: Wed Feb 29, 2012 8:52 am    Post subject: Reply with quote
Why do you want to do this?
Back to my question about what muffler/header you are running...
