GoWestyYoungMan Samba Member
Posted: Fri Mar 23, 2012 10:48 am Post subject: Syncro lock diff panel and vacumn system alternatives |
Surely, the modern air-locker fittings/eletrical harness is a much better option than the old 87-91 system installed by VWOA, right?
How is the vacumn achieved on the modern system?
Thank you for your help and comments. |
insyncro  Samba Member
Joined: March 07, 2002 Posts: 6582 Location: New York
Posted: Fri Mar 23, 2012 10:56 am Post subject: |
Diff lock as an option or standard was installed at the factory, not the dealer.
It is a very simple system and once made operational, with minor upkeep should work for a very long time. |
Posted: Fri Mar 23, 2012 11:27 am Post subject: |
| insyncro wrote: | Diff lock as an option or standard was installed at the factory, not the dealer.
Yes true, but if the price of the used system is $400 (like on the classifieds) isn't reliability and durability on the modern system less cost in the end? |
Posted: Fri Mar 23, 2012 11:32 am Post subject: |
$400, is less expensive than I have sold that complete system in the past.
It works fine for me.
Vacuum and switch signals are all that is really needed to make it operate.
There are upgrades to stock wiring that will flash the lights on the dash.
Other than that, I think most just bite the bullet and run stock parts.
They haven't dried up completely yet. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 8724 Location: Vanistan, Abiquiu, NM, USA
jordauto Samba Member
Joined: August 12, 2011 Posts: 50 Location: Sorrento,BC
Posted: Fri Mar 23, 2012 12:04 pm Post subject: |
If you're adding a diff lock and want to avoid buying the panel from a syncro.You can mount the vacuum switch anywhere on the dash. the system is very simple and works well with very little upkeep. I just replaced my 2WD manual trans and added a diff lock.GTA supplied the vacuum switch with the trans. Local parts store supplied a 50' roll of 5/32" vacuum tubing,vacuum hose and a warning lamp.Went to the local Pick a Part for a vacuum tank.I had an unused A/C control panel and used that to mount the control and lamp.The local engraving shop made the panel for about $10.00. It works well and I think it looks like it belongs there.
Posted: Fri Mar 23, 2012 12:07 pm Post subject: |
Nice rework of the late AC dash panel  |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 1429 Location: flagstaff az.
Posted: Fri Mar 23, 2012 12:09 pm Post subject: diff lock |
Wow that is cool , considering the price of the stock ones , way to go. But alas I have more then one button!  _________________ 1987 syncro westy tin top sun roof GW2.3 rear locker decoupler custom bumper roof rack Gary Lee tire rack lift south african grill big brakes rhein alloy 15 BFG AT 617 gears ShadyBoy awning 140 watt rear 85 watt front solar mppt truckfridge automatic fire extinguishing system - 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley - Dodge 4500 4x4- 1987 tin top westy Jetta 2.0 ABA 1.8 head, 55 watt solar automatic fire extinguishing system -Just sold my 84 Westy |
Posted: Fri Mar 23, 2012 12:26 pm Post subject: |
| jordauto wrote: | | If you're adding a diff lock and want to avoid buying...] |
Thanks very much for that post!  |
Farfrumwork Samba Member
Joined: October 10, 2008 Posts: 346 Location: Mile High
Posted: Fri Mar 23, 2012 2:52 pm Post subject: |
I added a vaccum locker system to my 2wd when I added the locking syncro tranny.
things you need (may not be a comprehensive list, and could be altered):
- Vaccum accumulator, "3-bulb chamber" (ebay - lots to choose from)
- Check valve (at manifold)
- 1/4" vaccum line (I used blue/black/white to help connections)
- 5-way switch. I used a ~$60 SMC switch (no PN right in front of me)- you can get twist/pull/push/etc.. knobs (colors too)
I mounted a pull switch (valve) under the heater controls, and I have a custom insrument panel insert that has a diff lock symbol in the lower right (unused) indicator. It lights up when I have the lock engaged.
I'll hacve pics posted when I finally get an install thread posted... it's only been a year  _________________ '85 Wolfsburg, EJ22/ syncro tranny - Full Syncro conversion in process (+ 2.5L upgrade!)
'07 Legacy spec.B, stgII
NOTICE: Insanity has replaced reason in the design and construction of this vehicle. |
Posted: Sat Mar 24, 2012 10:08 am Post subject: |
| Farfrumwork wrote: | I added a vacumn locker system...
Thanks very much for your post!  |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 2082 Location: Cascadia
Posted: Sat Mar 24, 2012 12:12 pm Post subject: |
Funny, I was thinking about this the other day...for no particular reason. Actually, Mercedes uses lots of vacuum solenoids, so a simple toggle switch on the dash could be used to trigger one of these in the engine compartment that then sends a short run of manifold vacuum to the pod on the trans. Quite simple, and no need for the long runs of vacuum all the way up to the front.
I've collected a bunch of these over the years, so if anyone needs one, I can let them go for cheap.
The top port is NC and the side port is NO _________________ --Casey
'89 Bluestar
"Endeavor to persevere" |
Howesight Samba Member
Joined: July 02, 2008 Posts: 628 Location: Vancouver, B.C.
Posted: Sat Mar 24, 2012 2:53 pm Post subject: |
Audi 5000 Quattro cars used a vacuum actuator system to lock the center diff and the rear diff. The dash unit looks sexier than the Syncro unit. The actuators at the diffs might even be the same part numberS.
Here's an advert from Audi Fans for a dash diff lock panel which can operate two diff locks:
http://www.audifans.com/marketplace/show.php?
Here are pics of the Audi 4000 and 5000 Quattro dash panels to help you decide if that style is for you:
img]http://images.thesamba.com/vw/gallery/pix/909150.jpg[/img]
img]http://images.thesamba.com/vw/gallery/pix/909147.jpg[/img] _________________ '86 Syncro Westy SVX |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 999 Location: New York City
Posted: Sat Mar 24, 2012 5:12 pm Post subject: |
I thought VAG cars used electric door lock actuators, while MB definitely uses an electrically switched vacuum pump setup. _________________ --Casey
'89 Bluestar
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 5358 Location: Syracuse, NY
morymob Samba Member
Joined: November 09, 2007 Posts: 2741 Location: east-tn
Posted: Tue Mar 27, 2012 4:56 am Post subject: |
| On my '86 i got a 12V sol locally and ran a 2pair wire to front for a sw/ind led. Sol mounted in eng compartment,check valve, vac tank a vw wiper/washer fluid bottle and some short vac hose runs to actuator. |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 1586 Location: Oxfordshire, UK
Posted: Tue Mar 27, 2012 1:07 pm Post subject: |
I'm looking at using some of the VW modern boost solenoids like the N75 etc and just running an extra set of wires up to a switch on the dash so that there are no vacuum pipes to the front.
I have had to replace the front vacuum switch on my syncros in the past.
MG _________________ 1989 Syncro 16 S6 Westy Limey
1991 Syncro Lightweight SWB
1989 S8 Bluestar
1990 Tristar |
Posted: Tue Mar 27, 2012 1:28 pm Post subject: |
Did you see my post up above about the MB vacuum solenoids? They're perfect for doing exactly what you're describing. With one vacuum inlet and a NO and NC port, they're perfect for these dual stage actuator pods. _________________ --Casey
'89 Bluestar
