Will the rockers fit?
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
wizcleland
wizcleland is offline
PostPosted: Mon Apr 16, 2012 2:18 pm    Post subject: Will the rockers fit? Reply with quote
Hey Samba!
I have a new set of the CB 1:1.25 rockers (have the kit - http://cbperformance.com/catalog.asp?ProductID=92). Right now stock arms are in.
Question is -
Will these bolt right in? Trying to get an answer from CB but no help. I'm willing to try but what should I watch for?
Any idea if you HAVE to machine for these or theres a chance to fit?
Also, do they impact the pushrod length and would need to change?
Unfortunetly, dont know what kind of heads are on the motor but they are ported.
Cam is a 100
Cylinders are 88.5 or 90s.
As always, Any help would be appreciated!
Life in Mexico, surrounded by Beetles daily....and able to stop at the parts store on the way home for anything, any day ahhhhhh
slalombuggy
slalombuggy is offline
PostPosted: Mon Apr 16, 2012 2:41 pm    Post subject: Reply with quote
Check you rocker arm geometry and make the changes needed whether it be shimming the rockers or longer pushrods. The should fit without any kind of machining being needed.
brad
BB Buggy 121.253mph @ Bonneville 2012
http://www.youtube.com/watch?v=57hMyJmIU10
Raisin cookies that look like chocolate chip cookies are the main reason I have trust issues
mark tucker
mark tucker is offline
PostPosted: Mon Apr 16, 2012 5:58 pm    Post subject: Reply with quote
might need to shorted the push rods a bit, but you will have to stick it all togeather to find out.and check for pushrod interfearance in the cup&the tube.
neil68
neil68 is offline
PostPosted: Mon Apr 16, 2012 7:15 pm    Post subject: CB 1.25's Reply with quote
I've run 1.25's with the Engle 100 camshaft and you only need to shim the rocker stands slightly, and you can still use the stock 11" pushrods.
Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro
wizcleland
PostPosted: Tue Apr 17, 2012 5:23 am    Post subject: Reply with quote
Thanks guys, appreciated.
I'm going to give it a try in a couple of weeks and I'll let you know how it goes!
Cheers!
mark tucker
PostPosted: Tue Apr 17, 2012 9:15 am    Post subject: Reply with quote
I cant find slightly on my mics?is that mm slightly or what?
dsrtfox
dsrtfox is offline
PostPosted: Tue Apr 17, 2012 9:19 am    Post subject: Reply with quote
Just a scosh...
mark tucker
PostPosted: Tue Apr 17, 2012 9:30 am    Post subject: Reply with quote
so it is metric.thanks.
Sharig1979
Sharig1979 is offline
PostPosted: Tue Apr 17, 2012 12:38 pm    Post subject: Reply with quote
My go to answer from here on out is righty tighty lefty loosey and see what happens.
The aircooled VW ratio rocker is what a cam swap is to V8 guys.
1969 Beetle, turbo 1915
~118 mph on the salt at WoS 2012, 7k in 3rd, can't wait to figure out how to drive that engine on that stuff.
1972 914/4, 1.7
1991 GTI 1.8 8v, 4speed
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
