Consistency of Urethane Primer
mpate
mpate is offline
PostPosted: Sat Mar 24, 2012 5:06 pm    Post subject: Consistency of Urethane Primer Reply with quote
Can someone elaborate of when laying down primer is the consistency going down like an eggshell finish or should it be more of a flattened finished sheen when dry. I have been learning with urethane primer using an HVLP paint gun with a 1.8 tip/needle, and about 30 PSI with trigger down. I am learning how to lay down my own coats of primer prior to sending it off to paint eventually. I can do all of the body work but need a little advice here. I want to prime the entire shell with sanding in between each coat to build up and low areas.
Matthew Pate
62 Ragtop Beetle
66 Beetle in Progress
Matt K.
Paint and Body Nutcase
Matt K. is offline
PostPosted: Sat Mar 24, 2012 5:18 pm    Post subject: Reply with quote
Here is the thing, it depends on the brand. Some brands like Sherwin Williams primer dries almost glossy while some like Axis dry totally flat. Basically with primer unless you totally run it......you are doing ok.
This is my 21st year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .
craigman
craigman is offline
PostPosted: Sat Mar 24, 2012 6:47 pm    Post subject: Reply with quote
Yep, different brand primers will do different things.
Also how much you reduce it will have effect on it as well.
Just lay down 3 nice heavy coats, let dry, and block it out. No need to put down one coat, let dry, sand it, put on another coat, let dry, sand it, ect..
