stumped on brake issues
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
Wayne26
Wayne26 is offline
PostPosted: Wed Apr 04, 2012 7:27 am    Post subject: stumped on brake issues Reply with quote
Hello
I'm having a wierd issue with the brakes on my buggy. at first everything was old and the brakes were sticking badly and randomly locking solid.
I replaced all wheel cylinders still had issues.
I replaced the master cylinder still had issues.
I replaced all rubber and steel lines still have issues.
everything is new now but randomly the brake system pressures itself up. It can be just sitting in the garage for days and all the pedal freeplay will be gone, brake lights on, brakes locked solid. I have to break a bleeder loose and it squirts fluid like someone is pushing the pedal hard and I can hear the brakes release.
after I do the bleeder it's usually fine for the day. it's a stock brake setup kingpin/swingaxle.
any ideas?
joescoolcustoms Premium Member
joescoolcustoms is offline
PostPosted: Wed Apr 04, 2012 7:36 am    Post subject: Reply with quote
The only idea that comes to mind, make sure the push rod has play so it is not slightly holding the MC piston in the cylinder covering the fluid resivoir port.
The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
manxdavid
manxdavid is offline
PostPosted: Wed Apr 04, 2012 8:11 am    Post subject: Reply with quote
X2...sometimes they can feel as if they have free play when it's just not enough. 1mm at the pushrod can equate the quite a lot at the pedal.
Dale M.
Dale M. is offline
PostPosted: Wed Apr 04, 2012 8:33 am    Post subject: Reply with quote
Got to go with the above two suggestions... Had same issue at one point. A little twirl of the adjustment and all is well....
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
Wayne26
Wayne26 is offline
PostPosted: Wed Apr 04, 2012 8:45 am    Post subject: Reply with quote
thanks for the replies. I had set the freeplay but will check it again.
bigtonkakid
bigtonkakid is offline
PostPosted: Wed Apr 04, 2012 8:14 pm    Post subject: Reply with quote
I had a master cylinder that was new but the piston inside was sticking. I also had the wrong year push rod it, the adjusting nut would catch the hole sometime here is a link to some info
http://www.thesamba.com/vw/forum/viewtopic.php?t=438127
YES, I drove a hardtop Buggy!!!
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
