Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Wed Sep 25, 2013 5:26 am Post subject: |
Just because you can't imagine something doesn't mean it's not real.
Damn man, I told you I own one of these transaxles and it's in my garage. I'm not lying and I know what I'm talking about!
And of course there won't be an off the shelf solution for axles to adapt this trans to VW hubs, but I own a welder, so anything is possible. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
Posted: Wed Sep 25, 2013 5:29 am Post subject: |
And FYI, NAPA shows the right side axles are 17" longer for a stick than for an auto. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Wed Sep 25, 2013 9:56 am Post subject: |
I stand corrected. Not that I was acting like I was right anyway. In that pic it still looks like there's half the case missing on the other side but that's just my auto-bias tricking me.
Just for argument's sake, it seems like one side would still be pretty close to the wheel since you have the length of the engine to contend with on the other side.
BTW I hope you didn't think I was being a know-it-all, smarty pants. I just couldn't see why they'd have a 17" longer axle on one side. Seems like it'd cause an imbalance somewhere, but what do I know lol I over analyze things too much some times. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Stingray250 Samba Member
Posted: Wed Sep 25, 2013 5:41 pm Post subject: |
Or you could always just drive a 2004 Cavalier... |
Valen76 Samba Member
Joined: May 08, 2006 Posts: 142 Location: Fallbrook, Ca
Posted: Wed Sep 25, 2013 7:38 pm Post subject: |
Stingray250 wrote: |
Haha!!!! _________________ Darrin
Fallbrook, Ca
Texas Transplant
68 VW Ecotec Baja Bug
86 Honda TRX310R
98 30' Bounder
06 Chevy Avalanche |
Posted: Wed Sep 25, 2013 7:59 pm Post subject: |
I'm sure people used to say "why don't you just drive a 63 beetle". At least an 04 cobalt makes 150hp and has a trans axle designed to hold it. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
Aruba1 Samba Member
Joined: November 13, 2012 Posts: 95 Location: Birmingham, AL
Posted: Sat Sep 28, 2013 8:59 am Post subject: |
I can comment on the longevity on the Quad 4 engine. My father was a taxi driver in Aruba and he had a 1990 Oldsmobile Cutlass. He never replaced any internal engine parts. At 550,000 miles, the head gasket quit. We removed the heads and to our surprise the pistons and bores looked like they only had 50k miles on them. Had the head milled, put new gasket and off he went again. The tranny quit for the 3rd time around 600k and he retired the car. I do remember issues with the coil though, sounds like he had to replace it every 100k miles or so. The Quad was the only engine that came close of being as reliable as his other diesel cars (Nissan Laurel, Pathfinder, Landcruiser, Toyota Crown, Hyundai H1, etc ). |
shephard_scott Samba Member
Joined: April 25, 2011 Posts: 82 Location: Flint, Michigan
Posted: Wed Sep 10, 2014 11:05 am Post subject: |
I am in the middle of an ecotec swap and am interested to know what thermostat you are using and what the fan temps are set at. Did you leave them stock or lower them? |
72Pstroke Samba Member
Joined: April 04, 2011 Posts: 182 Location: North Idaho
Posted: Wed Sep 10, 2014 6:06 pm Post subject: |
I used a stock thermostat, as that is all I could find locally. I think it was only available in 180* or 185*.
I did lower the fan temps on the ECU. I think the fan comes on around 197, off at 192 or so.
Tim |
ponyboy88 Samba Member
Posted: Wed Sep 10, 2014 6:19 pm Post subject: |
Has anyone tried a mtx75 transaxle for a mid engine build? I've had it kicking around in my head for quite sometime. It's a light weight fwd or mid engine transaxle available with an LSD that puts up with 300-400 hp (in the old nobles). Cool build, I'll probably go water cooled once I need more power, but being as I'm a swing axle I'll probably wait till I swap or find a new pan. _________________ 1970 Baja Bug. |
EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Fri Sep 12, 2014 9:36 pm Post subject: |
Looks good. Everyone is installing Ecotecs and I'm just here like "I fixed the parking brake!" |
WD-40 Samba Member
Posted: Sat Sep 13, 2014 10:02 am Post subject: |
EnjoyNukaCola wrote: |
_________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
JabaDubRider Samba Member
Joined: June 02, 2012 Posts: 341 Location: Highland Mi
Posted: Thu Sep 18, 2014 4:54 am Post subject: |
JJozwiak wrote: |
Can u Carburate an Ecotech? |
Yes, I have saw ecotecs and quad 4s with dual webers off of a vw adapted to them. I don't know if someone makes the intake to do it or whether it was that persons custom job. They used the crank sensor for signal and two gm wasted spark coil packs. At that point you would have spent about the same amount of money and it wouldn't have quite the same power or drivability but it's ultimately about whether you are comfortable working on something carburated or fuel injected. Half the fun of my ecotec swap has been working through the little issues you get when putting a computer controlled, water cooled engine in an offroad car. |
Ken48442 Samba Member
Joined: August 29, 2010 Posts: 112 Location: Holly, MI
Posted: Thu Jan 08, 2015 12:10 pm Post subject: |
Did you brace the engine at all with the rear cage? Also, are you running stock rear arms or did you go longer and wider with them? |
Posted: Thu Jan 08, 2015 1:18 pm Post subject: |
shephard_scott wrote: |
JJozwiak wrote: |
A little late but I got time... http://quad4rods.com/ _________________ Brian H.
