RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
babysnakes Samba Member
Posted: Mon Apr 21, 2014 4:19 pm Post subject: |
You can say that again and again and again. |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Wed Apr 23, 2014 1:31 pm Post subject: |
Hi, I'm in the midst of adjusting my valves on my type 4, believed to be a 2.0.
My Question is, are the valve adjustment nuts 14mm?
I thought it was 13 mm but it doesn't fit, and 15 mm is too big. Just looking for confirmation. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
buck4eighty Samba Member
Joined: March 18, 2014 Posts: 21 Location: Manitoba Canada
Posted: Fri May 09, 2014 8:14 pm Post subject: |
I have a 74 Safari hightop and am doing a little engine work for the very first time, and I have come across a little line coming out of the right side of the charcoal canister....where in the world does it go? I cannot seem to find anything in the vacinity that it will plug into, and I cannot find any info on line. Any help will be greatly appreciated.
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri May 09, 2014 10:21 pm Post subject: EMISSION hoses from Charcoal Cannister |
The Large hose connects to the air filter housing
The small hose ends up going to the fuel tank and there should be a connection for it on the top of the engine compartment ceiling.
These items are Emission related and NOT engine related. _________________ V.W.owner since 1967 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Fri May 09, 2014 10:44 pm Post subject: |
tootype2crazy wrote: |
Yes. Hydraulic rocker arms and some solid rocker arms on type 4 engines are 14mm on the flats. The adjuster itself is larger as well 10mm vs 8mm. |
Was this a model year/displacement change? Or sloppy mechanics using hydraulic adjusters on solid engines? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
my 74 tangerine westy Samba Member
Joined: October 30, 2012 Posts: 161 Location: walla walla Washington
Posted: Sat May 10, 2014 6:50 pm Post subject: |
how do EMPI 34 epc's work on a type 4? what jets are needed im thinking about some on my 1800 _________________ VW made cars like Walter White makes meth
1974 Westy |
square-to-go Samba Member
Posted: Thu Jun 26, 2014 12:57 am Post subject: lots of great info so far |
i am enjoying learning all the differences in these great motors, now i have a question that has not been covered. when it comes to rocker arms, jake states they always use 1.7 rockers in all their t-4 builds, modified of course with 911 adjusters. my question is what is the difference in 1.7, 1.8, and 2.0 rockers? is it the ratio? the size threads on the adjusters? or just that they are made better? since i am rebuilding my motor for my squareback for the second time due to head failure, this time i am trying to use some better parts.a vanagon block since i like the vertical dipstick and cleaner looking castings, stock 94mm german p&c's, stock 71mm crank, a set of low mileage 1.8 larger valve heads from a 412 wagon, raby 9550 cam, new webcam solid lifters, larger rocker arm studs, chrome molly pushrods, raby heavy duty single springs, twin dell 40's. i have the 1.8 and 2.0 rockers but i just want to use the best i can with this budget build. does any one have a set of 1.7 rockers in there pile of parts they'd let go reasonable? thanks for any help on this. _________________ beer! not just for breakfast anymore!!
71 squareback |
curtis4085 Samba Member
Posted: Thu Jun 26, 2014 5:18 am Post subject: Re: lots of great info so far |
square-to-go wrote: |
i am enjoying learning all the differences in these great motors, now i have a question that has not been covered. when it comes to rocker arms, jake states they always use 1.7 rockers in all their t-4 builds, modified of course with 911 adjusters. my question is what is the difference in 1.7, 1.8, and 2.0 rockers? is it the ratio? the size threads on the adjusters? or just that they are made better? since i am rebuilding my motor for my squareback for the second time due to head failure, this time i am trying to use some better parts.a vanagon block since i like the vertical dipstick and cleaner looking castings, stock 94mm german p&c's, stock 71mm crank, a set of low mileage 1.8 larger valve heads from a 412 wagon, raby 9550 cam, new webcam solid lifters, larger rocker arm studs, chrome molly pushrods, raby heavy duty single springs, twin dell 40's. i have the 1.8 and 2.0 rockers but i just want to use the best i can with this budget build. does any one have a set of 1.7 rockers in there pile of parts they'd let go reasonable? thanks for any help on this. |
You will want to match lifters to the CAM the hardness could be different between webcam and Raby parts. Guessing but maybe Webam does Raby CaMs in which case you should be groovy.
I did te upper valve train upgrades on my 79. Seems to be a good but costlier upgrade. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Thu Jun 26, 2014 11:05 am Post subject: |
this is an NOS kit from raby and as far as i know webcam does his grinds. i am more intersted in if i need these 1.7 rockers or if i can use the 1.8 or the 2.0. _________________ beer! not just for breakfast anymore!!
71 squareback |
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Thu Jun 26, 2014 6:00 pm Post subject: |
I bought the Raby valve train kit and it is a webcam to Raby spec. I also have a 2.0 that I dropped off with Adrian at Headflow Masters last weekend. He has a 30 day wait so I still have time to collect parts for the build and I too wondered what the advantage of the 1.7 rockers were? They would be going in new CS heads from Raby as well. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Posted: Thu Jun 26, 2014 7:03 pm Post subject: 8mm or 10mm valve adjusting screws |
Levi, the problem with 10mm adjusters is valve guide wear and the fact that
with 8mm adjusters you buy Porsche swivel feet adjusters or CB Performance
elephant feet adjusters.
It would be great if someone made 10mm swivel feet adjusters but they don't.
So, to keep your engine in top shape buy a set of 1.7 rockers and have them
prepped for the swivel feet adjusters. they will need to have about 0.060 removed which can be done with a belt sander or an end mill.
or, if all your 10mm adjusting screws have a good surface on them and not
flat spots you could run those also.
Solid spacer kit also for the 1.7 rocker shafts.
10mm adjusters came out with the AW engines 73-74 year. If I remember. _________________ V.W.owner since 1967 |
FL-Beach-Bus Samba Member
Posted: Fri Jun 27, 2014 2:26 pm Post subject: Type 4 in a type 1 bus |
I know this is a rookie post but why do you have to change the fan set-up (DTM) to put a type 4 motor into a type 1 bus? |
Posted: Fri Jun 27, 2014 2:46 pm Post subject: Re: Type 4 in a type 1 bus |
FL-Beach-Bus wrote: |
The T4 engine bay cutout is a very different size from a T1 engine bay. The stock T4 cooling system won't fit at all. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Tue Jul 01, 2014 11:25 am Post subject: |
do i need to run all the mixture pipes on stock solex pdsits what can i block off i have a german bosch 009 that just got proffesionaly rebuil that i am going to run? bone stock 1800cc also can i block off/plug the brake booster vacuum i only have the air mixture pipe stock air cleaner...ect. does anyone have an extra solex PDSIT? need help finding that
1974 Westy |
