dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Sun Feb 19, 2012 11:34 am Post subject: Oil Level for 30HP engine with Judson and Fram filter |
Guys just refitted my refurbished 30HP engine with a judson & a fram filter. How much oil do I put in as the fram filter will take a certain amount.
thanks for your help |
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 544 Location: Vancouver WA
Posted: Wed Feb 22, 2012 10:15 pm Post subject: |
I would start with 3 qts, run the engine for a bit and let it sit for an hour or or so then check the level and add accordingly.
Hope this helps. Post pix if you have them please.
Mike _________________ Jackpot motorsports |
dave1 Samba Member
Posted: Thu Feb 23, 2012 8:20 am Post subject: Oil Level |
Mike,
thanks for your reply. I'll get some pictures taken at the weekend & post |
Posted: Thu Feb 23, 2012 10:45 pm Post subject: |
Those engines use a bit less than a 1600 I think but correct me if wrong please. That is why I was thinking 3 qts for a base to start with as the larger engines use 2.75 or there abouts. Do you think the filter will hold a full quart of oil in it? I have seen MANY of them but have never had any hands on with that set up, so I am learning a bit myself here.
Flavio Samba Member
Joined: May 14, 2008 Posts: 414 Location: Madeira Island, Portugal
Posted: Fri Feb 24, 2012 4:55 am Post subject: |
Probably 1 liter (1 quart?) is too much...not sure. But, because it's easier to add some more oil than to remove it, do what Bajamike said, except add only half a liter and check the level after running the engine and waiting for the oil to sit.
Just add the necessary to reach a litle more than half the distance between the two marks on the dipstick.
Also, I'm assuming that you already know that it's advisable to have a restrictor at the oil filter inlet in order to mantain a proper oil pressure.
Hope this helps |
dave1 Samba Member
Posted: Thu Mar 15, 2012 3:25 pm Post subject: 1954 original 30HP judson engine top half rebuild |
Only miner problems with start up. Distributor shorting out, replaced fibre washer on the condensor fixing. A leak on the fram filter. Unable to get gasket replacement. Made a 5mm rubber gasket with no leaks!!
Finally finished engine rebuild engine running sweet - Taking car for MOT Saturday & hopefully ready for the volksworld show |
Posted: Thu Mar 15, 2012 5:33 pm Post subject: |
That is a great looking engine, glad you have things sorted out.
Any photos of the car?
dave1 Samba Member
Posted: Fri Mar 16, 2012 5:37 am Post subject: 30hp judson engine |
Mike,
thanks for that & your help with the oil quantity. I'll get some photo's on here over the weekend |
gt78 Samba Member
Joined: November 21, 2009 Posts: 49 Location: Pori, Finland, Europe
Posted: Fri Mar 16, 2012 12:48 pm Post subject: |
Man,
that's sweet shit! I'm drewling over here!!!
dave1 Samba Member
Posted: Fri Mar 16, 2012 2:49 pm Post subject: 1954 RHD Ultra maroon Oval judson |
A few Pictures as requested from the volksworld 2011 show |
D-train Samba Member
Posted: Fri Mar 16, 2012 5:41 pm Post subject: Re: 1954 original 30HP judson engine top half rebuild |
dave1 wrote: |
my seal was gone as well so i used one from a truck oil filter, go to a mechanic an look through the old filter bin an find one to suit.
u can see the difference in thickness, i havnt used it yet, but i blocked off one side and blew through it with the original seal an it had air leaks then put on the other one an did the same trick an ended up lookin like a trumpet player.
just a thought for a seal _________________ shiny paint doesnt make it worth any more |
Posted: Sat Mar 17, 2012 3:54 pm Post subject: |
DROOLING...........
Posted: Sat Mar 17, 2012 3:57 pm Post subject: |
Haha... _________________ shiny paint doesnt make it worth any more |
