Any Solidworks aficionados out there?
Island Bumpkin
Island Bumpkin is offline
PostPosted: Mon Mar 17, 2014 7:11 pm    Post subject: Any Solidworks aficionados out there? Reply with quote
I'm working on a project for my entry level solidworks class in college, and the project I chose I'm finding reaches out what I know of the program.
What I'm trying to do, is make a basic model of a sandrail chassis/frame. I started with what I know, basic sweeps along a path. But there has to be something that I can do that works better.
Any help is appreciated
-Jameson
Vehicles:
1971 Baja Bug, 1600dp, summer/winter/summer project
Follow my progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=556996
1988 F250 SC/LB 7.3 IDI/ZF5/Dana 50 front, Sterling 10.25 rear. 4" lift -Daily-
1976 F250 Reg cab/LB Stock 300/NP435/NP205 -Long Term Project-
Axitech wrote:
My rail is basically my "I can't take civilized life anymore this month, so I'm going camping" vehicle
risk
risk is offline
PostPosted: Tue Mar 18, 2014 6:17 am    Post subject: Reply with quote
There are some solidworks models on here that you could use as a guide:
https://grabcad.com/library?per_page=20&query=vw
For tubing, I would use the "thin feature" on your sweeps.. and assign a thickness based on the gauge. 14 gauge tubing is .083" and 12 gauge is .109" thick. Uncheck "merge result" when extruding features into other features if you want to show an edge for welding.
I built a turbo header for my bug, started modeling it in solidworks but never finished it up.
really-whale
really-whale is offline
PostPosted: Tue Mar 18, 2014 1:54 pm    Post subject: Reply with quote
Another option is to use 'Weldment' features, although I'm not sure if this is only included in the Sheetmetal add-on to Solidworks.
Create a 3D sketch of the sandrail frame and then use weldment to assign lines in the sketch to a particular tube section. Solidworks probably has a few types of tube predefined in its library or you can create your own. Like Risk mentioned about not using "merge result", you will have the same option when using this feature. You can then use 'Trim/Extend' features to clean up unruly junctions.
If this doesn't make enough sense to get started, the Weldmente tutorial within Solidworks is quite good and might have enough detail to get you on your way.
Pete - '67 Aust. RHD Squareback - Build Thread - Engine Thread
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
