KevbOliver Samba Member
Joined: February 29, 2008 Posts: 204 Location: Forestville, CA
Posted: Sun Apr 08, 2012 3:21 pm Post subject: Steering pops loose when turning right.. |
I'm trying to figure out what parts and tools ill need to go on a rescue mission for my bus... He is 5 hours north of my house and the steering is iffy... When i turn the wheel to the right it feels like something is popping out of its socket . When i get down under the front and look at the steering box there is some loose kevlar looking rope that is coming out. Any help to make this a smooth rescue would be super appreciated!!! Thanks!
79 FI BayWindow _________________ THANK GOD FOR THESAMBA!
79 2.0L FI SeaFoam Baywindow (Oliver)
83.5 VanagonL 1.9 Westfalia
90 Syncro |
SGKent Samba Member
Joined: October 30, 2007 Posts: 17526 Location: State Capitol CA (Sacramento)
Posted: Sun Apr 08, 2012 7:03 pm Post subject: |
there is nothing rope or kevlar in the steering. The steering wheel attaches to a solid shaft. That shaft is bolted to a rubber puck that rubber puck also bolts to the top of the steering box. Out of the bottom of the steering gear is an arm. That arm bolts to a draglink that goes straight back to a swing arm that turns on a big pin on the torsion tubes. Off that same arm a tie rod goes to each wheel. The steering box is bolted to the frame. Nothing is tied in the steering. _________________ Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote | Quote: | | "When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. " |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 2231 Location: Los Gatos,Ca.
Posted: Sun Apr 08, 2012 7:52 pm Post subject: steering pop |
Sorry you broke down that far away from home.
Worst case is a Broken ball joint..
But, what you said about the rope thing could be the
remnents of your steering coupler meaning it's Broken.
Nt sure where near Forrestville you can buy one
part# 211 415 417
tools to change it
13mm socket and some extensions to fit your 3/8 ratchet
14 mm socket
13 and 14 mm wrenches
needle nose pliers and side cutters
You also have 4 small cotter pins that are needed.
The cotter pins Must be removed BEFORE taking the bolts out
of the old coupler. _________________ V.W.owner since 1967 |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4083 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Mon Apr 09, 2012 9:37 am Post subject: Re: steering pop |
| old DKP driver wrote: | Sorry you broke down that far away from home.
part# 211 415 417
tools to change it
14 mm socket
of the old coupler. |
This is, perhaps, one of the most helpful and complete posts have I ever read. It's all there. Nice work O DKP D. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Posted: Mon Apr 09, 2012 7:40 pm Post subject: |
Yeah, Thank you!
I doubt it to be a ball joint since i just replaced the whole front end(to avoid doing my ball joints!)
I can feel the pop in the steering wheel, almost like its gonna pop out onto my lap
Thanks for the checklist, i will be sure to gather all required elements and do my research on the steering coupler... _________________ THANK GOD FOR THESAMBA!
90 Syncro |
SGKent Samba Member
Posted: Mon Apr 09, 2012 10:35 pm Post subject: |
when you get a chance take a photo of your rope like thing and post it. _________________ Steve aka Merlin the Wrench
Posted: Mon Apr 09, 2012 11:00 pm Post subject: |
| I am wondering if in some previous lifetime the seal on your steering box went bad and someone stuffed some asbestos packing up in there to try and keep the oil in. At this point the oil is gone and the box is dry and shot. Yes a picture would be nice. |
SGKent Samba Member
Posted: Tue Apr 10, 2012 7:42 am Post subject: |
| Wildthings wrote: | | I am wondering if in some previous lifetime the seal on your steering box went bad and someone stuffed some asbestos packing up in there to try and keep the oil in. At this point the oil is gone and the box is dry and shot. Yes a picture would be nice. |
I was kinda wondering the same or if the bus simply picked up debris. The description of the wheel popping out at him sounds like a steering coupler (puck) because it woudl take an awful lot of force to break the innards of a steering box. Even if the lower arm came loose the wheel would not move up and down or rock. Another possibility is that the nut on the steering wheel is loose. _________________ Steve aka Merlin the Wrench
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23863 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Tue Apr 10, 2012 7:56 am Post subject: |
Here's a great pic of a decomposed steering coupler with the reinforcing cords hanging out of it:
Oh wait... someone didn't use the Samba gallery to post it and now it's gone..... GRRRRRRR!!! _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
SixStringMadMan Samba Member
Joined: December 02, 2011 Posts: 98 Location: Roseville, CA
Posted: Tue Apr 10, 2012 12:50 pm Post subject: |
That looks familiar I will be sure to post pics when i get up there... I have managed to track down a german made replacement in Eureka at Honest Engine...
