PacNorthWesty Samba Member
Joined: February 28, 2012 Posts: 83 Location: Bend, Oregon
Posted: Thu Mar 15, 2012 2:04 pm Post subject: Vanagon turn signal switch w/cruise control 86-91 |
Hey guys,
My cruise control stopped working. The trusty local mechanic/Vanagon guru has narrowed it down to the turn signal switch being completely bad. It's not distributing power to the cruise control.
I need to find a "Vanagon turn signal switch w/cruise control, years 86-91," only problem is, they stopped making that part several years ago.
Any ideas? _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
Find me on Instagram
Find me on Twitter |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 738 Location: Portland, OR
Posted: Thu Mar 15, 2012 2:12 pm Post subject: |
I'm in the exact same position as you. _________________ 87 Westy, 250k 2.4l GW, 16" wheels |
Posted: Thu Mar 15, 2012 2:18 pm Post subject: |
| markz2004 wrote: | | I'm in the exact same position as you. |
Ugh. Hopefully someone can shed some light. _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
insyncro  Samba Member
Joined: March 07, 2002 Posts: 6555 Location: New York
Posted: Thu Mar 15, 2012 2:57 pm Post subject: |
NLA, no longer available new.
Good used is your only answer.
I had them but have been cleaned out by those in need. |
jordauto Samba Member
Joined: August 12, 2011 Posts: 50 Location: Sorrento,BC
Posted: Thu Mar 15, 2012 3:27 pm Post subject: |
| Sometimes the wires break right where the arm pivots.If that's the problem you could pull the wires from the back side of the arm and splice in some new wires.Also I think some of the same year Jetta or Golf cruise switch would be very similar except for the arm. Get one from a pick and pull and cut off the end of the arm where the switch is,wire it up to the harness plug under the column and attatch the switch to the dash somewhere.Until you can get a correct one of course. |
Posted: Thu Mar 15, 2012 3:41 pm Post subject: |
| insyncro wrote: | NLA, no longer available new.
Any ideas at all where I could find one? _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
Posted: Thu Mar 15, 2012 3:46 pm Post subject: |
| PacNorthWesty wrote: | | insyncro wrote: | NLA, no longer available new.
Any ideas at all where I could find one? |
Off a parts van somewhere????
I have spares but own numerous Vanagons all with stock cruise.
Not looking to sell any as I have not been able to find any in good condition lately. |
Posted: Thu Mar 15, 2012 3:47 pm Post subject: |
| Check Bus Depot,website shows them.Good price too.But call and check stock. |
stevey88 Samba Member
Joined: January 16, 2008 Posts: 1129 Location: Fremont, SF Bay Area
Posted: Thu Mar 15, 2012 4:15 pm Post subject: |
I would suggest building a simple circuit to verify that it is indeed a bad switch. Wire up this and test for the cruise function. If you want the resume function, connect another push button between 4 and 2. If the stick is bad, you can use this until you can find a replacement. Remove the steering column cover to access the small 4-pin connector.
[/img] _________________ Steve
87 GL 4 speed
87 Westfalia full camper 4 speed |
Tristar Eric  Samba Member
Joined: July 25, 2004 Posts: 841 Location: Portland, Or
Posted: Thu Mar 15, 2012 11:48 pm Post subject: |
| jordauto wrote: | | Check Bus Depot,website shows them.Good price too.But call and check stock. |
Thank you so much for this I'll be calling them first thing in the morning to check stock. At least it shows them in stock online. Again, truly, thank you. It's very much appreciated. _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 7735 Location: Santa Cruz, CA
Posted: Thu Mar 15, 2012 11:57 pm Post subject: |
The CC stalk has been NLA for some years now and I would be amazed if they actually had any. BD shows many parts that they don't actually have in stock.
Checking your unit for continuity may find a wire problem that can be fixed.
Good luck _________________ SyncroFest Schadenfreude!
Insert every car that i have ever owned list here. |
Posted: Fri Mar 16, 2012 12:40 am Post subject: |
| syncrodoka wrote: | The CC stalk has been NLA for some years now and I would be amazed if they actually had any. BD shows many parts that they don't actually have in stock.
Good luck |
Gotcha. I was afraid of that to be honest. We'll see. Thanks for the info! _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 276 Location: Griffin,GA
Posted: Fri Mar 16, 2012 4:29 am Post subject: |
I have had 3 vanagons and each one had inop cc.All problems fixed by correctly rigging the switches at the brake and clutch pedals. My $0.02. _________________ 1973 Westy
1976 MGB
1984 MB 240D
1990 Westy
2004 Passat GLX |
Posted: Fri Mar 16, 2012 6:12 am Post subject: |
| CessnaJon wrote: | | I have had 3 vanagons and each one had inop cc.All problems fixed by correctly rigging the switches at the brake and clutch pedals. My $0.02. |
95% of all cruise control issues I have diagnosed have also had to do with misalignment of the brake and clutch pedal switches.
I have seen a few broken stalks, but none with any wiring issues.
The system is very basic. |
rsxsr Samba Member
Joined: February 09, 2005 Posts: 4780 Location: Loxahatchee, Florida
Posted: Fri Mar 16, 2012 6:30 am Post subject: |
Less than a year ago, Go Westy had brown ones in stock. A member here had posted it. I bought one then, but don't see them on their website now. Might be worth a call to them. They were brown, which was perfect for me.
I was using a switch from a later VW Jetta, that I purchased from Jason at Greasworks. It was a direct replacement, but the orientation was a little off. You can see it in this image.
 _________________ 1982 Diesel Vanagon Camper with ALH TDI.
1987 Syncro Tin Top. Organ Donor
2011 TDI Jetta Sportwagen. |
speedygeorge Samba Member
Joined: November 28, 2009 Posts: 205 Location: Victoria, BC
Posted: Fri Mar 16, 2012 7:07 am Post subject: |
This was my experience also, |I had several shops looks at it and they said it was everything from speed sensor to pump, it was finally fixed when we adjusted the actuator under brake that kept slipping |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1353 Location: New Hampshire
Posted: Fri Mar 16, 2012 7:45 am Post subject: |
try john hamil @ 802-722-3181 @johns car corner hes in vermont but something like that could be mailed cheaply _________________ currently 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th |
Posted: Fri Mar 16, 2012 10:03 am Post subject: |
| GBA 88West LA wrote: | | try john hamil @ 802-722-3181 @johns car corner hes in vermont but something like that could be mailed cheaply |
Thank you so very much for his name and number, just called him  _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
Posted: Fri Mar 16, 2012 10:04 am Post subject: |
| syncrodoka wrote: | | I would be amazed if they actually had any. BD shows many parts that they don't actually have in stock. |
How right you were! Out of stock!  _________________ Founder of Think Brilliant. Lucky to share my life with two Aussies and a Cattle Dog. Phish fanatic, lover of the great outdoors. -Aviv
