Mark Shutt Samba Member
Joined: February 10, 2012 Posts: 482 Location: Doncaster UK.
Posted: Sat Apr 19, 2014 10:37 am Post subject: |
well my car is in many pieces at the moment, ATF fluid in the diff so looking at rebuilding the diff but struggling to find gaskets for it. at this point I'm not doing anything with actual box as it seems fine.
this is the little bugger in question, it was held in with only 3 studs as one was sheared off and a bolt held in the end with silicone!
_________________ 1968 1600TL Auto build thread, have a look!
http://www.thesamba.com/vw/forum/viewtopic.php?p=6007222#6007222 |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Tue Apr 22, 2014 9:30 am Post subject: |
Just read through this entire thread. Your car looks fantastic and I love it but one thing bothers me. You used a urethane steering coupler. A lot of people have been warning against using these because they can fail and leave you with no steering. I'd hate to see your car wrecked so I thought I'd bring it to your attention. A stock steering coupler is not expensive so you might want to consider replacing yours. JMHO. Again, I LOVE your car! |
Posted: Tue Apr 22, 2014 9:35 am Post subject: |
SBD wrote: |
thanks for that, the next time I'm under there I'll get it swapped out.. I can't believe companies sell them if they are dangerous! I bought one thinking it would be an upgrade _________________ 1968 1600TL Auto build thread, have a look!
SBD Samba Member
Posted: Tue Apr 22, 2014 9:39 am Post subject: |
Mark Shutt wrote: |
SBD wrote: |
thanks for that, the next time I'm under there I'll get it swapped out.. I can't believe companies sell them if they are dangerous! I bought one thinking it would be an upgrade |
Oh, I'm sure the manufacturer would say that it's not dangerous. You're just using it incorrectly. |
Posted: Mon May 05, 2014 10:03 am Post subject: |
today I fitted the new front and rear screens along with new chrome inserts, it was a joy to use the new seals, so supple and gave no grief going in! also fitted a better screen whilst I was at it as the old one had lots of marks and chips in it.
the engine and transmission went back in on Saturday but I have a leak from one of the new stub axle seals so will have to redo that one :blush: luckily I can do that with just removing the CV joint and stub axle :smokin: all in all got quite a lot done over the weekend. _________________ 1968 1600TL Auto build thread, have a look!
Posted: Sat May 10, 2014 2:35 am Post subject: |
seen as though I have some paintwork on the roof to do because I removed the bee sting aerial, I thought I would sort the rear slam panel out as I was never happy with it.. it had some ripples in the metalwork and wasn't prepared very well so it's getting a bit of TLC!
all primed and on 2nd round of stopper just catch any of those small imperfections when it'[s all painted up I have an "<OIL" sticker to go on and I'm also giving the dipstick/filler cap a bit of a freshen up with new gaskets and a repaint.
this is where the silly aerial used to be, I've tried to keep the repair as local as possible as I don't want to paint the whole roof!
Posted: Wed May 14, 2014 10:01 am Post subject: |
all done and finished, quite a happy bunny now and the diff seems to have stopped leaking oil too! so must have just been residue and the fact I ran it with no engine breather for a while so may have blown a bit of oil past the rear main oil seal. only time will tell and for now there's no oil dripping
other little jobs include fixing the clock (again) but this time I had it ticking away on the bench for a few days nicely and kept good time too
