Wideband Kadron Tuning
Goto page Previous  1, 2, 3  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
UK Luke 72
UK Luke 72 is offline
PostPosted: Thu Apr 05, 2012 3:18 pm    Post subject: Reply with quote
My accel pump squirts if you only look at the throttle and I'm running a good svda so any hesitation is unlikely, I appreciate the eff being less but the difference in rich afr to lean at cruise isn't pennies over here! £1.50 per litre!!!
Btw... Where are the idle jets Embarassed Rolling Eyes
andk5591 Premium Member
andk5591 is offline
PostPosted: Thu Apr 05, 2012 3:52 pm    Post subject: Reply with quote
Idle jets are on the right side of the carb body - abuty 1/2 way down - look for a brass 8mm nut and thats it.
D-Dubya Manx clone - 63 Short pan,1776.
Max - 73 standard project at wife's request and your gonna die when you see this one.
UK Luke 72
PostPosted: Wed Apr 11, 2012 11:51 am    Post subject: Reply with quote
right, I've been having a play. I've got 130's and 55 idles in at the minute. here's a quick couple of videos Rolling Eyes
Here's a steady cruise at 40mph
and here's idle and takeoff.
I'm thinking i need to come down on the idles a fair bit first then the mains may come about right.
Am I heading the right way?
Thanks!!!
UK Luke 72
PostPosted: Thu Apr 12, 2012 3:59 am    Post subject: Reply with quote
Anybody?!
modok
modok is offline
PostPosted: Thu Apr 12, 2012 7:24 pm    Post subject: Reply with quote
If your asking which direction to try first, I think it definitely would be to try a step leaner, and see how it reacts
Tuning carbs sometimes takes a few days, either you've been thinking about it for months or you left out a lot of details. I like details
UK Luke 72
PostPosted: Thu Apr 12, 2012 10:36 pm    Post subject: Reply with quote
Ok what info do you need modok?
modok
modok is offline
PostPosted: Fri Apr 13, 2012 12:47 am    Post subject: Reply with quote
Just giving you a hard time bro
Would be good to say what combinations of jets you have tried and how it ran with this and that, that wideband is a very useful tool but what you can do is still limited by what the engine will tolerate.
You'll never know the limits if you don't "provoke" it a little Wink
UK Luke 72
PostPosted: Fri Apr 13, 2012 12:19 pm    Post subject: Reply with quote
Gonna drop some 125's in later on... See what she thinks to that.
I'm amazed at just how little the mixture screw does, I thought it proportionally adjusted the afr across the idles and mains. By the looks of things it only SLIGHTLY impacts them but really leans out the idle... I think 20:1 is to lean though!
UK Luke 72
PostPosted: Fri Apr 13, 2012 1:54 pm    Post subject: Reply with quote
125 mains
55 idles
13:1 WOT
12.5:1 cruise
18:1 idle
Gotta get some 50 idles!!!
[email protected]
john@aircooled.net is offline
PostPosted: Fri Apr 13, 2012 2:01 pm    Post subject: Reply with quote
the idle mixture screw adjusts idle mixture ONLY. Light throttle A/F should be adjusted with the idle JET (not the mixture screw). Make changes "2.5" at a time, not 5. 5 is too much.
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net
UK Luke 72
PostPosted: Fri Apr 13, 2012 2:09 pm    Post subject: Reply with quote
I'm not blessed with an abundance of jets this side of the pond though John :/
I've got my hands on
1x 127.5,
4x 130's,
2x 125's,
3x 55's,
2x 60's.
From what I can gather though PICT series carbs didn't come with 50 idles Sad
Thanks for your input John!
mharney
mharney is offline
PostPosted: Fri Apr 13, 2012 2:27 pm    Post subject: Reply with quote
The more the throttles are open at idle, the less the mixture screws will do to affect idle quality. This is even more the case when you have a balance tube.
UK Luke 72
PostPosted: Fri Apr 13, 2012 2:36 pm    Post subject: Reply with quote
I'm not sure what you mean...
I have a balance tube fitted.
UK Luke 72
PostPosted: Sun Apr 15, 2012 11:05 am    Post subject: Reply with quote
Didn't realize you sold jets John...
Can you help me out?!
mharney
mharney is offline
PostPosted: Sun Apr 15, 2012 11:26 am    Post subject: Reply with quote
Look at how the idle speed works. The screw positions the throttle plate. More open means more air. It also means you are exposing the progression holes that supply fuel in low throttle conditions. Balance tubes tend to require that the throttle is open MORE for the same idle speed than setups that don't use the balance tube. This means that more fuel is being delivered by the progression circuit and less by the mixture screw port, and the effects of the mixture screw become less definitive.
UK Luke 72
PostPosted: Sun Apr 15, 2012 11:57 am    Post subject: Reply with quote
So are balance tubes even a good idea for a DD?
modok
modok is offline
PostPosted: Sun Apr 15, 2012 12:32 pm    Post subject: Reply with quote
The balance tube will make it run more evenly on all four cylinders in lower rpm part throttle conditions, which can be good
With more radical cams the idle may be better without the balance tube, symmetry be dammed
UK Luke 72
PostPosted: Sun Apr 15, 2012 12:42 pm    Post subject: Reply with quote
Thanks modok, my cam is rather mild so I'll keep the balance tube!
UK Luke 72
PostPosted: Tue Apr 17, 2012 11:23 am    Post subject: Reply with quote
OK so an update...
125 mains
50 idles
13:1 WOT
17:1 idle
14:1 cruise
should i go down another on the idle?
also...
check out my plug colour after 5 minutes of idle
the one on the left was cool to the touch, the one on the right was almost too hot to hold. is this just due to the odd idle characteristics of Kads?
and...
these are the jets I'm using, out of 30 PICT3 carbs, they're slightly different but from what i can gather they're identical if you get me...
can you see any potential issues here?
much appreciated!
modok
modok is offline
PostPosted: Tue Apr 17, 2012 11:43 am    Post subject: Reply with quote
If it still drives ok with those idles looks like you could try a step smaller yet.
Reading 17 at idle is pretty lean, did you re-adjust the idle mix screws since changing the jets?
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 3
