thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Mon Apr 20, 2015 6:54 am Post subject: Re: Valve Cover Gaskets |
I've had excellent luck using Indian Head Gasket Shellac on my covers. It smells like death but my valve covers don't leak anymore so...
http://www.permatex.com/products-2/product-categor...und-detail
brainwash wrote: |
Also, not sure if the lip is bent in the area indicated by the arrow.
I've been told that lip was used in the manufacturing process to allow excess paint to drip out easier. I had the same question a while ago and assumed that mine were bent but every set of covers I tracked down had the same sized lip in the same spot.
Remember to always position your covers on the heads with the VW logo facing down! _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
brainwash Samba Member
Posted: Mon Apr 20, 2015 3:38 pm Post subject: Re: Valve Cover Gaskets |
Thanks, I just used the Indian Head Gasket Shellac on my gasket when installing my new Cold Start Valve yesterday.
brainwash wrote: |
thewalrus wrote: |
Interesting manufacturing protocol!
thewalrus wrote: |
Remember to always position your covers on the heads with the VW logo facing down! |
Thanks, Definitely going upside down with the logo from what I was reading on another thread re: valve cover gasket leaks...
http://www.thesamba.com/vw/forum/viewtopic.php?t=602566&highlight=valve+cover+gaskets |
thewalrus Big Jack
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5412 Location: Holland, MI
Posted: Fri Apr 24, 2015 6:43 pm Post subject: |
Yesterday I made the piston oil cooling modification to the rods as per the 1980's VW tech bulletin. Pretty easy to do with a good file if you are careful. Although originally intended for 2.0 bus engines, the modification can be beneficial for 1.7 and 1.8 engines as well. Simple, but effective.
Tech Bulletin drawing:
Left is stock rod. Right is modified with piston oil cooling modification:
Close up of notch:
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
galencurrington Samba Member
Joined: March 16, 2004 Posts: 426 Location: bowling green, ky
Posted: Wed May 27, 2015 10:18 am Post subject: |
i'm working on a 79 auto tranny bus for someone and it's from cali a few years back. i was wondering if there is a way to change out the muffler and stuff so they can run an aftermarket one. i know the 79 cali buses have a catalytic converter i was wondering if i can take it off now the bus is in ky. i have to pull the motor and tranny anyways because the bus has sat to long and all the gas has turned to tar so there is a ton of stuff i have to replace anyways. _________________ "asking and getting are two different things" |
blink Samba Member
Joined: September 07, 2011 Posts: 90 Location: Australia
Posted: Mon Aug 10, 2015 1:40 am Post subject: |
Can anyone tell me what i would be better off with either 36 idfs or 40idfs.
i have a new mild 2l type4 with head work and a nice cam i want a nice driving engine not going to be reving it to high just a nice cruiser. i have both 36s and 40s and looking to build them up to a nice set of carbs but just not sure which set of carbs to go with.
Any help would be awesome
Thanks Matt |
hashwin Samba Member
Joined: May 09, 2015 Posts: 1 Location: Vancouver, BC
Posted: Tue Sep 01, 2015 7:53 pm Post subject: |
Hey y'all....my first post. Thanks for a brilliant site. I sold my neglected (not by me) '79 westy for $1k more than I paid 8y ago ($4500) but it didn't have pointless ignition. I'm left with a '76 westy that only a Canadian mother could love, but it goes along the road fine, and I'm going to give her the love that's needed, including a newer engine and I'm not sure what's in there 1.7 or 1.8 (not orig motor). I'll bet there's a bore/stroke/interchangeability table on here somewhere.....if you could say where or add, even more brilliant. Best regards from Canada! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Tue Sep 01, 2015 8:58 pm Post subject: |
blink wrote: |
Thanks Matt |
Sorry no one answered. If you're not gonna run FI, the IDFs with the CB Performance would be the way to go. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
HolyRoller Samba Member
Joined: May 07, 2015 Posts: 101 Location: Belleville, Ontario
Posted: Sat Oct 24, 2015 7:40 pm Post subject: |
Greetings everyone. My first post in this forum...
