henry roberts Samba Member
Joined: February 24, 2003 Posts: 712 Location: australia
Posted: Sun Mar 11, 2012 11:44 pm Post subject: amps/watts for driving lights? |
i was wondering how many amps i will have available to run the headlights and driving lights. if you can give me a figure for watts of lighting that would be even better .
i will be running a 35A 12V generator, a warm 1200/1380 engine with a bosch blue coil. looking for the amount available with tail lights, brake lights, wipers and blinkers on.
thanks.
henry.
a very rough mock up of where i'm heading.
or if i have the amps more like
Shadd Samba Member
Joined: January 18, 2007 Posts: 863 Location: Athens, Ohio
Posted: Mon Mar 12, 2012 9:38 am Post subject: |
Use the Wav formula.
Watts = Amps x Volts
35A x 13V = 455W (although the battery is called "12V" working voltage of the gen is ~13V)
Headlights = 126W (both high beams + markers)
tail lights = 16W
brake lights = 42W
wipers = ~100W(guess due to them having an 8 amp fuse)
blinkers = 16W
Ignition coil = ~40W
Total = ~340W
Headroom = ~ 115W
So you can run two 55W driving lights. Just keep in mind that 35 amps is just a rating. Real world numbers depend on engine RPM. Also the generator does not have a 100% duty cycle so pushing the limits 100% of the time will not end well. _________________ Athens Euroworks
Service - Repair - Parts
Specializing in VW/Audi/Porsche/BMW/Mercedes
11 Hudson ave. Athens, OH. 45701
(740) 707-6210 |
slalombuggy Samba Member
Joined: July 17, 2010 Posts: 3727 Location: Canada 306
Posted: Mon Mar 12, 2012 10:56 am Post subject: |
| thanks. |
beetleseb Samba Member
Joined: November 09, 2006 Posts: 315 Location: Cheltenham UK
Posted: Tue Mar 13, 2012 5:00 am Post subject: |
I think the windscreen wiper may be a bit lower
its def worth popping a meter across and measuring the resistance. Then use V=IR to work it out
This is especially useful if your using a voltdrop to run your ww's as you can measure across the two and take that into your calc.
I love the look of the 4 lights. Def worth looking at lower power bulbs/leds or something clever like twin batteries and a management system to let you run them.
Seb _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
Kapt. Q Samba Member
Posted: Tue Mar 13, 2012 12:37 pm Post subject: Re: amps/watts for driving lights? |
| henry roberts wrote: |
You are lucky, here in the UK, and I believe the US, more than four lights on at once at the front is not legal on public highways.
Cheers! |
Posted: Tue Mar 13, 2012 3:54 pm Post subject: |
in my state you aren't allowed to have more than 6 forward facing lights (twin headlights = 4 lights but we have no problems there ) i have never looked into the legalities of how many can be on at once... |
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 489 Location: Vancouver WA
Posted: Thu Mar 15, 2012 5:41 pm Post subject: |
This is a great link, thanks Brad.
Mike _________________ Jackpot motorsports |
Rome Samba Member
Joined: June 02, 2004 Posts: 3303 Location: Pearl River, NY
Posted: Sat Mar 31, 2012 9:33 am Post subject: |
I also have driving lamps on all of my VWs (see a few of my gallery photos). For low-current draw, I'm interested in these:
http://www.superbrightleds.com/cgi-bin/store/index...H3-WHP.htm
They would allow you to run the additional 2 lamps with your generator. If you do pursue the 2 lamps on the hood, you probably know to add some sturdy reinforcing metal plates on the underside of the hood so that the lamps do not shake during normal driving.
BTW I drive with my headlamps on all the time in my VWs as well as my modern daily driver, after being hit by a Jeep in '88 who claimed he never saw me in the next lane.  |
dandand  Samba Member
Posted: Sat Mar 31, 2012 10:12 am Post subject: |
In 1961 a buddy and I found some 6 volt aircraft landing lights rated at 100 watts each. So naturally we hooked them up to our cars - his was a 1958 VW, mine was a 48 Chev. Both 6 volts. We used relays, 10 ga wire, etc. Did the job right!
We noticed right away that the other lights dimmed noticeably when these babies were turned on! So we split them - 2 switches and 2 relays. The RH light was wired thru the Hi Beam, and was aimed down the center of the road. Obviously this side was used sparingly, like on deserted country roads.
The LH light was aimed down the right side of the road, and was aimed toward the RH curb, not too far down the road. We reasoned that we could use this on the freeway as long as we didn't get too close to anyone in front of us.
The night we did the testing and aiming, the local police were called due to a complaint from the girls college across the athletic field we were using. Needless to say, the police were not impressed, and pointed out that there was a limit to the brightness allowed on the highway. We got by only because we rarely used them, and then only for a few minutes at a time. Now you see pseudo off road racers with 4 and even 6 lights equally as bright.
If you haven't already thought of this, I suggest you use a separate headlight relay for each pair, rather than running all current directly thru the switches. Use healthy sized wire, solder the connections, and check the power leads for hot spots at the connections, etc.
Just my 2 bits worth.
Dan |
