Rear hub/CV shaft issues...
Harwood39
Harwood39 is offline
PostPosted: Thu Mar 22, 2012 9:47 am    Post subject: Rear hub/CV shaft issues... Reply with quote
Ok. So I am in the process of removing the motor and tranny from the ghia.. Ran into a slight problem... All the little allen head bolts for the cv shaft are stripped... any pointers besides cutting the boots??
cool karmann collected
cool karmann collected is offline
PostPosted: Thu Mar 22, 2012 1:35 pm    Post subject: Reply with quote
Hmmm... How will cutting the boots off help you get the allen/spline headed bolts off? Given the abysmal quality of replacement CV boots on the market these days, I'd think twice about that anyway. Can you get a vice grip on the outside of the head? come to think of it, have you dug the crud out of the bolt heads and established that they are in fact allen heads rather than splined heads instead?, that could be why they appear to be 'rounding' off when you put a six-side bit in there.
Klick for my Karmann Kapers
http://www.thesamba.com/vw/forum/viewtopic.php?t=441089&highlight=
70 140
70 140 is offline
PostPosted: Thu Mar 22, 2012 1:42 pm    Post subject: Reply with quote
They aren't allen head. They require an 8mm 12 point bit.
If you degrease the bolt heads and use the proper tool, I'm betting they will come out.
Harwood39
PostPosted: Thu Mar 22, 2012 5:23 pm    Post subject: Reply with quote
got them with a vice grip. I dont care about the cv shafts, the one is screwed, and the car is getting parted out but everythings out of the car now.
