Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Apr 24, 2012 10:20 am Post subject: |
I recognize the seat in the photo above. Standard Virco stacking school chair seat. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Apr 24, 2012 3:15 pm Post subject: |
A few comments on your axle. May not make much difference for what you are doing, but you should have used fine thread. That gives you the ability to us a cotter pin and get a little more adjustment out of the castle nut.
Also, you are going to want to make a small spacer to go over the axle first so it goes up against the welded area. If you have a 5/8 drill bit, you can use a piece of EMT for that spacer. The 5/8 drill simply takes out the boogers and really doesn't remove much material. You only need a spacer about 1/4 to 3/8 inch. It will help keep your bearing from getting stuck on there.
It also may have been better to use a solid rod for the axle. That way you know the axle is straight. Welding bolts on is really difficult to get them both square.
But again for this application it is probably fine. For our 4 wheel stuff, I prefer a straight axle because wheel alignment is critical to us. We also mount the axle in bearings so it can spin in the chassis and the wheels can then spin on the axle. You may want a little more rolling resistance then that! _________________ Mother Nature is a Mean Evil Bitch! |
thext94 Samba Member
Joined: April 11, 2010 Posts: 1003 Location: Manhattan Beach, CA
Posted: Tue Apr 24, 2012 9:45 pm Post subject: |
Robbo112233 wrote: |
Shouldnt the 'V' cut for the headtube be in the other direction? |
Yes sir, good eye. I got a bit excited and started notching the wrong side for the axle. I'll be chopping that off and notching it the correct way. Luckily I measured out a bit extra for mistakes like that.
Quote: |
Also, you are going to want to make a small spacer to go over the axle first so it goes up against the welded area. If you have a 5/8 drill bit, you can use a piece of EMT for that spacer. The 5/8 drill simply takes out the boogers and really doesn't remove much material. You only need a spacer about 1/4 to 3/8 inch. It will help keep your bearing from getting stuck on there. |
I understand the need for a spacer, but I can't picture what your suggestion is, or how the 5/8 drill bit and EMT is involved...help?
Lots of good points in there though. I spent awhile trying to get those axles square, and I got almost perfect, but they'll never be perfectly straight. That solid axle idea is a good proposition, may use that if I end up building more. The only solid axles I had seen used were live axles which I didn't want, but I never really thought of just welding them on and using bearings. |
Robbo112233 Samba Member
Joined: September 18, 2011 Posts: 817 Location: London, UK
Posted: Wed Apr 25, 2012 1:20 am Post subject: |
thext94 wrote: |
Yes sir, good eye. I got a bit excited and started notching the wrong side for the axle. I'll be chopping that off and notching it the correct way. Luckily I measured out a bit extra for mistakes like that. |
Aha, i thought so. Its looking good so far! Are you cutting the headtube from a existing frame?
Im not sure if to use a cut down frame for the main part and stick the axle on the back. Or do what your doing and just stick the headtube on a custome frame. _________________ 1973 Bug
Beetle Bums VW Club member
Archie's Photo Gallery |
Undis Samba Member
Joined: October 24, 2006 Posts: 1396 Location: Riga, Latvia & Sydney, Australia
73 KAFER Samba Member
Joined: September 02, 2007 Posts: 1385 Location: St. Marys, Pa.
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Apr 25, 2012 6:49 am Post subject: |
thext94 wrote: |
I don't know about the drill bit, but the EMT will be there to scrape you off the front bumper of the car that you run into. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Posted: Wed Apr 25, 2012 8:26 am Post subject: |
EMT electrical tubing is almost the perfect size to slide right over a 5/8 axle. But it needs to have a 5/8 drill bit run through the inside for a clean up cut before it will fit.
The nice thing about using that as a spacer is the thin wall. When it is installed it will sit only against the inner race of the bearing. So the rest of the bearing is able to spin free.
We use these a lot on our down hill cars running a 5/8 axle. usually they are only about 1/4 to 3/8 inch long.
