offshores Samba Member
Joined: February 08, 2012 Posts: 1085 Location: So Cal
Posted: Sat Dec 07, 2013 5:09 pm Post subject: |
I finally decided to go this route with the defrost tubes. Left side will get the same.
grandpa pete Samba Member
Posted: Tue Jan 14, 2014 10:00 am Post subject: |
I used a 1”x12” piece of copper pipe where id is 1” and od is 1 1/8” OSH part # 0000685768275763 $5.79
The piece that slipped into the heater channel is listed on the receipt as “wrot copper bushing”
And is 1 1/8” id and 1 ¼” od (small side) 1 1/4” id and 1 3/8” od (large side) #0000685768203476 $6.19
The piece that is on the top of the 12” pipe that connects the blue hose is called a 1” CXC roll stop with id of 1 1/8” # 0000032888006669 $3.99 the rolls make the od 1 3/8”
The blue hose is from HD # 1000-023-013 HRPSP25 <A> 1 ¼" id x 25 pool and spa hose. $3.64/ft. I got 4.5’
I also used but forgot to photo or mention was “Solder-It Solder Paste” Ebay for about $7 per small syringe. I applied around “wrot copper bushing” and heater channel. Used torch and it soldered it to the heater channel. POR putty was to water seal and add a little extra strength. After a few days I beat on it with a hammer and it didn’t budge. Also, the roll stop has solder inside of it and once you slip it onto the pipe just hit it with the torch and it is now soldered to the pipe.
I got this idea from Aynthm:
http://www.thesamba.com/vw/forum/viewtopic.php?t=442479&highlight=defrost+tubes |
Posted: Tue Jan 14, 2014 10:24 am Post subject: |
A little update.
Bought some bumpers
GoHeels72 Samba Member
Posted: Tue Jan 14, 2014 6:46 pm Post subject: |
Looking Awesome! Continue to take your time. It took me 5 years to do my 65 and I just finished it about 3 weeks ago. I just bought a 63 Ragtop for my next project. The steering wheel is trashed. What did you do to restore that steering wheel? It looks great! Keep up the good work. _________________ Restored/Custom 1965 Beetle
Current Restoration - 1963 Ragtop |
Posted: Tue Jan 14, 2014 7:38 pm Post subject: |
Thanks. I wish I had more time to get after it. Check out this link:
http://www.thebugshop.org/bsfqstrg.htm
I used a dremel with a cutoff wheel to open up the cracks. Filled with POR 15 Putty and sanded with 120, 220 and 600 grit. I primed with some Rustoleum Plastic Primer. Found imperfections, added more putty, sanded again, primed and repeated until I was satisfied. The finish coat is Rustoleum Appliance Epoxy in white. That stuff is great btw. It seems like it will be last a while.
Good luck |
1965VWBUGGER Samba Member
Joined: March 10, 2013 Posts: 212 Location: Sedro Woolley, Washington
Posted: Thu Jan 16, 2014 3:48 am Post subject: |
Good progress man! have to remember that trick if/ when I get around to pull the body off the pan, the way copper is priced anymore you just added serious value to the build. Nice score on the bumpers! _________________ 1965 VW Beetle Project "SIX5BUG" now Zaney"s Rally Racer
2011 VW Golf TDI DSG Malone Stg 1.5 (Traded)
2013 VW Tiguan 4 Mo 2.0 TFSI. APR Stg 1.5. Aka Iggy |
Posted: Sun Jan 19, 2014 7:09 pm Post subject: |
Almost done with the hinge pillar.
obfuscurity Samba Member
Joined: December 01, 2012 Posts: 320 Location: Westminster, MD, USA
Posted: Tue Mar 11, 2014 10:44 pm Post subject: |
GoHeels72 wrote: |
Looking Awesome! Continue to take your time. It took me 5 years to do my 65 and I just finished it about 3 weeks ago. I just bought a 63 Ragtop for my next project. The steering wheel is trashed. What did you do to restore that steering wheel? It looks great! Keep up the good work. |
Chris Vallone did a nice video on restoring these old steering wheels.
http://www.youtube.com/watch?v=DEQ-WBHfuwU _________________ 66 Sedan L456 "Ramona" |
Posted: Mon Mar 24, 2014 7:26 pm Post subject: |
Time sure does fly. Well, since Jan 19th I've only managed to get an old muffler sandblasted and painted along with my steering column tube and signal switch. Cleaned up some hardware and got a red horn button and nice horn bar. Woo hoo, major progress right there!!!
The past few weeks though I've been in the garage working on my hood, deck lid and fenders. Getting those things ready for primer...
Posted: Sat Apr 05, 2014 6:49 pm Post subject: |
Posted: Sun Apr 13, 2014 6:45 pm Post subject: |
Fenders got sandblasted to get most of the paint and surface rust off. The rears got DA’ed with 40 grit to get the rest of the stuff off. There was still some light rust in spots, mainly on the insides so I brushed on some Jasco and let it sit for a day. Today I rinsed them off with hot water and soap then dried and finally primed. Front fenders got a few sections welded up, but still need more attention before any filler and prime.
Posted: Tue Apr 15, 2014 6:35 pm Post subject: |
Posted: Sun Apr 27, 2014 3:13 pm Post subject: |
Doors got sandblasted on the insides, outer edges, hinges and all the hard to reach places. Sanded the outside big panel on doors down to bare metal and applied a skim coat of filler, blocked and primed.
kidosteele Mr. Butthurt
Joined: July 14, 2004 Posts: 116 Location: Saint Petersburg, FL
Posted: Mon Apr 28, 2014 7:25 am Post subject: |
Wow this is coming along nicely... gives me encouragement to get back on my 65.. |
Posted: Mon Apr 28, 2014 4:52 pm Post subject: |
Thank you. It's literally coming along one piece at a time. Good luck with your 65 and let's see some pics. |
Posted: Sat May 03, 2014 7:19 pm Post subject: |
The plan today was to finish body working the front fenders and prime, but instead I decided to fit the front apron and mock everything up. Glad I did because the fenders and apron both needed some tweaking. Still need some more, but getting closer. This stuff takes a long time.
toxicavengerintheSprings Samba Member
Joined: July 19, 2012 Posts: 29 Location: North Springs
Posted: Mon May 05, 2014 12:56 pm Post subject: |
That looks great! |
Posted: Tue Jun 03, 2014 5:25 pm Post subject: |
No real progress as of late. Been moving and am in the process of getting settled in to the new place. A few pics right before the move.
Quick question though on aftermarket rear fenders. In the 1st pic, see the point on the left, rear fender where it meets the apron??? Is that the common fitment issue with these? I thought I was getting ahead of the game and sand blasted and primed these prior to test fitting. The ones I took off fit great, but needed more attention than I thought these did. I completely overlooked fitting them. My apron is bent in a little on the left corner so this is the worst of the 2. If I decide to use these how would one go about making them fit properly?
