rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Sun Mar 18, 2012 7:21 pm Post subject: Review: GW Upper Door Lip Seal |
I bought this little seal kit from GW a couple of weeks ago ($14.95) - installed it this weekend:
http://www.gowesty.com/ec_view_details.php?id=23590
It works! Big difference on the wind noise. I always thought that the noise was due to the defroster and heat vents, as well as the windshield and the doors. What I found is that the sound level dropped significantly for me - to the point that when driving down the freeway, I closed all the vents and could hear just a bit of whistle through the baffles...where as before there was so much wind noise that it just got louder when I closed all the vents.
The other measuring stick for me was that I didn't have to turn up the volume on the stereo as loud as before (when driving down the freeway).
Now I want to find a source for the lower lip door seal that some of the 90/91 models have.
Installation is pretty easy - except that it is very tough to seat the seal between the main door seal and the bent over angle of the door. I found that if I inserted a credit card, pressed down against the main seal and then pushed the new seal in with the other hand/thumb, I was successful in getting the new seal in place. See here:
Let me know if you have any questions. _________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Thebiggestfro Samba Member
Joined: December 23, 2011 Posts: 18 Location: Asheville, NC
Posted: Sun Mar 18, 2012 7:42 pm Post subject: |
I installed this last weekend as well, but haven't actually driven my van yet. This makes me excited to drive it though! _________________ 1986 Westy
2011 Jetta Sportwagon TDI |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Sun Mar 18, 2012 8:10 pm Post subject: |
Cool, nice review and good install tip. Did you use any sealant for yours? I ended up trimming mine a few inches as I couldn't access the lowest part of the seal between the frame & door. |
Posted: Sun Mar 18, 2012 11:18 pm Post subject: |
No sealant. Once in place, the pressure from the main door seal holds in place very nicely. Yes, the seal is longer than you need - I used the GW photos as a guide to where I should stop and trim the seal. _________________ 89 Westy
- John Wooden |
madspaniard Samba Member
Posted: Sun Mar 18, 2012 11:29 pm Post subject: |
the GoWesty link says vans up to 97 did not have this, Rockfish, I thought you had an 89 Westy, was your van missing it or you just replaced the old one? _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Sun Mar 18, 2012 11:35 pm Post subject: |
Missing.
GW doesn't have a replacement.
Any ideas? _________________ 89 Westy
- John Wooden |
Posted: Mon Mar 19, 2012 12:28 am Post subject: |
Sorry, I meant the seal, not the sealant, was your Westy missing the seal? _________________ 1991 Westy auto w/ Peloquin TBD
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Mon Mar 19, 2012 8:37 am Post subject: |
mine wont stay in place i think i need to adjust my doors, i find mine hanging loose inside quite often _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
Posted: Mon Mar 19, 2012 11:41 am Post subject: |
Mad: Yes - missing the lower front door (exterior) seals. I called GW today - the part is definitely NLA. And so far, they have not found a replacement. And I did not have the upper seals either!
BTW - the GW price, believe it or not, is far lower than what other vendors are asking just for the upper seals. Most sites have the upper seals listed for $40+!
GBA: It takes a lot of work to get the seal seated in between the door metal and the existing door seal. Between the credit card and using your thumb to push, you're hands will get a little sore. I found working on sections 1" at a time is best - not to try and do whole thing at once. I had to go back and work on a couple of sections on the first side. Learned my lesson so that the second side has stayed in place pretty well. If it isn't fixed by mid/late July, I'll be at Hedding Camp/Exeter/Portsmouth around 7/20 or so... _________________ 89 Westy
- John Wooden |
Darren2dream Samba Member
Joined: April 12, 2011 Posts: 162 Location: Redwood City, CA
Posted: Mon Mar 19, 2012 8:01 pm Post subject: |
I've been interested in this trim because I love to reduce wind noise but to be honest, I cant figure out how it would go on.
On my 84' the door trim which goes all around the door has a flap that appears to intentionally go over the metal edge that this new trim woud fit on to. Do I need to stuff the original door trim under the metal lip and then put this new one on? Is that were it's suppose to be already and my full door trim not installed correctly? I'm pretty sure the trim I have on my doors is the original... nothing leaks currently. Maybe I dont "need" this additional trim? Of course not but, if it makes it quieter inside, I'd like to give it a shot. Wondering if anyone else was thinking this same thing before I invest $14
here's what my existing door trim looks like:
On each corner, the full door trim doesn't cover the lip, wich makes me think while it covers most of the area, it wasn't meant to go over the metal lip?
