Timwhy Samba Member
Posted: Tue Mar 20, 2012 2:09 pm Post subject: |
Just put these on today. I used contact cement under the little lip that goes between the existing
door seal and the doors edge. Also put some cement on the flat part of the seal where it will make
contact with the upper edge of the door. The seal will block the distance between the door and
the A collumn. I haven't tried out the van yet, want the cement to set first. I used a popsicle stick
with very little contact cement on the small grove and worked it in quickly. Also used a card
but found that my old drivers licence was thinner and easier to use than a credit card?
Hope the pics help? _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
msinabottle Samba Member
Posted: Tue Mar 20, 2012 3:29 pm Post subject: Hmmm... |
Joe, when you've got those in, I might lure you over here for a beer rendezvous, just so I can see how yours turned out. I've ordered 'em for Winston. I was thinking of getting REALLY SERIOUS on the adhesive and using that 3M Weatherstripping Adhesive I used to fix Winston's rear panel. THAT stuff grips and doesn't need a clean surface, and you can get it at NAPA.
The other thought was to use a plastic putty knife, instead of a credit card of any description. Parts ordered to pull Winston's luggage rack, clean, re-seal, and re-install as a preliminary to the new tent.
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Tue Mar 20, 2012 6:52 pm Post subject: |
My original seals are in place.. though worn a bit. No doubt in my mind these doubled seals help reduce wind noise (and drafts).
IIRC, Van Cafe sold this stuff in sections long enough to run from the the bottom of the window up over the top to the back. Thier website said "Cut in two.. One half each side"
Why wouldn't we do that? Use a longer single piece up and over the top corner and all the way back?
For years my passenger side main door seal whistled in cross winds 20mph+.. Replaced that seal and no more noise.. but it seems that this second "double" seal would help along the top, too.
Thoughts? _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Mon Mar 26, 2012 7:25 am Post subject: |
I found some time to get these in this weekend. I used the credit card trick with much success (especially since the credit card really isn't good for anything else.)
While the original seal does roll over the top of the door a bit as mentioned earlier in this thread, when you pull it back and get the card in there, you'll have room to push in the GW seal.
I didn't use any adhesive; once in there, the seal holds tightly without it.
I noticed an immediate difference. In heavy cross winds like we have in Colorado this time of year, I used to get a lot of noise through there; now it's much, much quieter. I can actually hear some wind noise around my window seals now and can tell what else needs to be replaced.
Not bad for $15 and about twenty minutes of work. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Mar 26, 2012 8:46 am Post subject: |
joetiger wrote: |
Not bad for $15 and about twenty minutes of work. |
Thanks for the report - I can't wait until mine get here.
I replaced Dixie's window seals a few years ago - they made a really big difference to highway comfort. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
onslowb Samba Member
Joined: November 20, 2006 Posts: 315 Location: Woodland Hills
Posted: Tue Mar 27, 2012 7:54 pm Post subject: |
I didn't trim the seal at the top and installed the remaining 6 inches or so along the top edge of the door. The seal does make a difference from not having it ....but not sure if it is any quieter than if I had trimmed it though. One thing I did learn is that it helps to wipe the inside of the seal with alcohol or similar where the adhesive goes otherwise the powder that is in there (from the manufacturing process??) prevents the seal from sticking to the door. |
Merian Samba Member
Posted: Tue Apr 08, 2014 4:05 pm Post subject: |
For the Upper Door Lip Seal that goes on the diagonal, did you guys start at the top corner and work down?
or from the bottom and work upwards? |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Tue Apr 08, 2014 5:08 pm Post subject: |
I've installed the passenger side piece of this so far, and I used some stereo installation tools (little plastic pry-bars) instead of a credit-card - although that's a good idea too!
I haven't done driver's side yet, or tried anything, as my van is apart.
It took me about 30-minutes and some sore fingers to get this seated right, and i'm not 100% sure it'll stay in place. I didn't use any sealant/glue (yet). _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Timwhy Samba Member
Posted: Tue Apr 08, 2014 5:23 pm Post subject: |
Timwhy wrote: |
Hope the pics help? |
Its been over two years since this post and they are still on and glued securely as on that day in 2012. _________________ '15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
Posted: Tue Apr 08, 2014 5:41 pm Post subject: |
I didn't use glue, and my driver's side one has become a bit tempermental with age; it comes loose every once in awhile. However, the passenger's side is still hanging in there. I need to glue them; it's worth it. With the driver's side one currently out, I can definitely tell a difference in noise. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Merian Samba Member
Posted: Tue Apr 08, 2014 5:49 pm Post subject: |
Merian wrote: |
hello? |
Posted: Tue Apr 08, 2014 5:51 pm Post subject: |
Merian wrote: |
Merian wrote: |
hello? |
I started from the top and worked down using the credit card method. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Merian Samba Member
Posted: Tue Apr 08, 2014 5:53 pm Post subject: |
Thanks much! |
BlueGrasser Samba Member
Joined: August 27, 2014 Posts: 562 Location: Sacramento
Posted: Thu Nov 20, 2014 11:37 am Post subject: |
So what was the verdict on these seals. A see a couple posts saying big improvement, at least one saying none at all, and quite a few that were going to report back and never did.
Now that I'm not fixated on the sound of my transmission killing itself, I'm noticing that most of my wind noise seems to come from the upper portions of the doors. I'm thinking of throwing a set of these in on my next order. _________________ Going to where the grass is bluer...
1985 Vanagon Westfalia Camper with 1.8T |
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Thu Nov 20, 2014 12:03 pm Post subject: |
I have an '89 with these seals from the factory and an '85 without and the wind noise difference is significant. Granted, my window seals may not be as good in the '85 and the '89 has insulation in the back that the '85 doesn't but still, it makes a difference! _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
Darren2dream Samba Member
Joined: April 12, 2011 Posts: 162 Location: Redwood City, CA
Posted: Thu Nov 20, 2014 12:05 pm Post subject: |
I put mine on two years ago, a few months after I put in new window seals all around.. I think I could take them or leave them without noticing.
That said, if you've identified wind noise from that area, try the seals, they wont likely make it any louder... _________________ 84' Wolfsburg Westy GL 1.9 Manual |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17121 Location: Retired South Florida
Posted: Thu Nov 20, 2014 12:32 pm Post subject: |
I don't think I would miss mine. I did not notice any real difference, but seemed like a good idea at the time. If you want to test your window area, put some masking tape to mimic the seal on both sides and climb in through the sliding door. Take it for a road test and see if the tape makes a difference. If so, then you might see an improvement adding this seal. _________________ ☮️ |
Solrider Samba Member
Joined: April 27, 2011 Posts: 199 Location: Phoenix, AZ
Posted: Fri Nov 21, 2014 12:48 pm Post subject: |
I bought these several months ago and when I went to put them on my van I didn't realize it was an additional seal to the one already on there! Guess I'll be attempting this project again this weekend. _________________ Heidi - KF7CKI
85 Vanagon GL 1.6NA - Otto Von Wunderwagen
Gone but not forgotten:
71 Super Beetle - Gretel
92 Jetta GL - Jerry
97 Passat TDI - Penny |
Posted: Fri Nov 21, 2014 1:12 pm Post subject: |
Well perhaps I am just hearing newer window and door seals and attributing it to the upper seals making the difference in my vans. _________________ ---------------------------------------------------
