george1969 Samba Member
Joined: December 02, 2008 Posts: 29 Location: Michigan
Posted: Tue Apr 03, 2012 9:36 am Post subject: 1969 beelte bird churping sound rear CV Joint, play in axle |
I have a 1969 beetle and I am now hearing a squeak (bird chirping) sound when the car starts to roll.
The faster I go the faster the chirping sound. I have inspected the front wheels and have now moved onto the rear. I raised the back of the bug and put it on jack stands to see if I can get the sound to happen again when I put the car in gear. No squeak.
It seems that it only happens with the weight of the car on the rear wheels. Could it be the CV joint or the axle or the wheel bearings? I have replaced the entire break system a couple of years ago.
Also, when pulling the passenger side wheel drum off, I noticed that the “toothed” axle pulled about ¼” out with the pulling of the drum. Once I got the drum off, I was able to push and pull the toothed axle in and out about ¼”. Is that normal?
Any help would be greatly appreciated.
60ragtop  Samba Member
Joined: March 13, 2006 Posts: 2465 Location: Big Wonderful Wy
Posted: Tue Apr 03, 2012 9:50 am Post subject: |
| What is the rear axle nut torque? You running hubcaps /beauty rings? |
Posted: Tue Apr 03, 2012 9:56 am Post subject: |
| 60ragtop wrote: | | What is the rear axle nut torque? You running hubcaps /beauty rings? |
humm...not sure the torque on the castle nuts (got em thinking). and hubcaps no rings. |
Koeppler Samba Member
Posted: Wed Apr 04, 2012 5:34 am Post subject: Re: 1969 beelte bird churping sound rear CV Joint, play in a |
| george1969 wrote: | I have a 1969 beetle and I am now hearing a squeak (bird chirping) sound when the car starts to roll.
Any help would be greatly appreciated. |
I'm not being snarky when I say that "beelte bird churping"sounds a little weird. I swear I've made posts that got no responses b/c I had big misspellings in the title but got responses once I fixed them. Just a thought.
And now.....
When say you took the drum off, do you mean literally just the drum or are you also talking about the backing plate? B/c just taking off the drum there shouldn't be 1/4" of play but once you take off the backing plate you've removed the grease seal and taken tension off the bearings so some very slight movement is to be expected.
If you only took the drum off, then that's another story but check out the video in this thread and see if you can relate to it:
http://www.thesamba.com/vw/forum/viewtopic.php?t=452619&highlight=rear+wheel+bearing+noise
That kind of side-to-side play wouldn't be a bad CV joint (nor would the chirping sound as bad CV's tend to click or tick as the ball bearings in it are what's making noise).
When you go fast enough, if the chirping become constant....almost like a whine then you've got bad wheel bearings and you should replace. You might also want to have a new set of spacers on hand b/c if you find that the outer one (most likely one) is messed up then it won't matter much when you put new bearings in.
Spacers and a little explanation of what they do
http://www.chircoestore.com/catalog/product_info.php?products_id=2526
Provide an update if you can.... |
Posted: Mon Apr 09, 2012 6:10 pm Post subject: Better torque the rear castle nuts per spec.!! 1969 beetle |
It turns out it was the torque (or in my case, lack of torque). I tightened it up and my son is back on the road.
Thanks for the advice samba members! |
