Any one else had this? Is it common?
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
NZer
NZer is offline
PostPosted: Tue Feb 28, 2012 6:23 pm    Post subject: Any one else had this? Is it common? Reply with quote
Ive started to going through my Westie as it is starting to heat up so I was in the back and pulled out the rear seat and under seat box and noticed that the floor was a bit damp and I couldnt find any thing obvious so I started her up and let the motor warm up and had a closer look at the rear heater and wiggled the top hose and got a squirt of coolant from between the coolant shut off and the inlet of the core. Rolling Eyes
So i eventually pulled it apart and the O ring was flat and on the way out so I replaced it and the problem went away!! Very Happy
Not happy about the plastic fittings back there! Confused
A sad looking 88 Westfalia, MT 2.1 with 150k on the clock and several issues!
RadioRental
RadioRental is offline
PostPosted: Tue Feb 28, 2012 6:42 pm    Post subject: Reply with quote
Same here when I pulled the bench seat out to soundproof the floor. O-ring was flat as a pancake.
__________________________________
'87 2.1. 125K 4spd Not rebuilt "Red Dwarf"
joseph928
joseph928 is offline
PostPosted: Tue Feb 28, 2012 8:17 pm    Post subject: rear heater Reply with quote
Blue Bay Bus I think we all have this problem , mine to. AT least these vans keep us on our toes! Very Happy
1987 syncro westy tin top sun roof GW2.3 rear locker decoupler custom bumper roof rack Gary Lee tire rack lift south african grill big brakes rhein alloy 15 BFG AT 617 gears ShadyBoy awning 140 watt rear 85 watt front solar mppt truckfridge automatic fire extinguishing system - 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley - Dodge 4500 4x4- 1987 tin top westy Jetta 2.0 ABA 1.8 head, 55 watt solar automatic fire extinguishing system -Just sold my 84 Westy
syncrodoka
syncrodoka is offline
PostPosted: Tue Feb 28, 2012 8:30 pm    Post subject: Reply with quote
These vans are long on the tooth. 25 years is a reasonable lifespan for a rubber o-ring to me. At least the part is readily available and cheap.
SyncroFest Schadenfreude!
Insert every car that i have ever owned list here.
SteelB12
SteelB12 is offline
PostPosted: Tue Feb 28, 2012 8:32 pm    Post subject: Reply with quote
Hmm, maybe its time to finally tackle the maple syrup smell. Hope its only the o-ring
1987 Westy
NZer
NZer is offline
PostPosted: Tue Feb 28, 2012 10:30 pm    Post subject: Re: rear heater Reply with quote
Hahaha, I love "playing" with vehicles!
Be prepared to spend about a whopping $0.63!!!
A handy hint in case you didnt think of it, use 2 pairs of vise grip pliers to gently crimp the hoses so the coolant stays where it should!
Mine was too, and starting to go hard and did break in the end.
Totally agree. Very Happy
Tooharsh
Tooharsh is offline
PostPosted: Thu May 03, 2012 6:15 pm    Post subject: Reply with quote
Does anyone know the diameter of this o-ring?
1984 Vanagon Tin Top, 69,000 miles, Manual Transmission.
73thingsale
73thingsale is offline
PostPosted: Thu May 03, 2012 7:21 pm    Post subject: Same trouble in my tintop Reply with quote
So my tintop had this happen too, and I posted a thread about the subsequent issue of cleaning up the sweet slickness of coolant spilled into the floor, and soaked up by the underlayment panels/boards. They're like compressed or chipboard with rubber backing. And now mine are saturated w/ coolant, and I've laid them in the sun for several days, still when squeeze the edge a little, it just squishes out the slick stuff.
Anybody know a good way to clean and dry these boards/panels out? They're No longer available from any vendor I've found .
Dave
86 GL Hardtop Blue
photogdave
photogdave is offline
PostPosted: Thu May 03, 2012 7:49 pm    Post subject: Re: Same trouble in my tintop Reply with quote
With the floor still in the van I loosened the boards and wedged silica gel packs under them. Then I ran a space heater in there for a couple of days. Seemed to do the trick.
carterzest wrote:
That was such a tight exhaust before that little ditch
89 Syncro GL Westfalia 2.1 WBX
My Westy Movies:
http://vimeo.com/user8267150/videos
DAIZEE
DAIZEE is offline
PostPosted: Thu May 03, 2012 8:17 pm    Post subject: Reply with quote
I tried washing mine but had to throw it out due to squirrel nestings in the parked van back in WA. I put in a floating laminate floor and took out the rear heater (sstored it for next owner if wants)
83.5 Vanagon L Riviera Model with 97 1.9L TD AAZ 4 speed Daily Driver 3 out of 4 seasons (for sale)
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
Mental Health issues affect us all. Ignorance is not bliss. It's up to each of us to educate ourselves.
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
