delliott101 Samba Member
Joined: February 22, 2008 Posts: 1304 Location: Boise ID
Posted: Tue Apr 03, 2012 1:05 pm Post subject: |
Oh, looking at the picture, you could probably just replace the muffler with a stock one for that year or just (what I would do is) just get rid of it. _________________ Transplanted Jersey Boy living in Idaho by way of Northern California!
We don't own old VWs, we just take care of them for the next driver |
slione Samba Member
Posted: Tue Apr 03, 2012 3:21 pm Post subject: |
| delliott101 wrote: | | The Overdrive heated too much on the trip out there as we forgot to turn it off while towing the Bug with the tow bar... on the return trip on the following Sunday, the transmission conked out in Brewster Kansas... |
Ouch!!  _________________ 1974 SB Vert - Getting there, slowly but surely |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 2231 Location: Los Gatos,Ca.
Posted: Tue Apr 03, 2012 10:46 pm Post subject: failed teast |
Lets start with CO since your car is a Gross polluter
CO starts with excessive carbon build up usually from short
drives.and, increases HC's and Nox.
Oil contaminated-Change Hot,Vacuum leaks,Air filter.Carb adjustment
HC's Plugs,Wires,cap&rotor,Timing advanced to far,Vacuum leaks
Lean fuel mixture.
NOX=EGR,Lean fuel mix.
Some try and use "seafoam for the carbon buildup and readjust
vales,timing and carb settings to see if all this will get the car to pass.
I Don't know what shape your engine is in and you may want to find some local help with someone that can do a Pre-test after you have tried this method. _________________ V.W.owner since 1967 |
Go_Bug_n Samba Member
Joined: August 01, 2008 Posts: 111 Location: Rockledge, Florida
Posted: Tue Jun 26, 2012 11:15 am Post subject: |
Just my two cents. If your engine is in correct tune, I'd keep the EGR.
By doing what it does, it reduces combustion temps which will reduce cylinder head temps. That will help extend the life of your valves. If everything on your engine is right, you'll barely notice the very slight part throttle power loss from the EGR.
In my case, I have a perfectly running 1976 fuel injected Beetle. When I disconnected my EGR, I could hardly tell the difference so, I hooked it back up. Yes, the EGR valve works, the port is not plugged with carbon, and the EGR filter is recent (paint is still on it). _________________ Was it over when the Germans bombed Pearl Harbor? Hell no!!!
-Bluto
No longer a virgin 1976 standard Beetle. Now has ice cold AIR CONDITIONING! Thank you Gilmore A/C! |