Top corner for an example (I know this trim wouldn't cover this area but, it's easy to photograph):
_________________ 84' Wolfsburg Westy GL 1.9 Manual |
shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Mon Mar 19, 2012 8:20 pm Post subject: |
On my 84' the door trim which goes all around the door has a flap that appears to intentionally go over the metal edge that this new trim woud fit on to. Do I need to stuff the original door trim under the metal lip and then put this new one on? |
x2 on that question -- I have the same problem on my passengers side door.
And not to be disagreeable with the review and the GW marketing, but I honestly haven't felt like I noticed a difference in the wind noise with the seal I installed on the drivers side.
That said, I should also mention that I have recently replaced ALL other seals on the drivers side (a HUGE improvement!) and done sound deadening, so it's already fairly quiet. But I can't honestly say I noticed a difference when I installed this. It was also kind of a pain to install, so my satisfaction level is not very high with this project. _________________ 1989 Bostig Syncro Westy |
Posted: Tue Mar 20, 2012 6:17 am Post subject: |
The seal doesn't run around the corners - it only runs on the diagonal side that parallels the wing window. Check the 2 photos above on the white Westy example - the seal starts (top) right at where the bent over edge curves back for the horizontal corner. Then the seal runs to the end of the diagonal run and is trimmed before the edge turns down/vertical by the door hinge.
I'll take pictures today and post. _________________ 89 Westy
- John Wooden |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Mar 20, 2012 8:51 am Post subject: |
Sorry, but I have no idea what I am looking at in the above picture. The others are too small. I have an 82 and I believe my door seal is also overlapping the door seam in front of the vent window. A couple extra pictures would be appreciated. Inquiring minds. _________________ ☮️ |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Tue Mar 20, 2012 9:20 am Post subject: |
rsxsr wrote: |
Sorry, but I have no idea what I am looking at in the above picture. The others are too small. I have an 82 and I believe my door seal is also overlapping the door seam in front of the vent window. A couple extra pictures would be appreciated. Inquiring minds. |
and a slightly better view of the card too, please; I would like to order some parts
just kidding _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Tue Mar 20, 2012 9:49 am Post subject: |
Quote: |
The seal doesn't run around the corners - it only runs on the diagonal side that parallels the wing window |
Yup, I understand the portion of the door this trim is designed for but the existing full door trim on my 84' covers that area already. This makes me wonder if my existing full door trim should be tucked under the door's metal lip for this diagonal area of the door only so that this new trim would have a place to go. Effectively doubling the trim on that one angled side of the door...
I guess I'm thinking that there is little way this new trim would really improve the wind noise much from what's already installed since the existing trim includes a rubber channel that covers the edge of the door already. _________________ 84' Wolfsburg Westy GL 1.9 Manual |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Tue Mar 20, 2012 11:44 am Post subject: |
So let me get this clear, this is the same seal like on the 90/91 vanagons? cause it makes a huge difference if this is something close to replacing those, I want these on my 86 and have a hard time finding donor parts. |
GreenMachineVW Samba Member
Posted: Tue Mar 20, 2012 11:50 am Post subject: |
This seal is on the 90/91 Vanagons, but is not the seal you are thinking of. This seal goes on the diagonal section, and is thin. You are refering to the seal that goes on the vertical section, and is much thicker, and NLA. I have transfered the seal mentioned here from a donor to my 1983 with no trouble attaching it, but I cannot vouch for the sound difference, as I did a few other sound reducing updates at the same time. |
Posted: Tue Mar 20, 2012 12:28 pm Post subject: |
[GBA: It takes a lot of work to get the seal seated in between the door metal and the existing door seal. Between the credit card and using your thumb to push, you're hands will get a little sore. I found working on sections 1" at a time is best - not to try and do whole thing at once. I had to go back and work on a couple of sections on the first side. Learned my lesson so that the second side has stayed in place pretty well. If it isn't fixed by mid/late July, I'll be at Hedding Camp/Exeter/Portsmouth around 7/20 or so...[/quote]
very cool i will try it as you said with a credit card did you use any sealant or adhesive?, hey man drop me a line or PM when you come out this way i live in exeter NH who knows you may need a friendly contact for spare parts, work space or just coffee maybe we can just cruise the beach with the vans ...there are few samba members that live in the area also with varying expertise...safe travels & best wishes _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Mar 20, 2012 1:39 pm Post subject: |
purplepeopleeater wrote: |
Its for the upper, angled portion of the front doors. I just ordered a set, having a big whistle on the PS in that region that's really p*ssing me off. I'll let you know what the effect is. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Mar 20, 2012 1:55 pm Post subject: |
I ordered a set on Leap Day and haven't had a chance to install them. All of my door/window seals are original, so these might make a difference or it might just be pissin' in the wind until I replace everything. For $15 I figured why not.
With this being gale-force wind season in Colorado, I should know pretty quickly. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
