Baja68 Samba Member
Joined: June 08, 2007 Posts: 576 Location: Houston Texas
Posted: Wed Apr 04, 2012 12:06 pm Post subject: another beam adjuster question |
So I got my weld in adjusters in and I have a question for you guys I did search but did not find the answer I was looking for.
I cut my hand so I can get out there and play test fit and figure it out so I thought I would just ask you guys.
Inside my new adjusters there are 2 set screws one is small, and can not be reached unless the inner sleeve is removed the other is the large one that goes through the tube and hits the spring plates.
So my question is the small set screw does it just sit there like it is to support the sprigs and since I removed the small springs I image it will not be making contact with anything.
I plan to line the notch in the spring plate with the large bolt set screw that goes all the way through and has the lock nut on it.
What can you tell me about that small set screw?
Thanks _________________ My Build Page http://www.thesamba.com/vw/forum/viewtopic.php?p=3852984&highlight=#3852984 |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Wed Apr 04, 2012 2:07 pm Post subject: |
The smaller set screw holds the leaves tight in the circular anchor piece. The longer set screw it the one the adjuster screw pushes against to rotate the anchor piece and raise or lower suspension height.
The drawing is by Matthew Pate. I'm not sure what his note on seams is about |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Apr 04, 2012 2:27 pm Post subject: |
Note that there is different setup if beam is Ball Joint vs King & link....
The way the adjusting screw is oriented and the inner lock set screw is located will depends on what beam type you have...
http://www.swayaway.net/joomla/images/InstallInstr...USTERS.pdf
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Wed Apr 04, 2012 4:03 pm Post subject: |
The small screw holds the dimple in the leaves. What you do is remove the large screw rotate the inner sleeve to expose the small screw, install the leaves so the screw will hit the dimple, tighten screw, rotate leaves, install large screw. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Baja68 Samba Member
Posted: Wed Apr 04, 2012 5:37 pm Post subject: |
thanks for the quick answers guys.
Is there any negative effect on the adjuster or leafs since I removed all the upper and lower small leaves? In other words will it fit properly and the grub screw tighten up correctly?
should I cut them and put them in?
Thanks
Oh ya I have a B/J beam with avis adjusters currently. _________________ My Build Page http://www.thesamba.com/vw/forum/viewtopic.php?p=3852984&highlight=#3852984 |
Posted: Wed Apr 04, 2012 7:03 pm Post subject: |
It'll probably work OK for a while, but eventually because the leaves have more space to flex in the anchor piece, there will be movement, then it'll wear and eventually become loose. It'll take a while and depends on how hard you use it. |
