rmckay Samba Member
Joined: April 27, 2011 Posts: 109 Location: Fairfax, Virginia
Posted: Wed Feb 29, 2012 1:50 pm Post subject: Removing a glued-on rear view mirror from windshield |
Does anyone have any tricks for removing a mirror glued to the windshield? After sticking it there 40 years ago, I think it's time for a new one, but I don't want to chance cracking the glass.
Thanks.
Rick _________________ -------------------------
63 California Clipper
"The trouble with quotes on the Internet is that you can never know if they are genuine." --Abraham Lincoln |
hotrod100 Samba Member
Joined: September 07, 2011 Posts: 74 Location: Bullhead City, AZ.
Posted: Wed Feb 29, 2012 2:12 pm Post subject: |
I heat up the outside of the windshield over the area where it's glued with a heat gun first then go inside and heat up the mount the same way. After heating it for a bit you'll want to twist the mount instead of trying to pull it straight out. After it's off use some rubbing alcohol and a razor to clean the remaining glue off of the windshield. _________________ My build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=482400 |
Tony Marconi Samba Member
Posted: Wed Feb 29, 2012 5:26 pm Post subject: |
| Mine has fallen off at least 5 times in the last two years. Driving drunk neighbors home from a party seems to be a surefire way to have it knocked off. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 1914 Location: Downingtown, PA
Roys_Big_Toys Samba Member
Joined: April 30, 2011 Posts: 111 Location: Richmond, VA
Posted: Wed Feb 29, 2012 7:55 pm Post subject: |
I used a 1 inch sharp wood chisel. I put the bevel against the windshield and gave it a little love tap. The sharp point slid right under and it popped right off. _________________ I'd rather be an hour early than 5 minutes late. (Mine)
"Socialism only works in two places: Heaven where they don't need it and hell where they already have it." -Ronald Reagan
Original Meyers Manx
Original Meyers Manx Tow'd
Original 2 sided Meyers Manx Dealership sign. (The Only one known to exist)
Meyers Manx Surf Board #1 0f #100
Custom Meyers Manx Cornhole game |
missionaviator Samba Member
Joined: January 24, 2008 Posts: 171 Location: Belize, Central America
Posted: Tue Mar 06, 2012 12:59 pm Post subject: |
DO NOT just grab it and twist. I've made that mistake. I thought, "It gets knocked off all the time by just bumping it, surely if I just give it a twist it will be ok." One cracked windshield later..... _________________ "There are many brilliant and profound quotes out there....but this isn't one of them"
Daily drivers:
Manx 2 with Mexibeetle/Thing guts
'98 Mexibeetle for the wife
Murphy Rebel kitplane |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 10064 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Mar 06, 2012 6:20 pm Post subject: |
Any other time it would just fall off..... Maybe a sharp rap with heavy object from side would do it...
Dale _________________ Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
ccbuggy Samba Member
Joined: August 28, 2009 Posts: 154 Location: Cape Cod, MA
rmckay Samba Member
Posted: Thu Mar 15, 2012 6:06 pm Post subject: |
Ok, so after all that, when I took the windshield off to replace the bottom gasket, I leaned it against the back cushion on our sofa, tilted it forward to work on the gasket and the mirror fell off. There must have been just enough pressure on the bottom sofa cushion to make it pop. Go figure. _________________ -------------------------
