andy2166 Samba Member
Joined: March 22, 2012 Posts: 8 Location: naples, florida
Posted: Thu Mar 22, 2012 7:49 pm Post subject: newb needs help. |
| I just bought a sand rail. The title is a 66. The engine is a 1972. It has an obvious rear axle seal leak. My question is how the heck do I identify the year of the rearend to order the right seal? |
68bugbaja Samba Member
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4160 Location: Campbell, CA
Posted: Thu Mar 22, 2012 8:24 pm Post subject: |
| 68bugbaja wrote: | | Is it IRS or Swing axle? |
that would be good to know.
scrape off all the gunk and take pics or write down the #s on the sides of it. we'll go from there _________________ 73 Thing
61 Double Cab
WANTED: Howe Motors Plate Frames |
Posted: Thu Mar 22, 2012 8:35 pm Post subject: |
| Are the numbers on the axle somewhere? |
Posted: Thu Mar 22, 2012 8:48 pm Post subject: |
on the side _________________ 73 Thing
61 Double Cab
DWP Samba Member
jeffsbugs Samba Member
Joined: May 02, 2011 Posts: 294 Location: Nanaimo, British Columbia, Canada
Posted: Fri Mar 23, 2012 8:50 am Post subject: |
That's a swing axle.
I think the axle seals are the same for 61-79 beetles. You could always pull the old one and measure it. Make sure the axle nut is torqued properly too if it's not it can leak.
Jeff _________________ '73 Westfalia, rebuilt 1700, dual OG solex - 3500 miles and counting
'62 Baja |
Posted: Fri Mar 23, 2012 9:02 am Post subject: |
| Thanks. I can't even get the axle nut off lol |
Posted: Fri Mar 23, 2012 9:04 am Post subject: |
Got one of these?
Axle nut removal tool.
or some people use this Torque Meister.
I use a 3/4 drive breaker bar, 36mm socket, with a 4 foot piece of pipe.
'62 Baja
Posted: Fri Mar 23, 2012 9:10 am Post subject: |
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7718 Location: Hablamos Ingles, So. Cal.
Posted: Fri Mar 23, 2012 11:14 am Post subject: |
| jeffsbugs wrote: | Got one of these?
Jeff |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 10067 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Mar 23, 2012 11:47 am Post subject: |
Use a 3/4 of 1 inch drive socket/breaker bar with cheater pipe....
You can break the best quality 1/2 inch drive easily and when you are at full tilt on energy on bar and it breaks you will get hurt.....
Dale _________________ Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
Posted: Fri Mar 23, 2012 1:54 pm Post subject: |
| Got it off. You guys are great. Anyone have the torque values for the 4 bolts that that seal housing? And torque for the axle nut? Ordered a manual but it hasn't come in yet. |
Posted: Fri Mar 23, 2012 2:51 pm Post subject: |
Yup, I've broken more than one 1/2 drive breaker bars so I got a 3/4 drive.
Torque on the cover is 22 ft/lbs I think. Axle nut is 253+ ft/lbs.
'62 Baja |