I have read through most of the pages of this thread but a question remains...
I have picked up a Type 4 engine. It has a couple of labels/stickers that make IDing difficult.
Can anyone tell me anything about these photos that would help me to understand the size of the engine.
I am a total noob re: Type 4 engines so be gentle. Any questions will be answered to the best of my ability.
Thanks
timvw7476 Samba Member
Posted: Sun Oct 25, 2015 12:22 am Post subject: The Type 4 Engine thread |
Two places to look: 1.right under the eyelet hook in your picture, there will
be a VW # on the cooling shroud.
2.there is the same number(if you're lucky) stamped
into the right case half, it's hiding between the shroud
and the breather tower, just beyond 12 o'clock
position if you stare at the fan itself, there may be
debris in there, seeing as they stamp it on a
near horizontal surface. |
Posted: Sun Oct 25, 2015 3:07 am Post subject: |
HolyRoller wrote: |
Can anyone tell me anything about these photos that would help me to understand the size of the engine. |
Looks like a Vanagon engine to me. The breather isn't the bus style nor is the fan shroud.
The engine is fairly similar to a '79 bus engine in that it has square port heads. To run it and not have to do a lot of fabricating you are going to want to find a set of '79 Federal heat exchangers and a bus fan shroud. |
Posted: Sun Oct 25, 2015 5:25 am Post subject: |
Thank you so much for the replies. I will check those areas for a # later today when I get out to see it again.
With respect to heat exchangers etc., do these pictures help? I assume these are what you are talking about...
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Oct 25, 2015 8:24 am Post subject: |
Vanagon shroud, Vanagon oil filler, Vanagon part number, Vanagon mounts, Vanagon heat exchangers (with the ports sawn off ), if it walks like a duck and quacks like a duck................
I'd be very suprised if it's not a hydraulic valve 2 liter with square ports. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Sun Oct 25, 2015 5:21 pm Post subject: |
It says CV code on one of the stickers. Bottom left corner so that puts it 80-82 air cooled. Rebuilt be VW in the late 90's I would guess. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
Posted: Sun Oct 25, 2015 7:03 pm Post subject: |
Thank you for all the replies. I appreciate the info. I am sort of familiar with Type 1 engines... but a lot to learn re: Type 4.
I have a Type 34 project and debating whether this would fit and if so, whether it is a good idea.
Matt. |
Posted: Sun Oct 25, 2015 7:15 pm Post subject: |
980-83 Vanagon, 2.0 liter, L-Jetronic, Hydraulic Lifter
Apparently, I have this engine sitting in my barn. Really appreciate the help. Hate to be greedy re: help but can someone explain what L-Jetronic is or point me to an appropriate thread so that I can read to my heart's content?
Thanks so much.
I will try to find out as much as I can on my own, but hoping one of the very knowledgeable folks here can shortcut me to a great thread to read.
Matt. |
Posted: Sun Oct 25, 2015 8:15 pm Post subject: |
HolyRoller wrote: |
Thanks so much.
Matt. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=232719
Plus the L-Jet is your basic fuel injection system on the 75-82 buses. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
jtvader Samba Member
Joined: September 12, 2015 Posts: 3 Location: Billings, Montana
Posted: Wed Oct 28, 2015 8:58 pm Post subject: 1.7 liter with single carb |
I just recently acquired a '73 bay window. I understand that these came with dual carbs. However, the p o had installed a single carb. Anyone had experience with this before? _________________ Loved bugs, but I am 6'5'. Going for a '73 bus instead. |
Posted: Wed Oct 28, 2015 9:02 pm Post subject: Re: 1.7 liter with single carb |
jtvader wrote: |
I just recently acquired a '73 bay window. I understand that these came with dual carbs. However, the p o had installed a single carb. Anyone had experience with this before? |
Very common on these rigs. Search for "progressive". |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3851 Location: San Jose, CA
