4-Point Rear Seat Belt
Goto page 1, 2  Next
giller
giller is offline
PostPosted: Tue Mar 20, 2012 4:14 pm    Post subject: 4-Point Rear Seat Belt Reply with quote
I've read through quite a few of the seat belt threads but can't seem to find exactly what I'm looking for. My plan is to install a safer seat belt for the rear bench of my 72 Westy (driver side only), which will secure my 10-year-old.
It seems to me the easiest and best option is a 4-point belt because it only requires three anchors, none of which are on the side walls or require much fabrication - two of the anchors are already there for the existing lap belt. I would add a mounting plate to the middle lock nut.
Does this seem reasonable? What am I missing? Does anyone have some pictures of 4-point belts?
This is what I'm thinking:
busdaddy
busdaddy is offline
PostPosted: Tue Mar 20, 2012 6:29 pm    Post subject: Reply with quote
Aside from having to remove the fuel tank to install it the theory seems adequate.
Wanted, 68-73 westy OG plaid curtains, singles OK.
drober23
drober23 is offline
PostPosted: Tue Mar 20, 2012 6:51 pm    Post subject: Reply with quote
Please post pictures of this here if you get it working to your satisfaction!
DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey
webwalker
webwalker is offline
PostPosted: Tue Mar 20, 2012 7:45 pm    Post subject: Reply with quote
I toyed with a full 4 point (lap and shoulder) where the shoulders wrapped over the top of the seatback and down to where they join the lap belt and bolted into the stock locations. 2 bolts, 4 points.
An old Volkswagen is only cheap to maintain if your time is worth nothing.
The only thing cheap about an old VW anymore is its owner.
1977 CE1 Transporter Deluxe
Click to view image
1972-1/2 1302S -- Now Sold
nerd04
nerd04 is offline
PostPosted: Thu May 03, 2012 4:11 pm    Post subject: Reply with quote
Any progress on this? I need to put safer restraints in the rear of my bus, and this looks promising.
1977 Asi Riviera
RatCamper
RatCamper is offline
PostPosted: Thu May 03, 2012 4:15 pm    Post subject: Reply with quote
honesty what you need are these:
That's a picture from one of the sellers I tried to buy one off that didn't come through for me Evil or Very Mad . they are OE VW.
Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
RatCamper
PostPosted: Thu May 03, 2012 4:24 pm    Post subject: Reply with quote
Those rivets were some kind of owner mod. They aren't there usually.
manikmike
manikmike is offline
PostPosted: Thu May 03, 2012 4:26 pm    Post subject: Reply with quote
So just the one bolt and the ledge for stabilization?
Mike
79 Rivi, 2.0L FI
G'Ville, FL
RatCamper
PostPosted: Thu May 03, 2012 4:28 pm    Post subject: Reply with quote
That's it. But really when you consider that the bolt should be a high grade steel and the fit against the ledge should be flush, plus I think a truck could run them over and not damage them it doesn't seem so bad. These brackets were fitted to Australian Kombis / transporters.
SGKent
SGKent is offline
PostPosted: Thu May 03, 2012 4:34 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=262433&highlight=brake+mat
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
RatCamper
PostPosted: Thu May 03, 2012 4:42 pm    Post subject: Reply with quote
Hey it's the Bigfoot seat belt anchor. All that exists are fuzzy photos and nobody can prove it actually exists Laughing
One thing I can say is that the one i showed as a (poor) example was fitted for local safety requirements and would have been engineer certified, not just something they threw together. I may bitch about our regulations but one thing I can say is that their phenomenal anal retentiveness has prevented us from getting any dangerous vehicles like some countries. I would actually put my faith in this thing even though the one bolt system seems a bit weird to me, simply because not only was it required to be fitted for safety, there are also standards that need to be conformed to. If you have ever been insane enough to dredge through the relevent ADR and AS documents you'd realise they don't mess around with specifications and implementation specifics.
edit: put more faith in the seatbelt anchor than my typing ability. Fixed.
manikmike
PostPosted: Thu May 03, 2012 4:58 pm    Post subject: Reply with quote
Thanks for the reminder Steve, I didn't put the brackets here together with that post - as these look more robust, yet no more well secured... That ledge and runner must be more reinforced than I'm giving it credit for. This issue (safely strapping in the kiddies) is a huge sticking point between me and my Woman - one that has made me strongly consider selling once I get the engine settled. This might be just the ticket (bracket!), as I can see how it was constructed.
Hah - Fair enough!
Mike
79 Rivi, 2.0L FI
G'Ville, FL
RatCamper
PostPosted: Thu May 03, 2012 5:04 pm    Post subject: Reply with quote
I tell you, if there was someone over there with the equipment to fabricate an equally strong or better facsimile I'd move heaven and earth to find one to send over as a template in return for a new pair.
no-one will do anything like reproduce and sell them here for legal and legislative reasons. kind of complex really. I don't think customs would give a hoot about them though and nobody would question them if I installed them. only issue is I lack that ledge. It was one of the big discouraging things for me. I figure I can either find a couple of those sections from a wrecked bay or make something fairly similar from thick box section, possibly a second anchor plate inside and a lot of welding, and just try to make it look stock enough that nobody would look twice at it. Regulations and all again, and scary amounts of associated money Crying or Very sad
manikmike
PostPosted: Thu May 03, 2012 5:10 pm    Post subject: Reply with quote
I'm no Transporter Expert, so I'll ask - Lack - How so? That's not standard construction on your 75, or...?
Mike
79 Rivi, 2.0L FI
G'Ville, FL
RatCamper
PostPosted: Thu May 03, 2012 5:24 pm    Post subject: Reply with quote
Well...um... easier to show you. By the way that brown stuff is some kind of adhesive and not rust, and the laminated ply panel was chucked in with the cabinets when i got them.
You can see, or rather can't see the ledge. My camper was based of a really unusual bay.
1975 model. Dual carb 1800 type 4. Early auto transmission, panelvan, walkthrough front bulkhead (really strange for a panel).
RatCamper
PostPosted: Thu May 03, 2012 5:25 pm    Post subject: Reply with quote
...is that electrical tape? Why on earth is that there.
manikmike
PostPosted: Thu May 03, 2012 5:48 pm    Post subject: Reply with quote
I wasn't gonna say nuthin...!
That lower ledge looks like it has possibilities, all the obstructions you previously mentioned aside.
Mike
79 Rivi, 2.0L FI
G'Ville, FL
RatCamper
PostPosted: Thu May 03, 2012 5:59 pm    Post subject: Reply with quote
looks like it does, yes. but it doesn't. The slider is behind that and if a bolt went through the head would need to be wafer thin to fit and allow the slider to work Sad
giller
giller is offline
PostPosted: Thu May 03, 2012 6:04 pm    Post subject: Reply with quote
Sorry folks, no progress on my part. Seems like those kinds of belts are really hard to come by where I am and I didn't want to fork out the cash (shipping, returning if they didn't work) if I wasn't certain it would work - that's why I was asking the question.
However, I did notice that the PO made a bolt hole in the metal behind the driver-side passenger seat - I think it's for a seat belt anchor. I'll try and take some pics this weekend - maybe a 3 point belt will go in (I still have the original front seat belts that I replaced).
RatCamper
PostPosted: Thu May 03, 2012 6:09 pm    Post subject: Reply with quote
There's always a CRAB bar and harness.
Goto page 1, 2  Next
