Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
bwaz Samba Member
splitjunkie Samba Member
Posted: Wed Mar 14, 2012 5:07 pm Post subject: |
the 802 is the only manifold that was used during actual production so that is the only correct one if you are going for factory orignial. The 701 was a later 25hp replacement (glad to see my thesis about the 701 is taking hold ).
The 802 was the replacement manifold for the older jacketed and non jacketed K manifold up until at least the middle of '55 so the 701 had to have come some time after that.
The 701's will have an E but it has been ground off.
the 701E is a garden variety 36hp manifold _________________ Chris
Posted: Wed Mar 14, 2012 5:46 pm Post subject: |
splitjunkie wrote: |
the 701E is a garden variety 36hp manifold |
In all my years of building these early engines, I have never seen a 25hp (08.02 intake type) used on a 36hp engine upto 1955. I should know this BUT
according to "splitjunkie", the 25hp intake manifold was used upto 1955?!?!?!? BTW, I did NOT grind any letters off the intake as "splitjunkie" suggests _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Mar 14, 2012 5:51 pm Post subject: |
Mr. Okrasa wrote: |
BTW, I did NOT grind any numbers off the intake as "splitjunkie" suggests |
He's not suggesting that at all. 701's with the E ground off are very common. The factory ground them off. |
Posted: Wed Mar 14, 2012 6:12 pm Post subject: |
nlorntson wrote: |
Mr. Okrasa wrote: |
BTW, I did NOT grind any letters off the intake as "splitjunkie" suggests |
OK. Since he did not mention that the FACTORY ground them off. I read it as I ground off the "E". Thanks for the clarification. _________________
VW www.Okrasa.com
356 www.PreA356.com
Posted: Wed Mar 14, 2012 6:22 pm Post subject: |
Hummm...trying to figure out how the small diameter opening of the 08.02 intake would seal on the later head (1955)
since the boss opening on the 36hp is larger? You can see that gap clearly below:
VW www.Okrasa.com
356 www.PreA356.com |
bwaz Samba Member
Posted: Wed Mar 14, 2012 7:04 pm Post subject: |
8 02 was on my zwitter... and not on 1955 delivered cars....
and I've found John Henry's listing to be dead on...
http://www.zarwerks.com/intake_matrix.htm
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed Mar 14, 2012 7:18 pm Post subject: |
1.125" OD on the end casting for 25hp, and 1.250" OD for 36hp. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Wed Mar 14, 2012 7:21 pm Post subject: |
Mr. Okrasa wrote: |
I think Chris is saying that the 802 was available as a replacement part for 25hp engines until '55, not that it was used on 36hp engines after 25 hp came out. You are right, it could not be used on a 36hp engine, it woudl not seal at the head. _________________ John Henry
'57 Deluxe
'56 Single Cab |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Thu Mar 15, 2012 5:15 am Post subject: |
Always a lot of confusion about these.
And you did not even talk about these exotic birds.
_________________ Master of my domain! |
Posted: Thu Mar 15, 2012 7:13 am Post subject: |
usariemen wrote: |
I just got one of those Carsten, the FINAL intake for my "Intake Museum" collection!! Now I have them ALL _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Mar 15, 2012 7:22 am Post subject: |
johnshenry wrote: |
I just got one of those Carsten, the FINAL intake for my "Intake Museum" collection!! Now I have them ALL |
That one there appears to be on an Oval. How rare are they? |
Posted: Thu Mar 15, 2012 7:33 am Post subject: |
They are hard to find in usable condition, they rot on the inside. The guy I got mine from originally wanted like $800+ for it, but then discovered that it had a pinhole leak inside and would leak between the intake runner and the heat riser. So it is unusable... but perfect on the outside and perfect for a "museum" (don't forget to stop at the gift shop on your way out, gaskets are half off in March!!!). I made him a lowball offer and he took it.
I think I saw documentation some time ago that pointed to '54-'55-ish, so not 25hp. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Mar 15, 2012 8:56 am Post subject: |
These are '54 - early? '55 36hp manifolds. They were so bad they they must have had to recall them because you hardly every see them. As John said, they rust from the inside of the heat chamber. You can see them in the '54 and '55 bug and bus owners manual
These are the optional cold weather climate 25hp manifolds.
Posted: Thu Mar 15, 2012 9:32 am Post subject: |
Let me clarify.
The jacketed K was replaced by the 08.02 (P/N 129 501c) with the introduction of the Zwitter and continued until the end of the 25hp engine in '53.
The 08.02 (P/N 129 501c) is the only correct factory manifold for the Zwitter and '53.
This manifold was the only supplied replacement 25hp manifold until at least 9/55. See these technical bulletins:
Technical Bulletin K1 - Carburetor SOLEX 28 PCI - Optional Fitting. All show and list the Zwitter manifold as the manifold to replace the earlier manifolds. If the 701 had already existed they would have used those because their heat risers didn't rot out.
http://www.thesamba.com/vw/archives/manuals/techbulletins/k1.php
The first one listed was dated 1/53 and the last one listed was 3/55. We don't know if this is the last bulletin, It's just the last one we have access to.
Technical Bulletin M1 - VW Engines This lists the various manifolds and carburetors. the 9/1955 and 9/1957 ones have a lot of valuable info.
http://www.thesamba.com/vw/archives/manuals/techbulletins/m1.php
The 9/55 lists: "Only intake manifold 129 501c delivered as replacement part" for the 25hp engine. So the Zwitter manifold was available as the only replacement manifold at least as late as 9/55 for the 25hp engine.
The 9/57 copy lists: "Induction Manifold spare part No. 111 129 701" as the 25hp manifold spare part. This is the 701 manifold you have. So, the 08.02 (P/N 129 501c) manifold was replaced by the 701 sometime between 9/55 and 9/57 based on the above documents.
The 701 manifold was exactly the same as the current 701E 36hp manifold at the time. The only difference is they fitted them with the smaller 25hp end castings and ground off the E on the jacket casting.
I hope this makes it clearer. _________________ Chris
Posted: Thu Mar 15, 2012 9:48 am Post subject: |
Good stuff Chris, thanks for taking the time to put all that together. _________________ John Henry
'57 Deluxe
'56 Single Cab |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Mar 15, 2012 11:48 am Post subject: |
johnshenry wrote: |
I think I saw documentation some time ago that pointed to '54-'55-ish, so not 25hp. |
here's one on a '54 cutaway engine. i'll check the engine number to verify next time i go to this shop.
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Thu Mar 15, 2012 12:51 pm Post subject: |
I think we need to come up with an official name for the '54 manifold.
To me the center section looks like a pear or a uterus. Perhaps the "lady parts manifold"? _________________ Chris
Posted: Thu Mar 15, 2012 12:55 pm Post subject: |
To me the center section looks like a pear or a uterus. Perhaps the "lady parts manifold"? |
Ohhhhh-kay.
You're not naming the domed oil cooler though. _________________ John Henry
'57 Deluxe
'56 Single Cab |
