which electric fuel pump for 2180cc twin webers44 + porsche
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
madasun
madasun is offline
PostPosted: Sat Mar 24, 2012 4:26 am    Post subject: which electric fuel pump for 2180cc twin webers44 + porsche Reply with quote
hi guys,
need your help please, got new engine fitted to my 66 kg, due to porsche fan need to fit electric fuel pump, its a 2180cc with twin weber 44s with porsche fan kit, was thinking of fitting either a cb performance electric rotary fuel pump or a facet cube style pump(which is best) and also a filter king pressure regulator and gauge, where is best place to fit both in engine bay.
which is best location to fit external oil cooler + fan, inside engine bay right hand side inside of arch or outside underneath?
please send links of any photos that may be helpful
thanks
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Mar 24, 2012 6:05 am    Post subject: Reply with quote
CB pump.
Put the cooler under the car by the transaxle.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
madasun
madasun is offline
PostPosted: Sat Mar 24, 2012 6:11 am    Post subject: Reply with quote
Been told if I use cb pump will have to fit near petrol tank, is this correct?
Mr. 010
Glenn is offline
PostPosted: Sat Mar 24, 2012 6:13 am    Post subject: Reply with quote
Correct, electric pumps are "pushers" and need to be near the tank.
Glenn
HBB/RW
www.DasVolks.com
madasun
madasun is offline
PostPosted: Sat Mar 24, 2012 6:22 am    Post subject: Reply with quote
Ok, so best option cb pump fitted at the front by petrol tank, filter king fitted on engine firewall behind engine and oil cooler by transaxle.
Ty Glenn
Dale M.
Dale M. is online now
PostPosted: Sat Mar 24, 2012 9:06 am    Post subject: Reply with quote
A Carter P60504 pump is same as CB pump...
http://www.summitracing.com/parts/CRT-P60504/
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
mcmscott
mcmscott is offline
PostPosted: Sat Mar 24, 2012 9:23 am    Post subject: Reply with quote
CB retail, 65$ Summit 73$ Same pump
Dale M.
PostPosted: Sat Mar 24, 2012 10:43 am    Post subject: Reply with quote
http://www.amazon.com/dp/B000BZX92K/ref=asc_df_B00...nkCode=asn
http://www.autopartsexpress.com/item.wws?sku=P6050...7c10113769
http://autoplicity.com/products/996767-Carter_P605...FNOFITMENT
http://www.rockauto.com/catalog/raframecatalog.php...0504-74928
http://www.righttoolusa.com/p/Carter-P60504-Electric-Fuel-Pump-3256271.html
http://autoshepherd.com/carter-p60504-electric-fue...+Fuel+Pump
Dale
madasun
madasun is offline
PostPosted: Sat Mar 24, 2012 11:06 am    Post subject: Reply with quote
what about regulator, at what psi?
mcmscott
mcmscott is offline
PostPosted: Sat Mar 24, 2012 11:16 am    Post subject: Reply with quote
Dale
Good info there
JustBuggy
JustBuggy is offline
PostPosted: Sat Mar 24, 2012 12:05 pm    Post subject: Reply with quote
Thanks for the links Dale!
I've been wanting to get an Efuel pump myself. Finally whipped out the plastic and pulled the trigger after reading this.
Now I'll need an FP regulator, T, and gauge. Shocked
Dale M.
PostPosted: Sat Mar 24, 2012 2:02 pm    Post subject: Reply with quote
It's amazing if you have correct "manufactures name & part number" what you can find on Inte-net "SHOPPING" sites....
Tunnel blindness for VW parts dealers (or anything for that matter) can kill your pocket book...
Dale
Gatorbus
Gatorbus is offline
PostPosted: Fri Jun 29, 2012 1:41 pm    Post subject: Which Carter Reply with quote
I plan on replacing my noisy facet with a carter rotary. Link provided shows a 3.5 or 5.5 psi option. Which is better for a single 2 barrel Weber set up? Thanks.
http://www.cbperformance.com/catalog.asp?ProductID=577
SRP1
SRP1 is offline
PostPosted: Fri Jun 29, 2012 1:44 pm    Post subject: Reply with quote
The 3.5 is the correct one. Plenty of juice to the Gasser!
www.srpengines.com
Performance Plumbing- AN fittings, Braided hoses, Fire Sleeve....
Ragman
The Sambinator
Ragman is offline
PostPosted: Fri Jun 29, 2012 2:23 pm    Post subject: Reply with quote
Regulator is not needed for the Carter/CB 3.5 pump.
Gatorbus
Gatorbus is offline
PostPosted: Fri Jun 29, 2012 2:30 pm    Post subject: Reply with quote
Thanks gents. I'll get the 3.5 Carter and forego the PR. But will keep the noisy facet in place as backup.
smitty24
smitty24 is offline
PostPosted: Fri Jun 29, 2012 3:43 pm    Post subject: Reply with quote
^^the Carter rotary is very nice. I just installed one for my 1904 with Webers. Runs perfect. I removed my regulator since it was acting like a restriction at first. They do regulate themselves, as a previous poster mentioned. Mine came with a screwy filter that would not fit my fuel line. You can still hear the Carter, but over the engine...probably not. My engine is FAR louder than the pump (mounted inside my front clip near the ID tag).
I will add, I dont get any flooding or leakage BS either. The constant 3.5 PSI is probably perfect for routing fuel from front of car to rear, with a couple filters in between. I run 3 filters before fuel line hits engine compartment.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
