Stupid question
Goto page 1, 2  Next
green73
green73 is offline
PostPosted: Thu Apr 12, 2012 10:33 am    Post subject: Stupid question Reply with quote
If I take off the two hoses that come from the dog house to the heater boxes and plug the holes will the car run cooler? I dont need the heat as its already in the 80s here
~Tim~
Own now. 1973 bright green standard Beetle daliy driver Green Bug
Owned. 1977 yellow AMC Gremlin
1974 Lincoln Continental mark IV
1986 4X4 Nissan pickup
TjdTaylor
TjdTaylor is offline
PostPosted: Thu Apr 12, 2012 10:36 am    Post subject: Reply with quote
no it will run hotter. Take the tubes off and plug the holes in the bottom tin peice where they went through. If you dont heat will rise up into the engine compartment.
1974 Super Beetle
Beetle Bums VW Club Member
"If you can only be good at one thing, be good at cheating, that way, your good at everything"
Jamies74sb wrote:
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows
smokey503
smokey503 is offline
PostPosted: Thu Apr 12, 2012 10:42 am    Post subject: Reply with quote
Or just plug the holes in the fan shroud with baby food jar caps. Guess they fit well and snug.
Then install your heater hoses so no heat get's in the engine compartment. No heat but still looks stock.
If a car travels the speed of light, would the headlights work?
TjdTaylor
PostPosted: Thu Apr 12, 2012 11:18 am    Post subject: Reply with quote
just plug the holes and dont worry about it.
1974 Super Beetle
green73
green73 is offline
PostPosted: Thu Apr 12, 2012 11:43 am    Post subject: Reply with quote
Why will it run hotter?
~Tim~
Relyt
Relyt is offline
PostPosted: Thu Apr 12, 2012 11:51 am    Post subject: Reply with quote
The heat off of the exhaust will get into yor engine compartment.
71 Super Beetle
Solex 34pict/3
Bosch 034
Cusser
Cusser is offline
Heat and hot air from the exhaust will work its way up through those now-vacated holes in the rear "tin" plate. So even if you cap off the fan shroud openings, you still need to address the openings in the tin. Big rubber stoppers will work. Do you have Ace Hardware over there?
Is there a real reason not to have those two hoses on the engine?
If you can read right to left, you can readily figure out a solution.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2004 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
green73
green73 is offline
PostPosted: Thu Apr 12, 2012 12:29 pm    Post subject: Reply with quote
Haha yeah that right to left was a bit hard getting used to lol! We got ACE I have looked at every car part store and hardware store for new hoses and cant find a thing so I thought it might be better to just stop the holes up. I caped the dog house holes with jar lids and filled the bottom holes with big tin foil wads for the time being Laughing
~Tim~
Juanito84
Juanito84 is offline
PostPosted: Thu Apr 12, 2012 12:31 pm    Post subject: Reply with quote
The original VW idea was to completely seal off the engine compartment into two sections, a bottom and top. The idea is to keep all the hot air beneath in the lower section where it will be pulled out behind the vehicle as it goes down the road. The top section is supposed to keep cool air inside it, cool air that is supplied by the vents under the rear window and possibly on the lid.
Of course dune buggies and many aftermarket shrouds don't follow that idea. Many have taken huge portions off the rear ends of these vehicles thinking that the greater open area will provide better cooling. They don't take into account that recycled hot air doesn't cool as well as cool air.
If you don't keep your heat exchangers sealed off from letting hot air enter the top engine compartment then you are comprimising the cooling system.
Another original idea by VW was to provide plenty of air to all the parts on the engine that get hot. The hotter they get the more air they need so the more air is directed to these parts by the OEM shrouds.
If you take off the heater hoses but don't plug them then you are allowing air to "leak" and your engine won't be getting enough air.
1971 (or 1972) Type 1 1302 Super Beetle
1985 Golf Diesel
green73
green73 is offline
PostPosted: Thu Apr 12, 2012 12:43 pm    Post subject: Reply with quote
No by no means did I plan on driving without plugging the heat exchangers no worrys bro I know that much I just wasnt sure if those hoses some how kept the exhuast cooler thus keeping the engine cooler. Thanks for the help!!
~Tim~
Joey
Joey is offline
PostPosted: Thu Apr 12, 2012 12:53 pm    Post subject: Reply with quote
If you still have the heater boxes in place then you can't remove the hoses. The heater boxes needs the cool air blowing over them to remove the heat or your heads may overheat. If you remove the heater boxes and replace them with J tubes then you can remove the hoses and block off the outlets on the fan shroud but it's recommended to have a 1.5" hole in the plug as this creates the same back pressure as connected heater boxes do. You do not want to change the cooling characteristics inside the fan shroud - it far more complicated than it appears.
Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
vintagevdubbers.ca
green73
green73 is offline
PostPosted: Thu Apr 12, 2012 1:02 pm    Post subject: Reply with quote
Heater boxes are still in place problem is I only have one hose thats in bad shape.
~Tim~
gt1953
gt1953 is offline
PostPosted: Thu Apr 12, 2012 1:34 pm    Post subject: Reply with quote
Duct Tape the bad hose for now.
Numbers Matching VW's are getting harder to find. Find one keep it Stock. You will be glad you did.
PS Wife wants a Type 3 Fastback
Joel
Joel is offline
PostPosted: Thu Apr 12, 2012 2:36 pm    Post subject: Reply with quote
It always amazes how many people are blissfully unaware that they are making their engines run hotter by doing something they *think* will make it run cooler.
As has already been discussed the only time you should ever block off the shroud outlets is when you no longer have heater boxes.
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Apr 12, 2012 7:21 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=211521&highlight=exhaust+vent
In Stereo, Where Available!
green73
green73 is offline
PostPosted: Thu Apr 12, 2012 9:15 pm    Post subject: Reply with quote
Thanks for the info guys! I'll try and make some sorta hose then
~Tim~
Eric&Barb
PostPosted: Fri Apr 13, 2012 7:32 am    Post subject: Reply with quote
No problem.
Just make sure engine is put back as much to stock with seals and all engine tin so it is all sealed up. Any hole you can look down in the engine compartment and right down to the road is an air leak.
By posting images of the engine in question can allow all here to point out potential problems.
schadenfreude
Banned
schadenfreude is offline
PostPosted: Fri Apr 13, 2012 7:34 am    Post subject: Reply with quote
would be nice if someone made 2.5" discs that can block off those
rear tin bib holes...... , im cutting them by hand , a pita.
the caps make an easy regression path..
and j pipes with the heatwrap will send all the heat , to the guy behind you.
and not your heads,..
cheers.
HRVW
HRVW is offline
PostPosted: Fri Apr 13, 2012 10:11 am    Post subject: Reply with quote
Idea As for plugging the fan housing use a 1-7/8 Freeze plug (Brass) East coast terminology or a 1-7/8 (Steel) soft plug west coat terminology.
I like the Brass look and on a persons seasonal choice they can be swiveled out for the cold weather and heat needs and reinstalled during the warmer weather.
jhicken Premium Member
jhicken is offline
PostPosted: Fri Apr 13, 2012 2:06 pm    Post subject: Reply with quote
I assume in Israel you have autoparts stores. Measure the size of the hose or take the remaining one in and buy the appropriate sized hose. This is a common part to find and will probably cost you $5.00.
-jeffrey
Central Jersey Volkswagen Society
Vintage Volkswagen Club of America, New Jersey Chapter
Goto page 1, 2  Next
