Starter Motor Help
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
nick.falconer
nick.falconer is offline
PostPosted: Tue Mar 20, 2012 2:15 pm    Post subject: Starter Motor Help Reply with quote
I've now gotten my build up to starting my engine. It's 12V but the starter is 6V and I think it's a bit stuffed. It turns over really slowly. I have tried the battery from my diesel 4x4 and even that didn't work so I know its not the battery.
The problems I've noticed so far are; the positive terminal on the starter is stripped and it turns in the starter. I rethreaded it to take a smaller nut but It doesn't clamp down hard. I also opened up the starter and found the main shaft in the starter has come in contact with the housing.
Does this mean I need a new starter? Or can I fix these problems?
I also measured the voltage drop along the positive and negative lines. I have 0.6 on both. I have tried cleaning the contacts but it made no difference. Both wires are new and so are he battery clamps.
Thanks
Nick
Letterman7
Letterman7 is offline
PostPosted: Tue Mar 20, 2012 3:24 pm    Post subject: Reply with quote
How's the bushing on the transaxle side where the bendix lands? If that's worn and out of round it'll hang the starter. I've had that happen more than a few times - change the bushing and see what happens.
www.nationalsterling.org
www.tamartedesign.com
jspbtown
jspbtown is offline
PostPosted: Tue Mar 20, 2012 3:28 pm    Post subject: Reply with quote
Maybe you can fix the issues but for $40 wouldn't it be better to get a new one with a lifetime warranty?
http://www.autozone.com/autozone/parts/Duralast-Im...563_12989_
nick.falconer
PostPosted: Tue Mar 20, 2012 3:41 pm    Post subject: Reply with quote
I'll try changing the bushing. I'm guessing I have to pull the engine to do that?
I wouldn't mind a new starter but I don't think they ship overseas. And the places that I have found that will ship to NZ are much more expensive.
Thanks
Nick
BL3Manx
BL3Manx is offline
PostPosted: Tue Mar 20, 2012 4:39 pm    Post subject: Reply with quote
How about from Australia?
http://www.ebay.com.au/itm/Starter-VW-Beetle-1965-...8356385153
Letterman7
PostPosted: Tue Mar 20, 2012 7:09 pm    Post subject: Reply with quote
You can do the bushing with the starter out. It's a little bit of a pain and you'll need some dexterity but can be done. Old bushing can be pulled out with a large flat blade screwdriver wedged inside; new bushing simply placed in position with long needle nose pliers and pushed into place with a dowel rod or some other flat end implement. Put some blue locktite on it to keep it from moving once in place.
manxdavid
manxdavid is offline
PostPosted: Wed Mar 21, 2012 4:17 pm    Post subject: Reply with quote
If the vehicle's fitted with a 6v starter at present you can't just swap it for one of the 12v starters listed, it won't mesh with the flywheel. Unless you're planning on swapping the engine too you'd be best replacing it with another 6v one. If you're going to replace the bush make sure you get the pre-'67 type one to match your starter.
buggy2430
buggy2430 is offline
PostPosted: Wed Mar 21, 2012 6:37 pm    Post subject: Yes Reply with quote
You can change the bushing rather easily without pulling the engine. Just put a tap " I think its a 7'16 into the old bushing and pull it out. I did and it was easy.
nick.falconer
PostPosted: Thu Mar 22, 2012 3:39 pm    Post subject: Reply with quote
I have removed to old bushing. I had to pull the engine as it was so worn out the biggest tap I had which was an M12 just went straight though it.
As you can see there wasn't much of it left.
buggy2430
PostPosted: Thu Mar 22, 2012 7:24 pm    Post subject: Good Work Reply with quote
That baby was worn out for sure. I hope that fixes your starting issue.
nick.falconer
PostPosted: Thu Mar 22, 2012 11:09 pm    Post subject: Reply with quote
I changed the bushing and it now turns over much faster. But I don't think the spark is strong enough to ignite the fuel. It might still be a 6V coil as it felt quite hot after cranking the engine. I might just go through and change the coil leads and plugs and hope that gets it going. Anything else that might need changing to?
manxdavid
PostPosted: Fri Mar 23, 2012 12:57 am    Post subject: Reply with quote
You may as well change the points, condenser and rotor arm and check the distributor cap for cracks etc. while you're on your knees with your tools out.
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
