mopar_nocar Samba Member
Joined: March 15, 2010 Posts: 32 Location: San Antonio, TX
Posted: Thu Apr 12, 2012 6:57 pm Post subject: 71 super back together, throttle cable question (FIXED) |
So, I got all the tin on the car finally. I was missing the two center deflectors, the firewall tin and thermostat flaps AND the rear engine compartment seal. Now I have all of those and a t-stat.
Now, my queries. What is the tube that goes through the fan shroud for the throttle cable SUPPOSED to look like? Where does it penetrate the firewall tin?
I have it together, but its not right. I'd like it to be so. Any help or pics would be appreciated.
TIA.
sb
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5407 Location: Auburn WA
runamoc  Samba Member
Joined: June 19, 2006 Posts: 2740 Location: 37.54N 77.18W
Posted: Fri Apr 13, 2012 7:15 am Post subject: |
I use a 'universal' brake line from the LAPS for this. Already comes with a nice flared end.
 _________________ *DISCLAIMER* What you see might not be what I typed! |
HRVW Samba Member
Joined: May 01, 2011 Posts: 1543 Location: Rosarito, Mexico
Posted: Fri Apr 13, 2012 10:02 am Post subject: |
Poster may be talking about the after mkt chrome firewall tin. The gas cable tube would go underneath it and NOT thru it.
As for the tube going thru the fan housing it is to prevent the cable chafing and breaking. I like to use a T2 cable with the proper end for the gas pedal...cut to length at the carb. |
Posted: Fri Apr 13, 2012 10:54 am Post subject: |
Well the firewall tin is aftermarket, but not chrome. Do you mean the tube has to go between the tin and the firewall seal?
I will use a brake line. Probably have some sitting around that will work.
Thanks,
sb |
HRVW Samba Member
Posted: Fri Apr 13, 2012 3:09 pm Post subject: |
The throttle cable NEVER went thru the firewall but underneath inside a flexable tube/casing that attached to the metal line out of the frame horn area. Other end went up into the front engine compartment covering the trans bell housing. The metal tube thru the fan housing would fit into the flexable tube/casing and of course the cable end stuck out long enough to connect to the carb. Two pieces that kept the gas cable clean and allowed a easy route for a future replacement.
Still have a couple of them on hand. Use two for my Turbo side draft carb running the cable around outside near #3 cyl and up to the carb...a clean setup.
Without the casing there is the chance of the gas cable catching on the trans top nuts or the clutch cable. Have seen that problem many times in the past. |
Posted: Fri Apr 13, 2012 4:22 pm Post subject: |
Gothcha. I used a piece of 5/16" steel brake line. I pushed it through the fan housing and then through the tin between the firewall and the bell. Pulled the flexible rubber throttle cable to the steel brake line. Everthing's good now, I think.
My sister drove it 20 miles to work and back today, so far, so good.
sb |
