harley611 Samba Member
Joined: June 13, 2008 Posts: 267 Location: Charleston, WV
Posted: Wed Apr 04, 2012 9:39 pm Post subject: |
I looked at the almond, but it looks a little dark. The biscuit color seems to be more like what I have. Is everyone using the Krylon almond? I need to spray my column, etc. and want to make sure before I waste the money and time. |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
moab762 Samba Member
Joined: October 09, 2014 Posts: 518 Location: El Segundo, CA
Posted: Mon Nov 24, 2014 10:11 am Post subject: |
So let me get this straight. Appliance almond epoxy will match an "ivory" steering wheel? For painting the column and turn signal switch? |
ExtremeBean Samba Member
Posted: Fri Nov 27, 2015 8:27 am Post subject: Re: Rustoleum almond? Steering column |
Are you all.using regular Almond or Satin Almond? Also, is the Rustoleum the se as Krylon (in terms of shade) |
bruiserbabie Samba Member
Joined: December 08, 2008 Posts: 18 Location: Portland, Oregon
Posted: Thu Dec 07, 2023 8:19 am Post subject: Re: Rustoleum almond? Steering column |
I just wanted to add to this with my input, this is what I found.....
So I have been looking into things on this topic and found out that Parchment white L81 and Pearl white L87 are in fact the same paint color and formula mixture, looks like VW just changed the name. So I went to my local paint store and bought a quart of PPG Omni coat Pearl white paint L87, which is a less expensive PPG paint. The mix was way way off, it was not even close, it was more of a blue tinted gray, not anywhere near an Ivory color. See in the pics below and you will see my 58' bus dash is factory Pearl white, so I had that to go by to get a match. Then I had them mix me a more expensive blend of PPG the Concept Deltron Pearl white L87 and boy o boy was it spot on!!! In the pics below you will see my 56' bug wheel is also parchment white / pearl white (from the factory), I painted the centers of all 5 of my new wheels with the PPG Concepts Deltron Pearl white L87 and it turned out perfect, also see the Rustoleum Almond painted turn signal housing next to the wheel to see the contrast (difference). I am also going to be painting my Batwing steering wheel with the same Pearl White L87 (that is also what VW used in the factory for steering wheels. I will post another photo later once its been painted, I am doing it this Friday. Thanks and I hope this helps! Please note that the wheel center pics below are the same exact color but do look a lot different in the different light and at different angles. lol but are the exact same wheel haha
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Tue Dec 12, 2023 9:41 pm Post subject: Re: Rustoleum almond? Steering column |
Those wheels are beautiful!
But please be sure to sand that paint off to bare metal on the beveled surface of each lug bolt hole (the surface that touches the bevel of the lug bolt). Do NOT leave any paint there as after torqueing those bolts on the wheel, and then the stress and pressures on those surfaces while driving around can cause that unremoved paint between the two metal surfaces to probably compress and you might find the lug bolts quickly loosening and you might watch one of your wheels pass you on the highway as you limp on three wheels to the shoulder (if you are lucky enough)! Ask me and at least two other friends that I know how we now know to do this small bit of wheel paint removal... I just wish I had a photo of the look on my face when my rear left wheel passed me as I slowed down!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
