Jockomo Samba Member
Joined: October 11, 2006 Posts: 138 Location: Lafayette, LA
Posted: Mon Mar 19, 2012 6:25 pm Post subject: |
After closer inspection I found this port welded closed on one of the heads.
If I remember correctly it's something for FI. Head temp sensor mb?
I guess that answers my question about FI for now.
Otherwise I think the bus itself has the FI tubes on the fuel tank, along with whatever the lines are that runs up the side corners of the bus. Figuring out what to do with those is on my list of things to do. I'm pretty sure the bus was set up for FI originally. In fact it also had air conditioning. You can part of it sticking out under the bottom.
You're right thewalrus, the bus is not of US origin, it was originally purchased in Germany and somehow brought to the states. From what I understand the couple that owned it was traveling around the states and it caught fire on I-10 outside our town (what a heartbreak). I have the original german plates and it has some other cool things, I'll post more pics soon.[/img] _________________ '75 Westy with '78 2.0L engine. |
vw76westy Samba Member
Posted: Tue Mar 20, 2012 12:09 am Post subject: |
the head temp sensor hole is clear
and even if it was welded you would still be able to do fi
the cost of fi.....
your looking at $300-$500 in good used parts
and another $200-$400 in new parts,gaskets,fuel line,etc....
you could buy a fi system for $100-$300
then spend a few extra $$$ to replace
bad or missing parts
if your willing to go fi
& want something thats "turn key"
i will help you put together a fi system
used parts that have been cleaned & tested along with some
new/rebuilt parts like injectors
ill give you the harness,afm,brain,sensors,etc........
and a list of all the new stuff youll need like
intake boots,fi rated fuel line,& o-rings for the injectors
plan on spending around $750 _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1449189
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
1FUNBUG Samba Member
Joined: June 29, 2004 Posts: 577 Location: Orlando, FL
Posted: Tue Mar 20, 2012 4:21 am Post subject: |
| vw76westy wrote: |
plan on spending around $750 |
That's my vote! _________________ 1FUNBUG
71 Beetle, 1776, dual Kadrons
77 Westy, stock 2.0 F.I. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23848 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Tue Mar 20, 2012 7:05 am Post subject: |
| 1FUNBUG wrote: | | vw76westy wrote: |
That's my vote! |
Mine too, you'll spend at least that on carbs (more for the good ones) and still be tweaking them a year from now. Unless you've got some specific performance ambitions and have modified other engine components already the FI is the best bolt on system you'll find and once it's set you leave it alone and drive. _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Posted: Wed Mar 21, 2012 11:46 pm Post subject: |
this is as close as your going to get to a complete turn-key fi system
at a reasonable cost _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1449189
Posted: Thu Mar 22, 2012 11:49 am Post subject: |
Yea I think that sound like the best plan. I do have the weber progressive to use till I get it all figured out
I think I'll hold off on updating the carbs till I get some of the other things worked out. Lots to do.
I've started a project thread finally. You can find it here. _________________ '75 Westy with '78 2.0L engine. |
