TCBeier Samba Member
Joined: June 12, 2012 Posts: 109 Location: Granite Bay, Ca.
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Sat Mar 16, 2013 7:12 pm Post subject: |
TCBeier wrote: |
what kind of sound barrier ? I was thinking about bed liner, has anyone done or heard of using bed liner? |
I've heard that bedliner isn't recommended. I believe because it's messy, it smells, and can be costly. I'm torn between 2 kinds of sound barriers. I know Eastwood sells a good sound barrier, but it's pretty expensive. I saw this YouTube video http://www.youtube.com/watch?v=O0TGIinpKFg where they use something called "Quick Roof" which is pretty cheap at Home Depot that I may end up using, being that saving $ is always a major factor if I want to finish my project in this lifetime... _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
jvulich Samba Member
Posted: Sat Mar 16, 2013 7:17 pm Post subject: |
My 70 was done with a spray on bedliner product called Hippo Liner. Then I used half inch carpet backing/insulation on top of that. They make do it yourself roll on kits now that are a fraction of the cost. |
Boom Samba Member
Joined: September 29, 2007 Posts: 1119 Location: Houston by God Texas
Axle Samba Member
Joined: September 11, 2007 Posts: 64 Location: Annapolis, MD
Posted: Sun Mar 17, 2013 6:16 am Post subject: |
I used Fat Mat in my '64. good stuff, and not too expensive _________________ '64 Bug
'02 GTI 1.8t |
Posted: Sun Mar 17, 2013 7:26 am Post subject: |
Where's the best place to find that Fat Mat stuff? I'd like to do some research & see what it may cost me. Thanks _________________ .
Axle Samba Member
Posted: Sun Mar 17, 2013 7:40 am Post subject: |
I think I got it on ebay, might have been amazon. _________________ '64 Bug
'02 GTI 1.8t |
Atx67beetle Samba Member
Joined: January 06, 2013 Posts: 25 Location: Austin, TX, USA
Posted: Sun Mar 17, 2013 7:43 am Post subject: |
Sportin, nice thread! It looks like we are around the same spot in our projects. I'm going to start a thread on my build soon. I'm going to keep an eye on your thread, see if I can borrow some ideas. Thanks for the good info so far!
And a belated welcome to TX! _________________ "It should not be the the aim of the motor industry simply to bring out new models, but rather to produce and sell."
Heinrich Nordhoff |
Posted: Sun Mar 17, 2013 4:20 pm Post subject: |
Axle wrote: |
I think I got it on ebay, might have been amazon. |
Cool, thanks. I'll definitely check it out!
Atx67beetle wrote: |
And a belated welcome to TX! |
Thanks Atx67beetle! I hope to make some good progress before we get hit with the blistering Texas weather like we get. Looking forward to seeing your build thread as well - as you can see, it's a great way to get helpful input from other TS members! _________________ .
Posted: Sat Mar 30, 2013 5:41 pm Post subject: |
Took advantage of the 85 degree weather and worked on my bug.
I bought 2 quarts of POR15 - 1 of glossy gray and 1 of glossy black.
I first used Dynatron seam sealer for a good seal all the way around. This stuff was very easy to use and dried fairly quickly.
Next step after cleaning the pan surface and removing dust and debris was to POR15 the pans gray. I had read a good tip on one of the forums, where you paint the first coat gray:
Then once that dries, you apply the 2nd coat in black so that you know you've covered all necessary areas.
I may get crap for not removing the tunnel tar board, but it's in really good shape, and I'm not going for the show car results anyway. I'll try to do the same steps on the bottom side tomorrow....wait, that's Easter Sunday! So hopefully soon...... _________________ .
grandpa pete Samba Member
Posted: Tue Apr 02, 2013 8:37 pm Post subject: |
Thanks sportinwood for the post....I have a 68 that i will be starting this summer .I have been reading build threads in several forums and yours was the first to mention the grey paint then black paint trick....could have used that when i did my 69 bus...keep up the good work and watch out for that texas heat. ...I have an air conditioned garage _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
Posted: Wed Apr 03, 2013 7:26 am Post subject: |
Lookin good! Don’t be afraid to do stuff your self especially after pulling the body and doing pans. You can do it. If you have any questions I’ve been through the whole process including window seals just IM me. Like you I’m no pro but have figured it out |
Posted: Wed Apr 03, 2013 12:14 pm Post subject: |
grandpa pete wrote: |
Thanks sportinwood for the post....I have a 68 that i will be starting this summer .I have been reading build threads in several forums and yours was the first to mention the grey paint then black paint trick....could have used that when i did my 69 bus...keep up the good work and watch out for that texas heat. ...I have an air conditioned garage |
Wow - a/c in the garage! NICE! I'm hoping within the next year or two I'll find a new house with the necessary "accomodations" for my obsession...err, uh...I mean hobby!