Also for an axle, you can just use a piece of 5/8 rod. BUT you need to take your bearing with you sometimes. Depending on where you go, some 5/8 rod is exactly 5/8 OD which creates a problem when you try to put an exact ID 5/8 bearing on it. It's too tight. But most 5/8 rod is just under 5/8 so the bearing slips on nice and snug but isn't stuck.
If you have a threading die you can thread the ends and use a nylock nut or a castle nut and cotter pin.
If you don't have a die, just drill the ends for cotter pins and washers or spacers until you get the slack out. _________________ Mother Nature is a Mean Evil Bitch! |
The Sage Samba Member
Joined: December 10, 2005 Posts: 2470 Location: Traverse City
Posted: Wed Apr 25, 2012 3:40 pm Post subject: |
Has anyone been enterprising enough to start taking bets? _________________ Feel My Pain l Sage Ad World |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Wed Apr 25, 2012 6:37 pm Post subject: |
The Sage wrote: |
Has anyone been enterprising enough to start taking bets? |
i bet 5.00 this isn't going to end well _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Apr 25, 2012 8:19 pm Post subject: |
skills@eurocarsplus wrote: |
The Sage wrote: |
i bet 5.00 this isn't going to end well |
Five bucks says nobody gets hurt until after the third run down the hill. _________________ nothing |
super72beetle Samba Member
Joined: November 21, 2011 Posts: 491 Location: Wisconsin
Posted: Wed Apr 25, 2012 8:25 pm Post subject: |
thirds are usually the worst... |
Posted: Wed Apr 25, 2012 11:06 pm Post subject: |
The nice thing about using that as a spacer is the thin wall. When it is installed it will sit only against the inner race of the bearing. So the rest of the bearing is able to spin free. |
Ahh! Makes sense now. I don't have any tubing that size, but i'm hoping I can find some thin wall bushings in the bucket of hardware in the garage.
Im not sure if to use a cut down frame for the main part and stick the axle on the back. Or do what your doing and just stick the headtube on a custome frame. |
Yup, I just hacked the front forks, bars, and headtube off an old bike. Disassembled everything, welded headtube on at 28ish* angle, put everything back together.
It's starting to look official...
Posted: Thu Apr 26, 2012 3:51 am Post subject: |
thext94 wrote: |
Sweet man, i cant wait to get started on mine! _________________ 1973 Bug
Posted: Thu Apr 26, 2012 10:17 pm Post subject: |
Seat! (ratchet strapped on...)
I kept the original seat frame and I'll be welding supports to the trike frame and axle
Posted: Fri Apr 27, 2012 1:50 pm Post subject: |
It just seems like you need someplace for your feet. Maybe BMX pegs on the front axle. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Apr 27, 2012 1:54 pm Post subject: |
drscope wrote: |
It just seems like you need someplace for your feet. Maybe BMX pegs on the front axle. |
That's what I'm doing I was going to use a trike front wheel but the pedals will get in the way at that speed _________________ 1973 Bug
Posted: Fri Apr 27, 2012 5:45 pm Post subject: |
drscope wrote: |
Yup, I have a set of pegs off my BMX, just haven't put them on yet |
Lobotomy Samba Member
Joined: May 30, 2010 Posts: 517 Location: Traverse City, MI
Posted: Fri Apr 27, 2012 9:18 pm Post subject: |
Oh man, that's so baller. If there were hills here, I'd get one. _________________ Vehicles I have:
1974 Super Beetle "Reginald"
1983 AM General DJ-5
1958 Honda c-100 |
Posted: Sun Apr 29, 2012 7:39 pm Post subject: |
Lobotomy wrote: |
If there were hills here, I'd get one. |
You have plenty of hills big enough to play with that thing! After all, how fast do you really want to get it going?
Sudden stops hurt! _________________ Mother Nature is a Mean Evil Bitch! |