So, if this is the culprit, is it unsafe to drive with this part failing??? _________________ THANK GOD FOR THESAMBA!
90 Syncro |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Tue Apr 10, 2012 3:26 pm Post subject: |
I thought it may have been the puck, and of course it's unsafe to drive with a failed steering coupler. Any vehicle with diminished ability to control the direction is unsafe. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
AB westy nut Samba Member
Joined: June 01, 2010 Posts: 799 Location: Calgary, Alberta
Posted: Tue Apr 10, 2012 3:47 pm Post subject: |
| SixStringMadMan wrote: |  |
"premium quality"  _________________ 1976 Sage Green Westfalia Deluxe
freshly built 2.0L FI GD motor as of 07/12 |
kamara Samba Member
Joined: January 27, 2008 Posts: 117 Location: Tallahasee, Fl.
Posted: Tue Apr 10, 2012 4:03 pm Post subject: |
When my steering damper went bad, the joint popped whenever I would turn the steering wheel. Had someone turn the wheel while I went under the front end and located the source of the noise..... _________________ "Spirit is the journey - body is the bus
I am the driver - from dust to dust." J. Clegg |
SGKent Samba Member
Posted: Tue Apr 10, 2012 4:41 pm Post subject: |
if it is broken you can't drive the bus but the fix is only about 20 minutes on a late bay _________________ Steve aka Merlin the Wrench
Posted: Wed Apr 11, 2012 6:37 pm Post subject: |
| Quote: | | and of course it's unsafe to drive with a failed steering coupler |
It sure feels unsafe!!! _________________ THANK GOD FOR THESAMBA!
90 Syncro |
Posted: Wed Apr 11, 2012 6:49 pm Post subject: |
| Quote: | | When my steering damper went bad, the joint popped whenever I would turn the steering wheel. Had someone turn the wheel while I went under the front end and located the source of the noise..... |
Steering damper, that is the shock looking thing down there right? I'll be sure to check that out too. Thanks! _________________ THANK GOD FOR THESAMBA!
90 Syncro |
Sidbus Samba Member
Posted: Sun Apr 29, 2012 8:22 pm Post subject: |
Yes i did! Thanks for all the help!!! It was exactly as we all thought... here is a photo of the busted coupler (note the "kevlar looking rope" stuff)
Basically, I went up to my Bus with tools in hand and pre-ordered a German replacement coupler, pulled up my floor mat, unscrewed the two philips head screws holding down the base of the steering column and could see it all. A busted up rubber. I turned the wheel a bit and the whole column broke free YES I THINK ONE MORE TURN AND I WOULD HAVE BEEN AT THE MERCY OF CA199! I had a friend use a socket wrench from the top (13mm) while i underneath held the nuts(13mm) with a wrench. we unbolted all 4 - two of them had big washers and two had small washers. I got out the replacement and guess what...
It was too small!!!! Damn! so i had to leave the bus, go to the part store the next day, they had to order a different one, i had to drive home and wait till the following weekend.
Went back up and got the right part (only the one they got in was EuroMax?- not German )
Got back up to the bus, put it in, learned to lightly tighten them all before cranking them down, screwed the plate back down and laid out the floor mat and wha la! Pretty easy fix really, no cotter pins just four bolts 4 washers 2 screws and a rubber. Thanks everyone. Oliver is now home.  _________________ THANK GOD FOR THESAMBA!
90 Syncro |
SGKent Samba Member
Posted: Sun Apr 29, 2012 8:26 pm Post subject: |
cool _________________ Steve aka Merlin the Wrench
