my59 Samba Member
Joined: August 13, 2003 Posts: 1763 Location: connecting the dots
Posted: Tue Mar 06, 2012 12:31 pm Post subject: |
Thanks-
I like the pipe cleaner action- makes me think a brass bore brush cut down tied onto the wire might be useful as well. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'83 MB 300CD, '89 MB 190 2.6 5 speed, '93 Volvo 240, '68 Volvo 144s and yeah, '01 NB turbo |
55reasons Samba Swamp Cooler
Posted: Tue Mar 06, 2012 12:51 pm Post subject: |
| my59 wrote: | Thanks-
I like the pipe cleaner action- makes me think a brass bore brush cut down tied onto the wire might be useful as well. |
yeah, I just didn't have one that day.
Make sure it's not going to snap off and get jammed in the line though! _________________ 55 RHD CKD Käfer
50 BMW R25
WTB:
Allstate single wheel trailers and/or parts |
Vanhag Samba Mortician
Joined: June 29, 2003 Posts: 2733 Location: Desert Coast
Posted: Tue Mar 06, 2012 2:16 pm Post subject: |
| blankmange wrote: | | can't you use old gas up to about 4 years old or so? |
20 posts later and noone has commented on your post. I guess the days of Jakub Kaminkski are dead and buried.
Still, I used to run all old gas through my '74 Ford truck, it never noticed. But at 6 miles to the gallon I don't think it cared if you fed it turpentine. _________________ CU05
HOODRIDANCE
So long HBB
Russ Wolfe |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 9915 Location: Sandpoint, ID
Posted: Tue Mar 06, 2012 2:44 pm Post subject: |
| Vanhag wrote: | | blankmange wrote: | | can't you use old gas up to about 4 years old or so? |
Still, I used to run all old gas through my '74 Ford truck, it never noticed. But at 6 miles to the gallon I don't think it cared if you fed it turpentine. |
I missed his post somehow.
Old gas is a relative term. If it's seven years old, probably not. If it's one year old, maybe, If it has had some sort of fuel treatment.
Four year old fuel would likely be straight gasoline and not ethanol blended, and may be OK to run if mixed with some fresh fuel. I would not run it in a VW, but as was mentioned above, an old truck or lawnmower wouldn't mind. The exhaust will likely smell like varnish, though. _________________
| Olddog52 wrote: | | horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound. |
my59 Samba Member
Posted: Tue Mar 06, 2012 3:29 pm Post subject: |
My bug sits all winter long every year and has been doing so since I got it. It sits for maybe 5 months at a time; I've never had an issue with gas- but I also use a lead additive in the gas, which I think has some effect on the gas.
Nothing I own sits for more than a winter at a time without being driven or run. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
The Gonif Samba Member
Joined: July 28, 2005 Posts: 6 Location: Orange County, CA
Posted: Mon Mar 12, 2012 3:50 pm Post subject: |
Thanks for all the information everyone! I learned a lot reading through your replies. It sounds like I should drain and replace the gas, and I'll add some carb/fuel line cleaner, too. And replace the fuel filter. And I'll look into checking the state of the fuel lines for gumminess/degradation, but that might be above the scope of my know-how.
As far as the type of gas, well, I live in Southern California so it's just whatever gas they had at the station 1 1/2 years ago. I don't own a lawnmower and we're not allowed to burn leaves here, but there is a hazardous waste disposal facility not too far away so I'll pay them a visit.
Thanks again, you guys are great. |
KopfenJager Samba Member
Joined: December 09, 2011 Posts: 586 Location: Oregon
Posted: Fri Mar 16, 2012 2:06 am Post subject: |
| Most problems with ethanol gas come from old gum and crud in the fuel system that gets cleaned out by the ethanol. It is a corrosive. New cars almost never have problems because the are still clean. Most new engine problems are from people who let there boats or lawnmowers sit all winter with fuel in thebowl. You should not let ethanol gas sit more than a few weeks the ethanol starts to fall out of the fuel and obsorb water that leads to scaling on metal surfaces. If the car was parked and the carbs were not run dry, than you most likely have gum and varnish in the carbs as well as other nasties, BUT if she runs it will most likely clean itself out. If the car starts, than mix in some new fresh fuel, and a fuel systom cleaner like chemtool and run til almost empty, then refuel. Also adding a little stabil helps bring back old gas. But we are talking months here not yrs. You can store fuel without ethanol for yrs in airtight drums and adding stabil helps with this also. Storing gas in a vented gas tank is not a good idea. You should start and run the engine atleast every 3-4wks to keep things moving. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 8707 Location: Portland, OR
Posted: Fri Mar 16, 2012 9:55 pm Post subject: |
Vanhag, don't despair. I will be the first to step upon the soapbox:
"There is nothing wrong with two year old gas." |
