Rear brake drum broke me down again..
Goto page 1, 2  Next
Joeys1969
Joeys1969 is offline
PostPosted: Sun Apr 01, 2012 11:48 am    Post subject: Rear brake drum broke me down again.. Reply with quote
Well, I posted not too long back about me breaking down. It was my passenger side rear drum the was completely stripped on the splines. Well I got a used drum from a buddy and it was an easy fix... So I thought. It happened again today on the way home from work and my car is currently sitting in a school parking lot until my dad can come give me a hand towing it home. Thank god I was only a couple miles away from home, so I just walked home. What could cause this to happen again? It's gotta be something more then the drum for it to happen twice within a month, right? Any pointers would be appreciated. Otherwise I'm just gunna buy a brand new drum and hopefully that'll solve the issue.
hobbybob517
hobbybob517 is offline
PostPosted: Sun Apr 01, 2012 12:45 pm    Post subject: Reply with quote
Get a german drum.
http://www.thesamba.com/vw/forum/viewtopic.php?t=476259&highlight=
Local altitude: 1,180 ft. (yes 1 foot not 1100)
just a reminder for jetting.
75smith
75smith is offline
PostPosted: Sun Apr 01, 2012 1:01 pm    Post subject: Reply with quote
maybe a new stub axle as well, there may be play/excess clearances
if the stub is worn, when you brake your putting extra strain on the drum splines which would cause them to strip, also on acceleration the stub will start to move before the drum
when you replace both make sure the axle nut is torqued down good(230 ft/lbs if I remember correctly)
Joeys1969
PostPosted: Sun Apr 01, 2012 1:03 pm    Post subject: Reply with quote
Will do, should I be able to find that online too?
75smith
75smith is offline
PostPosted: Sun Apr 01, 2012 1:15 pm    Post subject: Reply with quote
should, cip1 has them, so does ww(cost twice as much), try the classifieds here as well
Joeys1969
PostPosted: Sun Apr 01, 2012 1:36 pm    Post subject: Reply with quote
Yeah I'll look around. I'll probably just get it from wolfsburg. Might as well do it right lol
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Sun Apr 01, 2012 3:45 pm    Post subject: Reply with quote
You need a new axle and a new drum
Jerry
Experience always triumphs over hearsay and You get to select which theory to believe
flyboat Premium Member
flyboat is offline
PostPosted: Sun Apr 01, 2012 7:22 pm    Post subject: Reply with quote
Proper torque is key to this repair. If you torqued it properly and it still stripped, I agree with others that the stub axle may be bad.
Proper torque doesn't mean "As tight as me and my buddy could get it with a cheater bar" Razz
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Z06 Vette
Joeys1969
PostPosted: Sun Apr 01, 2012 7:32 pm    Post subject: Reply with quote
Thanks for the responses guys. Yeah I do have a torque wrench but don't know the proper specs lol
I will order a drum and axle tonight Embarassed
Lucatero
Lucatero is offline
PostPosted: Sun Apr 01, 2012 8:49 pm    Post subject: Reply with quote
I read somewhere on this forum, that having the rear of the car lowered can cause stress on the spines and cause them to strip out. I have a 64 that is lowered and have stripped the splines on that vw, and I have a stock height 71, and have not had this problem.
64 Beetle Type 1/Totaled
64 Beetle Type 1/Totaled after owning 5day!
71 Beetle Type 1
70 Karmann Ghia
Vinnems
Vinnems is offline
PostPosted: Sun Apr 01, 2012 11:44 pm    Post subject: Reply with quote
I'm amazed you were able to strip another drum so quickly, unless that drum was in piss poor condition when you got it.
vw_hank
vw_hank is offline
PostPosted: Mon Apr 02, 2012 1:35 am    Post subject: Reply with quote
the top 2 causes of this problem are:
#1 improper torque.
#2 cheep (non German) drums.
1302s sunroof..
TimsACVW 1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Big thanks to my friends Jes67 & Keoki
vw_hank
vw_hank is offline
PostPosted: Mon Apr 02, 2012 1:39 am    Post subject: Reply with quote
dont surprise me,, used drum of unknown origin. this kid probably just bolted it on without cleaning and inspecting it(no offense to the kid!!).. the splines were probably on there way out before he got the drum..
1302s sunroof..
vw_hank
vw_hank is offline
PostPosted: Mon Apr 02, 2012 1:45 am    Post subject: Reply with quote
your 64 and 71 are two different breads!! ride height has no effect on the 71 with IRS,, but with the 64 the geometry of the rear end of the car is very sensitive to ride height changes,, not only can you eat up the splines you can destroy wheel bearings
1302s sunroof..
Joeys1969
PostPosted: Mon Apr 02, 2012 11:11 am    Post subject: Reply with quote
#1 improper torque.
Thanks for the info Hank and no offense taken(I have the nickname of joey-half-asski with my dad lol). Believe it or not, my cv joint fell off this time, it wasn't the drum Confused I need to go over the whole rear-end and make sure everything is tightened down correctly. anything else I should look at when I'm doing that?
RA 70
RA 70 is offline
PostPosted: Mon Apr 02, 2012 12:54 pm    Post subject: Reply with quote
Joeys1969 wrote:
#1 improper torque.
lol thats awesome.
vw_hank
vw_hank is offline
PostPosted: Mon Apr 02, 2012 2:09 pm    Post subject: Reply with quote
Joeys1969 wrote:
#1 improper torque.
Laughing Your lucky that didn't happen on the free-way!! Torque it all down to spec. make sure you have the little spreaders, use A dab of blue lock-tight
1302s sunroof..
schadenfreude
Banned
schadenfreude is offline
PostPosted: Mon Apr 02, 2012 3:29 pm    Post subject: Reply with quote
x2
get a bentleys, if for no other reason , the torque specs.
x2
you don't want that to happen , on the highway. at full speed.
show photos of the damage, and get better answers.
really.
Joeys1969
PostPosted: Mon Apr 02, 2012 8:15 pm    Post subject: Reply with quote
schadenfreude wrote:
x2
x2
really.
There's no damage at all! I still have yet to fix it, and the cv joint is still attached to the drum but not the trans. I'll take pics before I do any work, I looked the day it happened and somehow, every single bolt is still there, and so are the spacers. My dub loves me Laughing
Joeys1969
PostPosted: Tue Apr 03, 2012 7:01 pm    Post subject: Reply with quote
Literally no bolts fell out, and thats after towing it over two miles Laughing
Goto page 1, 2  Next
