offshores Samba Member
Joined: February 08, 2012 Posts: 662 Location: San Diego
Posted: Fri Apr 13, 2012 9:20 am Post subject: Grinder help |
Starting some body work and want some advice on what's best to knock down some welds. My compressor won't power pneumatic tools so I'll be going electric. I currently have a DeWalt grinder with one of those those thicker (3/16" or 1/4" thick) wheels, but wonder if there's something more efficient for the job??? Is there a better wheel for my grinder or a separate tool all together that you could recommend? Thanks
Jeff |
krusher Samba Member
Joined: September 24, 2002 Posts: 7617 Location: california
Posted: Fri Apr 13, 2012 10:09 am Post subject: |
Electric is much better IMO, all i use at work day in day out. (4.5")
Knock 90% o the weld down with a standard grinding disc,
Then if you want a smooth finish go get one of these'
you can get the in various grits.
http://www.homedepot.com/h_d1/N-5yc1v/R-202830905/...reId=10051 _________________ (06:31:07) RoachGhia: "i drink dick way too fast"
(06:54:29) BoomsVW: "i always feel free down there" |
donbarnes Samba Member
Joined: February 28, 2011 Posts: 486 Location: Wilmington,NC
Posted: Fri Apr 13, 2012 11:51 am Post subject: |
+1 here on that type of disc, I call them flapper discs- They will smooth welds in a hurry, just be careful to keep moving and not overheat one spot. For places they won't reach I have a Makita electric die grinder that I use several different kinds of bits and cutting wheels in, the cutting wheels can also be used to flatten welds with... _________________ Hater of cheap parts and poor workmanship.. |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6244 Location: N.W. Phoenix
Posted: Fri Apr 13, 2012 12:42 pm Post subject: |
| I love this website!!! That's exactly what I was looking for and in fact I have one of those flap discs. I'll give it a shot. I like the die grinder idea as well. I'll have to look into one. Now time to try and weld my fender up without blowing anymore holes through it. I'm a complete rookie when it comes to this. Thanks for the info guys!!! |
Posted: Fri Apr 13, 2012 1:04 pm Post subject: |
They make metal (copper or brass?) pieces you hold behind thin metal for welding so it doesn't burn through as bad, I've got a carbon stick out of some kind of old battery I use for the same thing... For places no one will see the back side of, I hold a long piece of metal behind it big enough to cover the hole, then I notch each side of the backer piece almost all the way through leaving the end just big enough to cover the hole- after welding you just break away the long piece remaining  _________________ Hater of cheap parts and poor workmanship.. |
Posted: Fri Apr 13, 2012 1:11 pm Post subject: |
stop welding on your car and start welding on some scrap- you need to turn the temp down on your wire feed _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
Posted: Fri Apr 13, 2012 2:03 pm Post subject: |
I just called it off. I did get some copper pipe and I cut a 3" piece off, ripped it down the middle on one side and hammered it flat. I fixed the first 2 holes I made, but in the process made a few more. I'm not gonna keep chasing my tail like this. I bought this, 90 Amp Flux Wire Welder
www.harborfreight.com/90-amp-flux-wire-welder-68887.html
and it only has high/low. Worked great when I did some welding on my front beam, etc... but I'm finding out that it's no bueno for sheet metal. What's another alternative that you all would recommend that's inexpensive for a newbie with 110 outlets in the garage. Think I'll just sell this thing and maybe invest in something else if the price is good.
Thanks again for the help guys.
Oh yeah, the flapper disc worked great too. It was like butta!!! |
beetlenut Samba Member
Posted: Fri Apr 13, 2012 2:54 pm Post subject: |
The flux core is tough on the thin stuff. If your set-up allows for a gas conversion, then go with that with some Argon-Co2 gas and .023 Lincoln wire. If not, get a MIG with the gas option. _________________ scrapyards are for quitters
| DesertBob wrote: | | Get a well rebuilt German Solex 34 PICT 3 carb and a new SVDA distributor and you will think you died and went to heaven. |
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Fri Apr 13, 2012 4:13 pm Post subject: |
| I have no idea if mine can be converted, but seriously doubt it. Do you have any knowledge of inexpensive migs that can be had? |
banditwolf Samba Member
Posted: Fri Apr 13, 2012 6:02 pm Post subject: |
Sometimes you just can't weld some spots up when the metal is too thin or rusty. Also use a thinner wire if you aren't. The page says that welder can handle .30 or .35 so try .30 if you aren't. And, No, you can't add gas to that welder. If you plan to do much more welding find a used name brand welder with heat settings. _________________ 1973 Super Beetle l 1981 Trans Am |
Posted: Fri Apr 13, 2012 6:50 pm Post subject: |
1st thing I did was trash the wire that came with it and bought some different .030 from Home Depot. My fenders aren't rusted, but there was a 1" tear that has turned into a few hole. Haha!
Just looked at a Craftsman 934.205111 same as a Century 117-076-002 that's listed on CList. Can't find much info online, but it's a 90 amp 120V and the guy has a tank, regulator and 4 drawer Craftsman toolbox that the mig sits on top of with a nice add on shelf for the tank on the side. Sweet setup. It will take .023 wire which he has and a bunch of other spools of different sizes. Not sure I want to pull the trigger only because I know nothing about it. It says Craftsman Mig Wire Feed 20511 Welder or close to that on the front. Anyone ever heard of or used this one before? |
Posted: Sat Apr 14, 2012 2:28 am Post subject: |
| offshores wrote: | 1st thing I did was trash the wire that came with it and bought some different .030 from Home Depot. My fenders aren't rusted, but there was a 1" tear that has turned into a few hole. Haha!
There nothing speical , but it will do the job. Anything with shielding gas is a huge step up.
http://www.thesamba.com/vw/forum/viewtopic.php?t=157122 _________________ (06:31:07) RoachGhia: "i drink dick way too fast"
miller0358 Samba Member
Joined: November 07, 2007 Posts: 607 Location: northford,ct
Posted: Tue Apr 24, 2012 6:48 pm Post subject: grinder help |
| Gas mig on thin metal is the only way to go. Depot, Lowes, Sears all sell them. Jeff |
