Nepenthe88 Samba Member
Joined: September 03, 2010 Posts: 1320 Location: Colorado
Posted: Sat Mar 17, 2012 7:22 pm Post subject: Help Identify this Engine |
I'm not sure i'm in the right spot, but I figure this should be an easy set of questions for someone here. Anyway... a buddy of mine has an old rail with an old engine in it. I looked up "engine codes" but nothing I found started with E like this block has. If you could help me solve this mystery, I'd be appreciative!
engine code E 19749
old cast distributor
strange looking tin where the heat exchangers are normally?
and finally a pic of the engine as a whole. It has a 28 pict1 on it, which I assume doesn't match....
Final answer? Is it anything interesting / desirable? _________________ a Black & Blue Su-BUS-aroo
Follow my adventures in the GoWAND'RLoST bus on Instagram:
https://www.instagram.com/gowandrlost/ |
leeezard7 Samba Member
Joined: November 13, 2011 Posts: 262 Location: oklahoma
Posted: Sat Mar 17, 2012 8:03 pm Post subject: |
maybe someone with more knowledge than i on the subject will chime in... but it appears by the engine number its possibly a industrial 36hp from june or july of 1956. the carb and 12v alt are wrong tho. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Mar 17, 2012 9:06 pm Post subject: |
How tight is the fit between the alternator and the generator stand, I did not think you could put a alternator on a 36hp.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Sat Mar 17, 2012 10:01 pm Post subject: |
The engine stamping area has clearly been ground down and restamped.
Probably just a random number some engine rebuilder used in the past.
The distributor and heater pieces are standard Beetle 36hp.
The 28 PICT is technically from a later engine but works fine on a 36hp. _________________ How to Post Photos
