mph1970 Samba Member
Posted: Mon Apr 09, 2012 8:19 pm Post subject: Red Light on Speedo |
| Quick question...Red light (left of turn signal indicator) was coming on during idle. When I gave it gas, it would go off. I thought this was oil pressure light but as I read through the forum, apparently its not. Yesterday, it came on while I was driving (55 mph) and stayed on for about 20 miles then flickered off and on until I got to work. Its a 56 Oval with a 36hp motor. Any thoughts? Thanks |
66brm Samba Member
Joined: January 25, 2010 Posts: 2527 Location: Perth Western Australia
Posted: Mon Apr 09, 2012 8:23 pm Post subject: |
Sounds like the points in the voltage regulator may be sticky/need a clean, or your fan belt could be loose, or you have llose/dirty connections in the charging system somewhere _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
| modok wrote: | | I am an expert at fitting things in holes, been doing it a long time |
Posted: Fri Apr 20, 2012 3:25 pm Post subject: |
| The fan belt was loose...took out a few shims and bingo. Thanks for the help. |
Motorhead55 Samba Member
Joined: August 22, 2007 Posts: 441 Location: California U.S.A.
Posted: Fri Apr 20, 2012 8:16 pm Post subject: |
How good are your generator brushes? If they are worn down then the generator can be sporadic. _________________ 1955 VW BUG European Deluxe Delivered to Holland. 1700cc single port, Zenith 2 barrel. Porsche A drum brakes.
2012 Jetta TDI Sportwagen. Tornado Red, Black interior.
2007 Dodge Cummins Diesel 4x4 6spd stick
1977 Mercedes 240D, 1939 WILLYS pickup |
