Help with shift coupler
Double69project
Double69project is offline
PostPosted: Fri Apr 13, 2012 11:10 pm    Post subject: Help with shift coupler Reply with quote
Have a question, I am in the middle of a body off restoration. I am now replacing the the shift coupler. I came home with my new Empi coupler and when I removed the old one to compare, it is different. Someone before me has welded an additional piece to it. Has anyone seen this before and what would your guess be to why it was done.
If you don't have time to do it right the first time, you must have time to do it over.
LiveJay
LiveJay is offline
PostPosted: Fri Apr 13, 2012 11:58 pm    Post subject: Reply with quote
Is the screw hole in the collar stripped? Or does it look like the end of your shift run has been cut off?
Jay
'73 Beetle
Double69project
PostPosted: Sat Apr 14, 2012 12:49 am    Post subject: Reply with quote
its not striped and the shaft isn't cut. so????
ashman40
ashman40 is offline
PostPosted: Sat Apr 14, 2012 1:24 am    Post subject: Reply with quote
Does the old one look like an original VW part (VW part#)?
If the old coupler cage (metal part) is still in good shape... clean it up and use just the poly parts from the new coupler.
As far as the welded part... what does it do?
AshMan40
'75 Beetle 1200LS (RHD) {junked due to frame rot}
Double69project
PostPosted: Sat Apr 14, 2012 1:32 am    Post subject: Reply with quote
no looks like an empi one just like new just old, and as far as i can tell the welded on piece seems to be like a spacer.
I mite just use new screws and rubber old part. ill go shot some purple power on old one and see how it cleans up .
Double69project
PostPosted: Sat Apr 14, 2012 1:41 am    Post subject: Reply with quote
Oh and empi part number is #16-5103-0
Dismas
Dismas is offline
PostPosted: Sat Apr 14, 2012 1:43 am    Post subject: Reply with quote
looks to me like the guy just wanted extra assurance the coupler wouldn't slip, so he tacked on a pinch collar.
between that and the regular grub, I imagine it wouldn'tbe slipping.
69/70 chop refurbed from a 70 baja
Double69project
PostPosted: Sat Apr 14, 2012 1:46 am    Post subject: Reply with quote
Should i use what was on there or new?(lots bolt for extra clamp)
topconker
topconker is offline
PostPosted: Sat Apr 14, 2012 2:27 am    Post subject: Reply with quote
Sorry to hijack your thread, but I'm about to change my coupling and have bought an after market one.
Looking at it, I'm not impressed so thinking about just using the rubbers and fitting a bolt through rather than the rolled steel tube and screw that was originally fitted, what do you think?
TC
Double69project
PostPosted: Sat Apr 14, 2012 2:31 am    Post subject: Reply with quote
was thinking bout changing my bolt to feels very cheap, but i don't no much either first time messing with it...
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Apr 14, 2012 3:37 am    Post subject: Reply with quote
The factory style tube in the middle is supposed to fit fairly snugly in the hole through the shift rod. When it doesn't, a rattling noise can develop along the shift rod.
The best new coupler I've ever bought was this one, from Wolfsburg West a few years ago. I very much try to avoid aftermarket ones, and won't go near red urethane.
By the way, when the cage style coupler was first introduced in 64-65 it didn't have a tube/screw type attachment, instead it had a solid metal rod that was held on with a slide clip (which could develop that same rattle if it was a loose fit)
Double69project
PostPosted: Sat Apr 14, 2012 8:50 am    Post subject: Reply with quote
is that rod an easy to find thing or is it going to take me forever to find it. looks like a hard to find piece.
julrich366
julrich366 is offline
PostPosted: Sat Apr 14, 2012 10:36 am    Post subject: Reply with quote
Probably shouldn't hold your breath waiting to find one. The couplers you'll find now are almost 100% like the one in the OP's photo. You'll have to get a used one by keeping an eye on the Classifieds or at swap meets. But they may not come up very often.
When I replaced on a previous VW, I kept the original "cage" (cause the new one looked so crappy compared to the old one) and just swapped out the new rubber/urethrane pieces. Unfortunately you may find the same that people don't get rid of the older ones 'cause the new ones are generally not as nice.
Good luck.
- John
'74 Vert ..lot's to still do.
The Android
PostPosted: Sat Apr 14, 2012 1:21 pm    Post subject: Reply with quote
If you mean that 1964 style, that was mostly an FYI. What I meant when I said 64-65, is that particular style only lasted that long... VW didn't keep that solid-rod/slide-clip style coupler after that. It wasn't long before they phased in the style of coupler with the hollow center and the screw.
Oh, and Wolfsburg West does still sell that OEM-VW coupler:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=311711211
Double69project
PostPosted: Sat Apr 14, 2012 6:31 pm    Post subject: Reply with quote
Alright well I'm going to keep my eye open for that solid rod, but for now the new empi part goes on. It doesn't really matter right now because I'm in the middle of restoration and could easily just swap when I find the rod.
topconker
PostPosted: Tue Apr 17, 2012 12:35 am    Post subject: Reply with quote
So my theory of replacing the tube with a bolt is sound then as I can tighten it to a snug fit with a lock nut which should last a long time?
TC
The Android
PostPosted: Tue Apr 17, 2012 1:49 am    Post subject: Reply with quote
Personally, I wouldn't use a bolt. the text called it an "expanding sleeve" for a reason - it's supposed to snug up inside the end of the shift rod. A simple bolt won't fit snugly, and will get looser over time, and may very well rattle around.
Double69project
PostPosted: Tue Apr 17, 2012 12:12 pm    Post subject: Reply with quote
True but the new bolt and my old one look so cheap and easily breakable
Double69project
PostPosted: Tue Apr 17, 2012 1:24 pm    Post subject: Reply with quote
I found out when I went to go get my transmission rebuilt that the transmission I have is a 73-74, could this be why the coupler is modded.
The Android
PostPosted: Tue Apr 17, 2012 2:36 pm    Post subject: Reply with quote
While the nosecone changed in 73 for a different style of front mount, the gear selector "hockey stick" inside it, plus the shift coupler itself remained the same.