EA812 wrote: |
Thanks EA812 - I have had experience years ago with window seals on a '63 project I had, but I sure don't remember there being as many problems as I've noticed others have with either the front or rear windows or the vent wing/door windows! I might hit you up with an IM when the time comes... _________________ .
Gnarlyleech Samba Member
Joined: April 23, 2012 Posts: 222 Location: Southwest Louisiana
Posted: Thu Apr 25, 2013 8:10 am Post subject: |
I hope you are taking advantage of all these cold fronts. You'll miss it when its gone. I'm headed outside to do some tie rod repairs. Your floor pans look great. _________________ "Good judgment comes from experience and a lot of that comes from bad judgment"
My 1966 Beetle Project Thread http://www.thesamba.com/vw/forum/viewtopic.php?t=520182 |
Posted: Thu Apr 25, 2013 9:20 am Post subject: |
Gnarlyleech wrote: |
I hope you are taking advantage of all these cold fronts. You'll miss it when its gone. I'm headed outside to do some tie rod repairs. Your floor pans look great. |
Thanks, man. Right now the progress is on hold. Have to get a deck built in my back yard that's taking all of my time. I hope to start again on my project soooon! _________________ .
Motomazzo Samba Member
Posted: Wed Jun 05, 2013 4:05 pm Post subject: |
Hey Dave,
It's looking great. I've been away for a while. Like you, I'm on another home project (gigantic porch enclosure/bird aviary), so mine's on hold as well. It's looking like late Fall for being on the road.
Keep at it and I will too!!
Moto _________________ Be Plant-Strong!! Watch "Forks Over Knives" on Netflix
'66 Sedan Project - http://www.thesamba.com/vw/forum/viewtopic.php?t=410718
R.I.P. - Mikayla. I miss you Baby girl. |
Madd Maxx Samba Member
Posted: Tue Aug 06, 2013 7:18 pm Post subject: |
SW-
I'm new to the forum. I too have a long slow road ahead of me. I've enjoyed reading about your project. I'm going to need all the helpful hints I can find. Keep 'em coming & keep up the good work! _________________ My 1960 Ragtop bug build
http://www.thesamba.com/vw/forum/viewtopic.php?t=565565&highlight=1960
Wanted: 1960 truck lid & rear fenders |
artie325 Samba Member
Joined: July 25, 2005 Posts: 187 Location: Hamburg, NY
Posted: Wed Aug 07, 2013 1:42 am Post subject: |
sportin-wood wrote: |
I may get crap for not removing the tunnel tar board, but it's in really good shape, and I'm not going for the show car results anyway. I'll try to do the same steps on the bottom side tomorrow....wait, that's Easter Sunday! So hopefully soon...... |
I hope you stripped the primer off of the pans first. I used por15 on my wolfsburg west pans a few years back the same way you explained and it peeled a year later...what a mess!
sovereignsamba Banned
Posted: Thu Oct 17, 2013 10:17 am Post subject: |
I'm done with por 15, going back to rustoleum. I had the same thing happen with some por 15 I applied to bare metal. Peeled right off and was rusting underneath!!!!! Bad prep??? I used metal ready that came with the por 15 kit. All the rusto I've applied is still in great shape, no rust underneath, no peeling, very durable. |
Posted: Thu Oct 17, 2013 7:15 pm Post subject: |
Although I didn't strip the pans down to bare metal, I did scuff them up really good with a medium grit sandpaper, so I feel confident that it'll hold.
Sorry I haven't had any progress to my thread. Lots of home improvements have gotten in the way as I'm getting ready to put my house up for sale. Hoping to find a new house with an enclosed shop for my project so that I can work on it in all kinds of weather. Don't give up watching, guys & gals! _________________ .
