Robertjm Samba Member
Joined: May 22, 2011 Posts: 254 Location: San Francisco Bay Area
Posted: Sun Mar 04, 2012 5:42 pm Post subject: Front seat tube clip metal thickness? |
HI all,
I've got to rebuild my front seat, and included in that process is going to be replacing sever broken clips. These are the ones that are on the tubing, which have points that you poke through the seat cover, and hammer over to grab the bottom string/wire.
Yes, I know I could pretty much use any size I want. However, I'm going to be riveting, not welding, so I'd like to use as thin a metal as I can get away with, but still have the strength like the original.
Does anyone know what the actual size of the original metal? I'm assuming it's something betwen 16-20 gauge. However, that's only a guess.
This is on a 1967 Double Cab, which has the 1/3-2/3 front seat.
Thanks!!
Robert _________________ 1967 VW Double Cab Pickup
1995 Saab 900SE Turbo Convertible
1972 VW Squareback (Autobahn in the Sky) |
exciter  Samba Member
Posted: Sun Mar 04, 2012 9:27 pm Post subject: |
Robert,
I just cut out and welded in about 25 of them last week for a set of double cab seats. I used 18 ga which is pretty close to factory if not spot on? Not real sure but the 18ga worked out great.
Good luck and let us know how it ends up! _________________ Joe
Vintage Metal Werks
419-236-9781 |
Posted: Sun Mar 04, 2012 11:13 pm Post subject: |
Thanks Joe! I kind of figured it would be about 18g after looking at some stock at the local Orchard Supply Hardware, which had 16g and 22g stuff only.
Robert
| exciter wrote: |
Robert,
Good luck and let us know how it ends up! |
