Beauty rings creeping
(o)=!=(o)
(o)=!=(o) is offline
PostPosted: Sat Mar 24, 2012 10:22 pm    Post subject: Beauty rings creeping Reply with quote
I noticed the other day my beauty ring had creeped almost an inch (2.54 cm) and was pushing the valve stem way over. I popped off the hubcap and realigned the ring but it creeped again after maybe 5 miles of city driving. Why is it creeping?
Van
Ian Godfrey
Ian Godfrey is offline
PostPosted: Sun Mar 25, 2012 5:32 am    Post subject: Reply with quote
I don't know why they creep, but it is very annoying..... I used some double sided tape on the edge of the rim to stop them creeping, a couple of pieces an inch long was enough, but I could still get the rings off without damaging them. (replace the tape each time)
analengineguy
analengineguy is offline
PostPosted: Sun Mar 25, 2012 7:40 am    Post subject: Reply with quote
It happens a lot on hubcaps and trim rings. Bending out the.prongs slighty that hold it on, be they on the ring, or on the wheel, usually cures it. You might get by with just bending a few, strategically placed, but its best to bend them all out to about the same degree. I'll bet they won't come on and off as easy though after that...
Ghiaddict
Ghiaddict is offline
PostPosted: Wed Mar 28, 2012 8:32 am    Post subject: Reply with quote
For the later models, if some f00l has been using
a big, flat-bladed srewdriver to remove the hubcaps
then the inner circumference of the beauty ring gets
damaged. The result is the creep.
Sorry, but this annoys me. Evil or Very Mad
VW supplied a (stock) hubcap removal tool for a reason.
Karmann Ghia & Beetle parts available.
Convertible tops installed.
golfvt1
golfvt1 is offline
PostPosted: Thu Mar 29, 2012 2:40 pm    Post subject: Reply with quote
Ghiaaddict,
What is the best method to remove hub caps? Putting beauty rings on this weekend, want to do it right.
(o)=!=(o)
PostPosted: Thu Mar 29, 2012 4:17 pm    Post subject: Reply with quote
VT1
there are two holes on the side of the hub cap. There is a tool that sticks in these holes to grip the hub cap. You can probably make one from a metal clothes hanger. Bottom line, do not try to pry them off with a big screw driver.
Van
http://www.karmannghia.com/viewDetail.asp?strMasterCat=&idproduct=1028
PostPosted: Thu Mar 29, 2012 5:38 pm    Post subject: Reply with quote
(o)=!=(o) wrote:
VT1
Van
This
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
golfvt1
golfvt1 is offline
PostPosted: Fri Mar 30, 2012 5:19 pm    Post subject: Reply with quote
Thanks guys. I am working on the "final polish" of my 'rings, will remove the hub caps properly from now on. Thanks again, think spring
