henk Samba Member
Posted: Sun Mar 25, 2012 11:38 am Post subject: coil bind SOLVED now lifters failed!!!!! |
hallo,
the heads and rockers went on my engine today,but it seems like it has coil bind.
what is the best way to solve this probleme from coil bind?
whitout changing the cam off course.
the cam is an FK-10 and the rockers are 1.4 scats
can i do some modification on the heads or so to solve this?
henk!!!
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 309 Location: Little Britain
Posted: Sun Mar 25, 2012 11:43 am Post subject: |
| machine the spring seats or fit longer valves |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 2741 Location: 37.54N 77.18W
Posted: Mon Mar 26, 2012 6:48 am Post subject: Re: coil bind |
| henk wrote: | hallo,
henk!!! |
No sure, but maybe that cam isn't for use with 1.4 rockers. _________________ *DISCLAIMER* What you see might not be what I typed! |
ALB Samba Member
Joined: August 05, 2008 Posts: 2635 Location: beautiful suburban .....
Posted: Mon Mar 26, 2012 9:04 am Post subject: |
The FK10 is designed for 1.4 rockers. Don't try to machine the heads to lower the spring seat height; you'll probably cut through the little bumps in the intake ports. Are you getting coil bind or are the retainers hitting the tops of the guides? They usually have to be clearanced for dual springs and that much lift. Also, some retainers allow more lift than others. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Slalombuggy- Now I understand my trust issues... |
henk Samba Member
Posted: Wed Mar 28, 2012 1:56 am Post subject: |
| ALB wrote: | | The FK10 is designed for 1.4 rockers. Don't try to machine the heads to lower the spring seat height; you'll probably cut through the little bumps in the intake ports. Are you getting coil bind or are the retainers hitting the tops of the guides? They usually have to be clearanced for dual springs and that much lift. Also, some retainers allow more lift than others. |
hallo,
it looks like we have both of them coil bind and the retainers are touching the valve guides.
i'm going to change the springs that are in it now to CB650.
and also machine down the retainers 3mm so that they clear the valve guides.
henk!!! |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 1606 Location: Baltimore, Maryland
Posted: Wed Mar 28, 2012 5:21 am Post subject: |
Normally it is the valve guides that are clearanced not the retainer to solve that issue. Are you running too many shims under the springs by chance? _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
Cox Racing Engines
Class 5-1600's; Stock 1600 to 2498cc Type 1's. Custom Built for you in Maryland |
henk Samba Member
Posted: Fri Mar 30, 2012 2:03 am Post subject: |
hallo,
ok thanks fot that.
we gonna trim down the valve guides instead.
henk!!! |
henk Samba Member
Posted: Fri Apr 06, 2012 1:04 pm Post subject: |
ok,new springs are in and the valve guides are shortend 2mm.
everything seems to work well now.
henk!!! |
henk Samba Member
Posted: Wed Apr 25, 2012 1:49 pm Post subject: |
after 10min. of running the engine starts to make some noise.
we checked the valve clearance and this big.
we adjust the clearence and fired it up again,same again and this time the lash cap came even uf the valve.
here is the result two lifters gone.
henk!!!
jfats808 Samba Member
Joined: December 10, 2007 Posts: 3039 Location: oahu hawaii
Posted: Wed Apr 25, 2012 2:01 pm Post subject: |
At full lift did you have adequate clearance of your spring clearance? Some valves have different set hieghts when installed. That's probably where hit. Alternate cause is not enough cam to lifter clearance. Cb650 are really stiff springs too. Ouch. _________________ 2276 IDA's 86C 11-1 DD !
2017 48DRLA's W125
Check your oil levels routinely! |
john@aircoo[email protected] Samba Member
Joined: August 03, 2002 Posts: 7047 Location: Salt Lake City, Utah
Posted: Wed Apr 25, 2012 4:38 pm Post subject: |
it's very possible the lifter cracked when the retainers hit the guides before, and the failure completed after reassembly. _________________ Please do NOT send me Private Messages through the Samba PM System (I will not see them). Send me an e-mail to john at aircooled dot net
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net |
mightymouse Samba Member
Posted: Wed Apr 25, 2012 7:08 pm Post subject: |
^^^^ this.
Need to do it all again, check lifter head to case clearance when assembling, then assemble and check for bind and all other clearances.
Those lifter heads broke awful bad. Never seen that before.  _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
henk Samba Member
Posted: Thu Apr 26, 2012 1:28 am Post subject: |
all clearences were fine when we installed the new springs.
@John,so you mean that this could be happend then just by turning it over by hand,that it had a some damadge and got destroyed when we fired it up?
henk!!! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 1006 Location: Videbaek Denmark
Posted: Thu Apr 26, 2012 2:42 am Post subject: |
| [email protected] wrote: | | it's very possible the lifter cracked when the retainers hit the guides before, and the failure completed after reassembly. |
Ditto that. If the lifter was damaged under trial and error, it will destroy itself fast during start up.
That is not the problem to this failiure, but you need to have 2,5 mm retainer to guide clearance and also min. 2,5 mm to coil bind. Lifter height clearance should also be at least 2 mm. I prefer 2,5 mm.
That is the "slack" it needs to have when tings are busy.
T |
tommiebsmith Samba Member
Posted: Fri Apr 27, 2012 10:02 am Post subject: |
Started break in with both springs in place.. got ten minutes on motor and the "good" lifters look like that??
I also read COIL BIND up top ??? was that ever addressed? other than cutting 2mm from the seat.
.539 ish with 1.4s shouldn't cause that much problems?
was addressing proper push rod length ever verified?
these are just me sitting here in Texas questions? |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8514 Location: SHALIMAR ,FLORIDA
Posted: Fri Apr 27, 2012 11:16 am Post subject: |
| my fk8 (.382 lobe lift) was over .580 lift with "1.4" rockers that checked over a 1.56 with another cam.just going by what is printed and what is thought along with a caluclator can ,will,and has killed a lot of parts.always check for your self just how much lift there realy is with all combinations&configurations. |
Pat D Samba Member
Posted: Fri Apr 27, 2012 12:47 pm Post subject: |
What brand lifters are they? The newer Engle cams use the harder chilled iron cam billet. Not all lifters on the market are hard enough for these cams. _________________ Pat, Im too fast slow me downs! |
VIN Samba Member
Posted: Fri Apr 27, 2012 2:55 pm Post subject: |
| Pat D wrote: | | What brand lifters are they? The newer Engle cams use the harder chilled iron cam billet. Not all lifters on the market are hard enough for these cams. |
are your lightweight racing lifters hard enough? _________________ Co-owner, 2 Brothers Guns
[email protected]
Click to view image |
stevet4 Samba Member
Posted: Sat Apr 28, 2012 2:39 am Post subject: lifters |
Full lift @the valve 14,5mm(0.570)...... scat 1,48 rockers
Retainer to guide clearance @full lift 1.5mm(0.059)
lifter to bore clearance @ full lift 2mm(0.078)
coilbind @full lift 1.9mm(0.074)
should we get more clearance? |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 471 Location: Cornwall - UK
Posted: Sat Apr 28, 2012 3:48 am Post subject: |
| VIN wrote: | | Pat D wrote: | | What brand lifters are they? The newer Engle cams use the harder chilled iron cam billet. Not all lifters on the market are hard enough for these cams. |
are your lightweight racing lifters hard enough? |
Put a guy in a tough spot!! |
