Brake bleeder question
Stray Catalyst
Stray Catalyst is offline
PostPosted: Mon Apr 16, 2012 10:22 am    Post subject: Brake bleeder question Reply with quote
So, today I learned that no local FLAPS carries flare wrenches smaller than 9mm. My brake bleeders (1977 VW Westy, stock brakes as far as I know) uses 7mm, I think, and I have to bleed the brakes. Is there any reason not to buy six new brake bleeders, in a size where I can get the right tool? The old ones can come out with vise grips and get replaced with the new ones, which I can install with the correct tool.
Stray
mywifesghia
mywifesghia is offline
PostPosted: Mon Apr 16, 2012 10:41 am    Post subject: Reply with quote
No reason. But, I bet the new ones will be 7mm also, unless you have found otherwise. Is there a Sears or Lowes close by? They will have 7mm.
'70 Ghia Coupe-My Wife's
'69 Squareback/'83 GTi-My Son's
'72 Bus-Mine
'06 Beetle-My Daughter's
VDubTech
VDubTech is offline
PostPosted: Mon Apr 16, 2012 11:47 am    Post subject: Reply with quote
A 7mm socket or regular wrench works just as well. No need to reinvent the wheel here.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
Stray Catalyst
PostPosted: Mon Apr 16, 2012 11:53 am    Post subject: Reply with quote
Embarassed
Now I feel truly dense! Thank you for pointing out the obvious, which I overlooked.
Stray
Wildthings
Wildthings is offline
PostPosted: Mon Apr 16, 2012 12:36 pm    Post subject: Reply with quote
I have a 7mm box end wrench that has been slightly bent on the end from being used to loosen things it was never intend to loosen. Makes an ideal tool for accessing the bleeders with that odd angle on the end though.
