1967250s Samba Member
Posted: Sun Feb 09, 2014 12:27 pm Post subject: |
1. Dual PDSIT's should work fine, albeit with less power than FI
2. As long as you have all the bits, should work very nicely
3. You run the cable around the pulley and up thru the hole under the flap lever, push the lever forward and tighten the cable under the nut and screw. Be sure the rod spring is trapped correctly to pull on the cable, and that the flaps work correctly.
4. I think it has a more gradual ramp |
Tcash Samba Member
Posted: Sun Feb 09, 2014 1:43 pm Post subject: |
[quote="chrisradioman"]
Lee.gh.thomas Samba Member
Posted: Mon Feb 17, 2014 9:53 pm Post subject: |
Hey guys, first post.
I was wondering what is good place to look for a type iv engine? I'm looking to buy a Baja, but I'd prefer not to putter around on 60hp. I also don't want to pay for a $20,000 Jake raby engine, considering I'm looking at under $4k for the car.
Thanks |
SGKent Samba Member
Posted: Mon Feb 17, 2014 10:03 pm Post subject: |
Lee.gh.thomas wrote: |
Thanks |
Just build a nice T1 motor with a descent cam and carbs. In a Baja there is no reason not to make power. You aren't pushing a bus around. BTW - this is a bus forum not a bug forum. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Desertbusman Samba Member
Posted: Mon Feb 17, 2014 10:08 pm Post subject: |
I'm looking to buy a Baja, but I'd prefer not to putter around on 60hp. |
Well then throw a 200, 250, or 300 HP Type 1 in it. That's what a lot of Bajas run. _________________ 71 Superbug
71 Westy |
Pecton Samba Member
Joined: January 17, 2014 Posts: 4 Location: Dunnigan CA 95937
Posted: Mon Feb 17, 2014 10:11 pm Post subject: |
hello everyone,
I'm a first poster,I also an old VW guy and new to type 4 motors.I am in the process of changing a 2.0 litre 79 engine from hydraulic lifters to solid lifters,upon re assembly discovered push rods are too short,what years/motor has the longer push rods,and what other bumps should i look out for ,,..Thanks everyone,Peace and love. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Mon Feb 17, 2014 10:13 pm Post subject: type 4 engine |
X-2 post it in the Hbb-off road forum
that's the dune buggy/Baja bug forum
also, unless you are trying to enter the Baja 1,000 an upright bug engine is cheaper and more inline for weekend off road.
or Go to www.fatperformance.com as Ron & Greg build Winning type 4
off road engines. _________________ V.W.owner since 1967 |
Posted: Mon Feb 17, 2014 10:13 pm Post subject: |
SGKent wrote: |
Just build a nice T1 motor with a descent cam and carbs. In a Baja there is no reason not to make power. You aren't pushing a bus around. BTW - this is a bus forum not a bug forum. |
Thanks for the quick reply. I actually didn't realize it was a bus forum until after I posted, sorry. |
Posted: Mon Feb 17, 2014 10:24 pm Post subject: |
Pecton wrote: |
hello everyone,
Hydraulic lifters take shorter pushrods than do solid lifters.
you may also want to use different springs with the solid lifters, as the hydraulics used heavier springs. |
Pecton Samba Member
Posted: Mon Feb 17, 2014 11:31 pm Post subject: |
Different springs, as in valves spring,=cylinder head removal?=engine removal? OH! holy m |
Pecton Samba Member
Posted: Mon Feb 17, 2014 11:37 pm Post subject: |
would it be the 1.7 that comes with longer push rods(how and where does the 1.8 and 1.9 fit in),in other words,when i go parts hunting,what do i chase. |
Posted: Tue Feb 18, 2014 12:04 am Post subject: |
Pecton wrote: |
Any Type 4 engine with solid lifters. 1.7, 1.8, or 2.0. The pushrods you want will have aluminium shafts instead of the steel shafts of the hydraulic pushrods. They all have steel inserts in the ends. You can also buy steel cut-to-length pushrods which are the way to go if your engine has been stroked or otherwise customized very much. |
Posted: Tue Feb 18, 2014 12:17 am Post subject: Valve Train and springs |
Quite a few vendors to buy the springs and you can also buy Stock pushrods here in the classified too.
I also have a few sets of 1.7 pushrods if you PM me
www.cbperformance.com
www.pelicanparts.com and others have the springs for Solid lifter camshafts _________________ V.W.owner since 1967 |
Posted: Tue Feb 18, 2014 12:23 am Post subject: |
Pecton wrote: |
I've never done it but as far as I know you can change springs with the head in place. Air-hose adapter in the plug hole to pressurize the combustion chamber to keep valves tightly closed.
Also in a real bind you can shove some 1/4" rope in the plug hole and run the piston up tight to compress the rope and hold the valve closed. _________________ 71 Superbug
71 Westy |
1977adventurewagon Samba Member
Posted: Tue Mar 25, 2014 5:21 pm Post subject: |
I picked up a type 4 1.8 liter, L-Jetronic fuel injected engine last weekend that has sat in a old 75' bus for what looks to be its hole life. It has everything it came from the factory with (never been touched) I would like to keep it FI but have never messed with Type 4's before and it has what looks to be a large wiring harness coming off the engine any idea what this plugs in to? And what are some of the major point do you want to trouble with type 4 FI engines , all comments are welcome, looking for all the information I can get thanks
Last edited by 1977adventurewagon on Tue Mar 25, 2014 5:34 pm; edited 1 time in total |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Tue Mar 25, 2014 5:31 pm Post subject: |
Does it plug into the computer near the battery?
(Hopefully your battery tray is in better condition than this guys )
_________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Posted: Tue Mar 25, 2014 5:38 pm Post subject: |
Haven't decided what year bus to put it in to yet I don't know if all modules have this hook up |
RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
Posted: Mon Apr 21, 2014 1:42 pm Post subject: |
I don't understand any of the technical stuff but am I right in thinking that a 1.7L out of a Porsche 914 will work in a '73 bus? _________________ 1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/ |
Randy in Maine Samba Member
Posted: Mon Apr 21, 2014 2:14 pm Post subject: |
It will work, but a 1700 or 1800 for a bus would work better.
Engine letter code would be "CB" or "AW". |
babysnakes Samba Member
Posted: Mon Apr 21, 2014 2:18 pm Post subject: |
RixiesRide wrote: |
I don't understand any of the technical stuff but am I right in thinking that a 1.7L out of a Porsche 914 will work in a '73 bus? |
Yes it will work but not quite as well as a bus 1700. IIRC the cam has a different grind to push the lighter car vs the more torquey cam in a bus. Also it will be a PITA to add oil as the filler is positioned much differently. |
